Evan's E61: Not an M5 but pretty close... - Page 16 - BMW M5 Forum and M6 Forums
 95Likes
post #151 of 291 Old 15th April 2016, 06:21 PM
Fiftytwoeighty
Fiftytwoeighty's Avatar
Nice use of billet Al! Love it.
Name:	Screenshot 2016-04-15 09.18.42.png
~Woody
///M The ///Most Expensive Letter in the Alphabet
Driving Concepts Competition Racing School
s85 + (afterthought) 6mt =162,000 miles with no RCOD and counting ...just saying...
2007 Dinan S2 e60 m5 6MT Interlagos Blue; DINAN 3.91 Exploded @8x,xxx ; Performance Gearing 3.91 LSD 3 clutch, 30/50 ramps, R&P polished ; ClutchMasters FX350 clutch and LTW single mass FW @157,000 miles, RPi Oil Cooler/Scoops; DINAN High Flow Air Mass Meter/Intake, DINAN TBs, DINAN pulley, DINAN strut, DINAN Monoballs, FastAttack Tune, w/Kung Fu grip!, Einhorn Industries Race Jedders, track pipe, and x-pipe; DINAN Section 3, DINAN LTW 19x9 ET18, 19x10 ET25, Michelin PS4S 275/35/19 and 305/30/19, Macht Schnell 15mm spacers (front); FERODO FRP3000H race pads; StopTech BBK 6/4 380mm/35mm x 380mm/32mm w/SS lines; RDSport F/R sways; MCS 2WNR motorsport coilover, -2.0/-2.5 F/R camber; z3 1.9L SSK, with f10 shifter; F/R G1W-H; Uniden R1, remote ALP 2Rx:1Tx, F/R NetRadar DSP, w/GPS and BT. SprintBooster v3; Euro MDM and DSC off. Fluids: Motul 7100 4T 10w60, Redline ShockProof Lightweight 75w140, Castrol SRF, Unicorn Jizz and Wolfpack Blood; Rod bearings replaced at 84,000 and 150,000 miles!!!
1988 e28 m5 STROKER 420bhp 91 octane(Paul Burke s38b39); VAC LTW flywheel; MegaSquirt G2 DME; Nuke Performance fuel rail and pressure regulator, Carbon Fiber CSL intake; Lifeline Zero 360 FIA 3.0kg Novec fire suppression; Cool Shirt Pro Air/Water system; Euro RestoMod track car: caged, 6 point Schroth FIA harness, FIA Sparco Ergo & Sabelt GT-160 seats...AC/heater, interior, sunroof, rear seat delete; Euro Headers, dump valve, and race cats; CAE Ultra shifter; custom Ground Control Coilovers/camber plates; Mason Engineering front/rear strut bars; Brembo 6/4 BBK; 17x9 BBS Style 42 w/Michelin Cup 2; undergoing Euro restoration, building the e28 CSL ///Motorsport never built. 5.71lbs/hp
Not-spec e30 racercar!!! Fully caged for wheel 2 wheel racing
1996 FZJ 80; LOCKED; Factory TRD Supercharger; Expo/Overland/Backcountry Rig; custom sleeper/drawer system, full rock armor, 33"s on 2.5" OME Heavy Lift; Rigid LEDs F/R; 231,000 miles and counting.
2008 Audi A3 S-Line Quattro w/flappy paddles (Mammoth Mountain Commuter)
2000 e39 m5 TiAg (Gone, but not forgotten) sold 7/2014.
The Indys that I trust for all my Beasts' needs: oceansidemotorsports.com my local physician for service
fastattackmotorsports.com because JColley!
einhornindustires because WolfPack!
~I FRACKING!
~Viva La Wolfpack!
Fiftytwoeighty is online now
post #152 of 291 Old 15th April 2016, 08:09 PM
umichchris
umichchris's Avatar
M5 or not....this is the type of build thread this forum needs!
love it! good look with every step man!
oh and....BRING BACK THE E39 M5!!!!
I do custom headlights & taillights
E46 ///M3 Vert - massive overhaul/rebuild project details here
E60 ///M5 Project #Patina
E36 ///M3 (sold) 5MT sedan
umichchris is offline
post #153 of 291 Old 15th April 2016, 10:01 PM
Ojisonracer
Why not pull the engine and trans as single unit, since your going to replace the engine anyway and it has to come out eventually?
Ojisonracer is offline
post #154 of 291 Old 15th April 2016, 11:19 PM Thread Starter
ucsbwsr
ucsbwsr's Avatar
Definitely done this more than once!
Miss the E39...
I will be doing that when the engine and 6MT go back in, the engine crane isn't in my possession yet (will purchase soon) and I didn't really mind pulling the trans out the bottom. Taller jack stands were purchased for this reason so the work area was prepped for a bottom removal.
But boy-howdy I can't wait to install turbos with the block on an engine stand, it will be a nice change from busting my hands against heat shield in the engine bay.
Evan
2008 N54-Powered E61 M5 Wagon: ~600whp ~600wtq
- AWD-RWD Conversion, OEM M5 Drivetrain Retrofit, Manual Trans Swap, Spec 3+ Clutch, MFactory SMFW
- OEM M5 Brakes, KW V3, RD Sport Sways, UR Strut Braces, Forgestar F14 SDC 19x9.5 19x11, Hankook V12
- Hexon RR550 Hybrid Turbos, Custom Turbo Inlets, AR DP, VRSF 7" IC, ER CP, Tial BOV, RB PCV, BMS OCC,
- BMS JB4, E85 Flash, Fuel-It Stage 2 LPFP, EOS Port Injection Manifold, Custom 3" Exhaust
- OEM M5 Front Bumper, OEM M5 Front Fenders (Vents Deleted), OEM M5 Skirts, OEM M5 Mirrors, M-Tech Rep Rear Bumper
- Quad Projector Headlights, Custom Tail Lights, Rigid SR 6" Reverse Light, Full LED Interior/Exterior Lighting
ucsbwsr is offline
post #155 of 291 Old 15th April 2016, 11:57 PM
umichchris
umichchris's Avatar
Evan
ever thought of about doing an S52 turbo build....or consulting on one? lol
post #156 of 291 Old 17th April 2016, 05:40 AM Thread Starter
ucsbwsr
ucsbwsr's Avatar
I am not knowledgeable enough on the E36, S52, or turbos in general to be a huge asset. But I wholeheartedly support turbos on anything and am always down to kick ideas around!
The M5 LSD needed some modification and after testing fitting it with my exhaust and pull rods I knew what to cut off. It was a balance of removing enough material for adequate clearance, with leaving as much as possible for cooling, while making it look as good as possible. I am pretty happy how it came out.
Evan
Oem M5 heatsink
...aaaaaaaand it's GONE!
Pretty hacked up after the cutting
After some more grinding and sanding
535xi and M5 top, modded M5 bottom
Prepped the axles for install, the threads had been hit with some anti-rust coating which needed to be cleaned
Had to pull out the motor for the telescoping wheel function, the bolts were very hard to reach and I am not looking to putting them back in.
Paddle shift steering wheel and control module removed along with the console and electronic gear selector.
Hole punched out for manual shifter :banana
Didn't have the special tool to lock the flywheel/starter in place while the FW bolts are removed so this was my solution.
One hurdle to clear will be the transmission support and bracket. According to RealOem I have compatible part numbers but that is not the reality, the mounting points for where the bracket connects to the trans are different since my trans was sourced from an e9X 335i. The E6X support, bracket, and bushing combo is monstrous compared to the E9X setup. I really like the design of the E6X bushings where it allows the upper bracket to reside inside the bushing, it makes a lot of sense and IMO the design better suited for high torque than the 335i mount.
My goal is to use the E60 support and either modify the top bracket have one made to make the mounting locations work. Not sure which direction to go yet.
Bare trans
Trans with 335i bracket (holes align)
535i bracket (improper fit)
E6X vx E9X
Showing how the E6x bracket feet mount inside the bushings
Bushing (bearing) comparison
ucsbwsr is offline
post #157 of 291 Old 17th April 2016, 05:20 PM
douglas_ngo
douglas_ngo's Avatar
douglas_ngo is offline
post #158 of 291 Old 18th April 2016, 01:47 AM
wchamp7
wchamp7's Avatar
Love this build! Cannot wait to see it all finished!
Sent from AutoGuide.com Free App
2006 M5 (Gunther)
Lamborghini Bianco Isis Triple Paint, Painted Black Roof, Custom rear wide body, Enlaes one-off GT2 hood, Radenergie Roof & Trunk spoiler, Custom Carbon Side Skirt's, 21" Radenergie RF01ís, KW V3's, RDsport V3 Sway bars,ESS Tune,RPi Block Off Plates/scoops/oil cooler, Headers, DTM Exhaust
wchamp7 is offline
post #159 of 291 Old 25th April 2016, 01:14 AM Thread Starter
ucsbwsr
ucsbwsr's Avatar
Originally Posted by douglas_ngo View Post
Great work so far. This thread remind me of the MITE46 thread from E46fanatics.
I looked up his builds and I must say that is quite a compliment, thank you.
Glad you are enjoying it.
Evan
I ended up making a tool to remove the rear differential bushings, part Habor Freight wheel bearing tool, part Home Depot hardware, part 36mm socket I have for the axle nuts. The 36mm socket was a great fit for the front bushings.
Bushings out
Oem vs MFactory Solid (rubber)
Bushings in
M5 axles in
Look how close the outer CV joint is to the wheel carrier!
My test fitting and eye balling suggested fitment would be tight but I didn't think it would be THIS tight! Clearance is literally 1-2mm
If it fits it fits!
LSD, the traction drug
Test fitting pull rods with the modified LSD heatsink.
Looking good
Exhaust should clear no problem
Cleaned up more heat shield
...and my RD Sport sways
ucsbwsr is offline
post #160 of 291 Old 25th April 2016, 02:59 AM
thiknek
thiknek's Avatar
This is a hell of a thread... just one question... are you some type of engineer??
thiknek is offline
E39 Want to buy: a few pretty parts. dj2xrated Parts / Other For Sale or Wanted 2 23rd May 2012 09:30 AM
Soft Close Doors = Won't Close Doors Bibendum E63 BMW M6 Forum and BMW M6 Convertible | m6board.com 7 15th June 2008 07:20 PM
Facelift Headlights & Taillights now available at Tischer BMW from Evan T Bone E63 BMW M6 Forum and BMW M6 Convertible | m6board.com 31 12th February 2008 05:42 PM
Is this pretty? Ashok Arora GTBoard.com: General Sportscars 7 2nd May 2006 10:20 PM
