Reduced engine power - BMW M5 Forum and M6 Forums
post #1 of 12 Old 11th June 2013, 06:37 AM Thread Starter
ror600
ror600's Avatar
Hi guys
I am facing an issue with my M5 E60 2007 with 80000 km on it
I am just getting the reduce engine power fault
Once I start my car it runs for 3 seconds only
I need your help
ror600 is offline
post #2 of 12 Old 11th June 2013, 11:19 AM
jut2nv
I have recently had this problem. But i would get a number or errors pop. Engine Fault, DSC and a few others. Vines replaced both Throttle Actuators as well as the alternator seem to have cured the issue.
The work was completed under warranty.
jut2nv is offline
post #3 of 12 Old 11th June 2013, 11:35 AM Thread Starter
ror600
ror600's Avatar
Is not it strange that both throttle actuators got defective at the same time?
ror600 is offline
post #4 of 12 Old 11th June 2013, 11:59 AM
jut2nv
according to the tech both had errors for a while but only one had failed and the other was on the brink of failing. The warranty company replaced both so i can not complain..
jut2nv is offline
post #5 of 12 Old 11th June 2013, 12:26 PM Thread Starter
ror600
ror600's Avatar
What error code did you get for the alternator?
ror600 is offline
post #6 of 12 Old 11th June 2013, 12:30 PM
markie
markie's Avatar
They wear at the same rate so its preventative, as jut2nv had his done under warranty so it wasn't a cost decision . The teeth on the internal cogs wear away, it seems to be one of the weaker areas of the M5. General rule of thumb is that when one goes the other isn't that far behind, there is a excellent thread on here talking around replacing the internals well worth subscribing too.
markie is offline
post #7 of 12 Old 11th June 2013, 12:58 PM
jut2nv
I have no idea what the code was for the alternator, all i did was take it to the garage and they replaced all the parts and now its working a treat
jut2nv is offline
post #8 of 12 Old 11th June 2013, 01:56 PM Thread Starter
ror600
ror600's Avatar
ror600 is offline
post #9 of 12 Old 11th June 2013, 03:39 PM
jcolley
jcolley's Avatar
Ror600, Got your PM, but for the sake of knowledge sharing, will reply here if it's ok.
From the screen shot above, there are several error codes which appear throttle actuator related. However, a couple aren't and would seem voltage related. I can't remember from old PMs, did you have your alternator checked?
jcolley is online now
post #10 of 12 Old 11th June 2013, 03:42 PM Thread Starter
ror600
ror600's Avatar
Yes I did the test from DIS and it is ok
Is there any other way to test?
After clearing the old error codes did not come back but only the siren alarm
The ones on the screen shot are new
ror600 is offline
Engine malfunction! Reduced power Natdad E63 BMW M6 Forum and BMW M6 Convertible | m6board.com 27 26th November 2017 04:33 PM
Engine Malfunction Reduced Power 5K bowtie17 E60 M5 and E61 M5 Touring Discussion 5 23rd May 2013 08:09 AM
M5 clicking and engine power reduced !! help Ma19sa E60 M5 and E61 M5 Touring Discussion 16 28th December 2012 09:16 AM
Engine Malfunction Reduced Power Mbanks2 USA South BMW M Forums 0 8th August 2010 07:34 PM
