DIY: 2008 E60 M5 Battery Replacement - BMW M5 Forum and M6 Forums
 10Likes
post #1 of 40 Old 13th September 2013, 04:25 AM Thread Starter
Tottifan
Thanks to everyone who continues to submit DIY's for the E60 M5 - I would be lost without these forums.
I just replaced the battery on my 2008 E60 M5 (10/2007 build) and figured I would share my experience and pictures.
My car had a BMW part # S61 21 6 919 342 battery in it, which is a 12V 90Ah 900A 160RC 900CCA. The battery has a black case, and after doing some research here I found that the best replacement that was readily available to me was a Duralast Platinum H8-AGM from my local Auto Zone.
There are tons of posts about which batteries to use, whether to reprogram or not, etc. I read them all and decided I would simply pop in the H8-AGM and not reprogram.
Please note that I am not a professional - just an enthusiast with a camera. Do your own research before attempting any of this.
My original battery:
Here is the new battery:
Tools required:
- Gloves
- 13mm and 10mm socket
- Pick (optional, but handy for the vent tube cover)
What I did:
1. Turn on car, open window, unlock doors, shut off car. I read something about not letting the car go to sleep, so I started working right after shutting off the car.
2. Remove trunk carpeting/floor (our battery is where the spare would be, not on the side of the trunk like other E60's I have seen) to expose battery.
3. Remove the battery brace, a metal bar that holds it in place. There is a small plastic wire organizer that easily unsnaps to move the wires attached to the brace.
4. Completely unscrew and then remove the negative (black) terminal first, and cover it with plastic.
5. Pop open the red plastic cover on the positive (red) terminal, completely unscrew it and remove it from the battery. It moves up and out of the way easily.
6. Remove the vent tube on the driver's side of the battery. It pops out easily, just wiggle it back and forth.
7. Pull out the battery. The styrofoam around the battery will travel with it a bit, so be ready to just carefully work the battery out.
8. Use a pick or something similar to carefully remove the vent tube cover on the original battery and place it in the same spot on your new battery (the H8-AGM has two vent tube holes, but the car only has one vent tube).
9. Put the new battery in, working once again with the styrofoam to keep it in place.
10. Pop in the vent tube.
11. Reconnect the positive (red) terminal and replace the plastic cover (it pops off the old battery easily).
12. Reconnect the negative (black) terminal.
13. Reattach the metal brace that secures the battery in place.
14. Replace your trunk floor.
15. Start your car. Set the date and time. These were the only two settings I lost.
I started the car and drove it for a bit, and everything seemed fine despite not having programmed anything. I will follow up in a few days after I am confident it is still fine.
Tottifan is offline
The Following 5 Users Say Thank You to Tottifan For This Useful Post:
Clyde (13th September 2013), cutthroat_jake (20th January 2016), Mark Carson (17th September 2013), mattcon (1st January 2016), Minimization (6th March 2015)
post #2 of 40 Old 13th September 2013, 07:18 AM
leletyM3
leletyM3 is offline
post #3 of 40 Old 13th September 2013, 02:28 PM
SilberGrauE60
SilberGrauE60's Avatar
Thanks for the writeup! So, you had a 10/07 original battery thru 09/13 or roughly 6 years. What kind of symptoms, if any, were you experiencing that caused you to change it out? Were you using a tender on the battery and/or how much did you drive your car? Daily driver or occasional use?
Mine is about 1 year newer than yours, and was only getting occasional use. I started getting "high battery discharge" or whatever the low battery warning is, so I put a tender on it, and all is good now. That is, the battery holds a good charge and no more battery warnings. Never got to the point of any other systems flaking out.
2009 BMW E63 M6 SMG Coupe
2004 BMW E60 545i 6MT Sport Sedan (Sold)
SilberGrauE60 is offline
post #4 of 40 Old 13th September 2013, 02:42 PM
Fuddy
Fuddy's Avatar
I would definitely take the time to reprogram the charging system for the new battery
Fuddy is offline
post #5 of 40 Old 13th September 2013, 06:11 PM Thread Starter
Tottifan
My car is a daily driver; mixed highway and NYC traffic I rarely go more than a day without starting it up.
For me, this was mostly a preventative maintenance item and an excuse to work on the car. I had received a SMG red cog error in cold weather last year a couple of times on cold starts. Each time, I just re-pressed the start button and the car worked fine. I replaced my SMG relays (salmon and black) and always wondered whether the slightly aging battery might have something to do with the red cogs as well. I just felt more comfortable changing to a new battery before the temps started to drop, and at least now if I get a red cog I'll know it's something else.
I guess the only other symptom is that I swear sometimes I hold the brake, press start, and the car doesn't attempt to turn over the engine...at which point I have to hit start again and everything works fine. No errors, etc...but I never remember having to press start twice when the car was newer. It also feels like the computer (navigation, radio, etc) takes a few seconds longer than it used to to boot up. All of this is very subtle, but I know my car and can tell when there's a change to the "norm". It's still too early to tell if the battery change fixed any of this (or if I'm crazy).
Tottifan is offline
post #6 of 40 Old 13th September 2013, 06:29 PM
m5tong
+1
m5tong is offline
post #7 of 40 Old 13th September 2013, 06:35 PM
texsn95
FYI, mine is a 10/05 build and I'm still at 30% on my OEM battery, so I think that's pretty darn good . No discharge or random errors yet.
texsn95 is offline
post #8 of 40 Old 13th September 2013, 07:36 PM
galun
galun is offline
post #9 of 40 Old 13th September 2013, 07:40 PM Thread Starter
Tottifan
I did not register or reprogram anything, but as you can already see there are plenty of people who advise against this.
Tottifan is offline
post #10 of 40 Old 13th September 2013, 08:28 PM
SilberGrauE60
Here's what I do on cold starts: keep foot off the brake and press the start button once and let the iDrive screen come up. Then with foot still off the brake, press the start button again: brings up the dash warning lights, etc. Then press brake, move shift lever to N (note shift from 1 to N), then press start button and engine turns over immediately. I feel doing the start in three steps gives time for all electronics to power on deliberately, and lets me note the SMG shifting from 1 to N before I turn the engine over.
The Following User Says Thank You to SilberGrauE60 For This Useful Post:
Tottifan (13th September 2013)
Currently Active Users Viewing This Thread: 5 (0 members and 5 guests)
Replacement Battery WOO E34 M5 Discussion 23 2nd August 2017 06:21 PM
battery replacement? MOOK03TRMN8R E60 M5 and E61 M5 Touring Discussion 31 6th December 2013 06:42 AM
2008 E60 Battery Issues and "Increased Emissions" brendon4 E60 M5 and E61 M5 Touring Discussion 3 7th March 2013 05:07 PM
Best replacement battery? tomssvx E39 M5 and E52 Z8 Discussion 6 26th January 2011 12:26 PM
'03 M3 Cab Battery Replacement? 2mnycars E90 M3 Sedan, E92 M3 Coupe, E93 M3 Convertible, E46 M3 and E36 M3, Z4 M and Z4 M Coupe 3 1st September 2009 04:25 AM
