SMG Fault codes help - BMW M5 Forum and M6 Forums
post #1 of 3 Old 3rd February 2014, 08:16 PM Thread Starter
Justchill
Justchill's Avatar
Fellas,
I have a friend who owns a 2008 M5 (around 50K Mi) and has had a few issues with his SMG. He brought it to a local german indy where he was able to pull a 4F40 (hydraulic unit under-shooting of pressure range) fault. The indy was unable to recreate the problem. However my fried has had a few recurrences of the issue. The car will all of the sudden drop into neutral and will be unable to be placed back in gear with that he obviously receives a red cog. not sure how he gets it back in gear but is usually able to find a gear again then he must park it for 45 min or more in order to return to normal. The indy obviously wants to replace the SMG system. Gives the typical answer of making everything new within the SMG system will eliminate any of those parts as the potential problem with the added benefit of a warranty on those parts. With that said I must add he does not have a warranty on the car so cost is a concern.
He is taking it to Mark over at German Motors for diagnosis today.
My thoughts are that it is either a SMG pressure sensor or his pump going bad. I am under the impression that in the 2008 the pumps are not normally problematic as there were some earlier issues that had been corrected after late 2006. Correct me if I am wrong. I just keep thinking it is a pressure sensor issue.
Is the SMG pressure sensor hard to get to (drop trans)?
Any insight will be helpfull
Thanks in advance guys!
E60 M5 Interlagos Blue
H&R Springs and spacers
Carbo Tech carbon ceramic brake pads
Cosmetic
LED side markers and rear plate lights. CF Roundels, matt black badges, vents and kidneys. Laguna Seca Blue calipers MTec LED Angel Eye's
Justchill is offline
post #2 of 3 Old 3rd February 2014, 10:49 PM
5soko
5soko's Avatar
Can try by looking at the simple things.. SMG hydraulic pump relay, there is a simple and cheap DIY on here. Also open the hydraulic fluid reserve and check the hydraulic level.
5soko is offline
post #3 of 3 Old 4th February 2014, 03:20 AM Thread Starter
Justchill
Justchill's Avatar
I assumed the fluid was checked by the Indy.
Could the relay cause intermittent problems?
Cosmetic
Help with fault codes Mohammed_A E39 M5 and E52 Z8 Discussion 5 31st October 2012 11:40 AM
Some fault codes D_Iceman E60 M5 and E61 M5 Touring Discussion 2 6th December 2010 07:14 PM
help with fault codes inssane45 E39 M5 and E52 Z8 Discussion 21 21st June 2010 01:12 PM
Help with fault codes maxm5 E39 M5 and E52 Z8 Discussion 1 3rd January 2008 08:27 PM
need help with fault codes please jkarp E39 M5 and E52 Z8 Discussion 1 7th January 2005 05:30 AM
