tilt steering wheel issues - BMW M5 Forum and M6 Forums
 1Likes
post #1 of 11 Old 2nd December 2013, 10:39 AM Thread Starter
liam821
This might be the most annoying problem i've ever had in the history of owning cars.
The tilt steering works 4 out of 5 times, but that every one time it just stops working. My car (2008 M5 6mt) has convenient exit so the steering wheel moves up and down when you turn off the car and start it. So when it stops working the steering wheel is locked in the up position. Sometimes it breaks when its in the down position and when I turn off the car its stuck down (which isn't so bad). When it stops working, the tilt adjustment doesn't do anything - you can't move it up and down or back and forth - just totally locked. Doesn't seem to be any pattern to it either, day or night, hot or cold. Driving the car with the steering wheel pointed towards the sky is unbelievably frustrating as I can't read half the gauges and it blocks the HID. Seat controls work normally when the tilt steering is broken.
I've taken it to the dealer but of course the damn car works perfectly for them and all systems test normal. I asked about maybe a bad SZL sensor but my dealer said the car would normally throw codes and mine has none - and it tested normally.
Honestly I could care less about the convenient exit feature (I'm not a big guy). After searching forums I haven't come up with a clear answer on how to disable convenient exit. I'd rather not disable the tilt steering altogether but if thats what it comes to so be it. Is there some coding to disable convenient exit?
I've also read that convenient exit doesn't work if you don't have your seat position stored which mine is, but I don't know how to delete the stored seat position. Unplug the battery maybe?
My last resort is to unplug the tile steering all together, but I'm not sure if the car is going to get all upset with me if I do.
Any thoughts on how to get this fixed or possible what the problem could be?
thanks!
liam821 is offline
post #2 of 11 Old 4th December 2013, 02:07 AM
jdsanabria
jdsanabria's Avatar
Are you able to bring the steering wheel down using the button on the left side of the steering wheel? Every once in a while my steering wheel stays in the up position and not sure why. What I do is bring it back down to where I want it using the button and set my seat memory again. This resets seats, mirrors, lumbar support, and steering wheel back to where I want it. Convenient exit now works perfectly. This happens probably every few months. I think it has something to do with manually moving the steering wheel up/down with the button...
Current
2006 E60 ///M5 (Silverstone II / Black Interior / Silver Trim)
Mods
  • WeissLicht LED Halo Bulbs
  • Black Grills
  • RPI Scoop
  • BMC Filters
  • V1 - Logic Mode
My Custom Codes
  • DRL inner beams with option in IDrive
  • HUD Turn Signals
  • Side Mirrors Up on Lock
Drive Setting
  • P500 Sport
  • MDM
  • S5
Previous
2006 E60 ///M5 (Interlagos Blue / Silvertone Interior / Walnut Madeira Wood Trim)
2003 E46 ///M3 (Alpine White / Cinnamon)
2003 E39 M-Tech 540 (Black / Black)
jdsanabria is offline
post #3 of 11 Old 4th December 2013, 08:07 AM Thread Starter
liam821
No, when it happens I am unable to move the steering wheel at all. The steering wheel tilt control (the little joystick on the left of the steering wheel) doesn't do anything and turning the car on and off doesn't help. Just stuck.
Turn the car off and leave it for a few hours and magic pixie dust happens and everything works normally again - convenient exit works normally and the steering wheel moves into its normal "memory" position and the joystick also works normally as well.
liam821 is offline
post #4 of 11 Old 4th December 2013, 01:54 PM
jdsanabria
jdsanabria's Avatar
Sounds like a different issue then--almost like it shuts itself down. How old is your battery? I say this because I believe all convenient functions operate while engine is off and car may start to shut things down if not enough power is available.
Current
Mods
  • Black Grills
  • RPI Scoop
  • BMC Filters
  • V1 - Logic Mode
My Custom Codes
  • HUD Turn Signals
Drive Setting
  • P500 Sport
  • MDM
  • S5
Previous
post #5 of 11 Old 4th December 2013, 08:51 PM Thread Starter
liam821
My guess is the battery is original and never replaced. But sometimes the car moves the steering wheel down normally and sometime during driving it get stuck down and won't return the steering wheel back up again - and again its just stuck but this time it will be stuck in the down position. Having it stuck down isn't as annoying at least its at a normal driving position.
liam821 is offline
post #6 of 11 Old 5th December 2013, 02:25 AM
Lay3r3
Lay3r3's Avatar
My initial thought is the motor is on the fritz.
Sent from AutoGuide.com Free App
Lay3r3 is offline
post #7 of 11 Old 5th December 2013, 09:52 AM Thread Starter
liam821
Isn't there two motors? One for up and down, and one for back and forth? Because they both don't work when the issues happens.
liam821 is offline
post #8 of 11 Old 5th December 2013, 03:17 PM
Lay3r3
Lay3r3's Avatar
Good point. I'm. It sure but if you're right it's clearly not the motor. My other thought was the switch but I'd be surprised if the car triggered the switch when you get in and out. Thinking the common thread would be a control module of some sort but I'd think that would tore a code.
Lay3r3 is offline
post #9 of 11 Old 6th December 2013, 12:22 PM Thread Starter
liam821
Yeah the car doesn't throw any code... just sometimes doesnt work.
2008 Indianapolis Red ///M5 6spd (sold)
2011 Platinum Gray X5d
2005 e46 zhp sedan
Honda Civic eg track car
liam821 is offline
post #10 of 11 Old 17th December 2013, 11:59 AM Thread Starter
liam821
Just wanted to update everybody on this issue. I pulled the dash apart and whoever did the CCC to CIC upgrade did a shitty job crimping wires. I pulled apart the twist ties and soldered all the wires and shrink wrapped everything and cleanly put everything back together. Since I've done this I haven't had a problem with the tilt steer not working. I'm guessing something was loose or contacting something else shorting out some electrical system in the car.
So knock on wood but hopefully its fixed now!
2005 e46 zhp sedan
liam821 is offline
Power seat and tilt steering wheel not working HDClown E39 M5 and E52 Z8 Discussion 10 14th July 2014 11:14 PM
Steering wheel tilt not working e39_415 E60 M5 and E61 M5 Touring Discussion 2 12th February 2013 02:28 AM
How to disengage steering wheel tilt? malexgcab E39 M5 and E52 Z8 Discussion 3 5th November 2009 02:32 AM
Tilt steering motor bgregg E39 M5 and E52 Z8 Discussion 3 24th March 2005 06:06 AM
Automatic steering wheel tilt krullshards E39 M5 and E52 Z8 Discussion 20 20th August 2002 04:44 PM
