DIY - E60 M5 - Reset Brake Pad Sensors Using Tool32 - Page 2 - BMW M5 Forum and M6 Forums
post #11 of 14 Old 6th October 2013, 08:11 PM
montesory
montesory is offline
post #12 of 14 Old 15th June 2016, 06:06 PM
AlehandroM5
Thank you, I was going crazy after testing the sensors (ohms were good) and voltage at the junction box (voltage was good), as well as using the jumper wire to bypass the sensor...Everything was working fine, but my indicator would not reset.
Finally I found this post and realized I screwed things up by reseting the indicator before changing the sensors.
I do not have the tools or software needed to do the reset myself. My question is:
Can I take my car to an indy shop or do I have to take it to the dealership to reset the indicators now? Also, what should I ask them to perform and how much should it cost?
Thanks!
AlehandroM5 is offline
post #13 of 14 Old 24th February 2017, 05:47 AM
IlyaG
Thanks!
I know im grave digging an old Thread, BUT i wanted to clear something up.
Before you start any process mentioned earlier in this thread and then get into a mess and realize that you are not ready to mess with all that please try the following.
THINGS you need.
A PC i5 or better minium 2.2 GHz and 4gb ram
ISTA (ista is now one suite comes with p/d take not that some e60 models will still needs ista p for retro fitting and programming)
Double K line cable much much cheaper
or if you are a "high baller" as the kids say get your self a K+Dcan with switcher, ( keep note that the cable does indeed matter and you need to figure out which one you need based on production year)
Now the simplest way of getting all this is through rheingold, but if you are not ready to spend $200 you can try a few sellers on ebay for a cheaper deal.
NOW lets assume you have all of this.
What you need to do is running the diagnostic tolls find the fault, and test everything,
Long story short you will be resetting the CBS via ISTA and that takes about 5 minutes tops,
Best Regards
To anyone who has been driving around with a big red brake light for the past 6 months :P
-ilya
IlyaG is offline
post #14 of 14 Old 20th May 2019, 03:51 AM
darrikpuetz
Will this just saved my life from annoyance lol. Thank you for your service
darrikpuetz is offline
Are there 2 Front Brake pad wear sensors, on left and right? DLDL E60 M5 and E61 M5 Touring Discussion 8 24th March 2012 07:58 PM
Front brake pad sensor reset silverford1234 E63 BMW M6 Forum and BMW M6 Convertible | m6board.com 5 5th October 2011 08:57 AM
can't reset brake pad warning in 07 M6.. wtf?? jcheun4 E63 BMW M6 Forum and BMW M6 Convertible | m6board.com 2 16th April 2011 01:03 AM
Checking brake pad sensors? Bimmerbear E39 M5 and E52 Z8 Discussion 5 13th January 2009 05:45 PM
I replaced the Brake pad sensors but... MPressed E39 M5 and E52 Z8 Discussion 8 27th June 2008 07:47 PM
