Rattle is driving me nuts, please help! - BMW M5 Forum and M6 Forums
 2Likes
post #1 of 24 Old 22nd February 2013, 06:08 PM Thread Starter
Ulyssesd
Ulyssesd's Avatar
Greetings to everyone,
First off, thank you for coming to my post. I have spent the past 2 days looking over previous posts and i cannot find any info that can assist.
I have had my car for just over a year, 2008 M5, 50k miles. For the past 5-6 months i have noticed a rattle only on significant acceleration. The noise has gotten worse, so much that my almost deaf girlfriend was able to hear it (she's not really deaf, she just loves to ignore me). The rattle goes away after i lift and does not return upon cruising at a stead speed. Cannot hear the rattle if my windows are up. Unfortunately I cannot pinpoint where the sound originates, however it seem like its coming directly from underneath the car. Has anyone experienced this? Any insight you can share? Its driving me nuts.
I have tried revving the engine in neutral, but there is no rattle. The sound only comes while i am driving. The car runs absolutely fine, no shakes, no thumps. I am taking the car in on Tuesday for service, while i am there i am going to ask my guy to see if he can determine the issue.
Thank you again for the help, i appreciate any info you can share.
-Ulysses
Ulyssesd is offline
post #2 of 24 Old 22nd February 2013, 06:13 PM
Fiftytwoeighty
Fiftytwoeighty's Avatar
Can you make/take and post a video clip of the offending rattle?
~Woody
///M The ///Most Expensive Letter in the Alphabet
Driving Concepts Competition Racing School
s85 + (afterthought) 6mt =162,000 miles with no RCOD and counting ...just saying...
2007 Dinan S2 e60 m5 6MT Interlagos Blue; DINAN 3.91 Exploded @8x,xxx ; Performance Gearing 3.91 LSD 3 clutch, 30/50 ramps, R&P polished ; ClutchMasters FX350 clutch and LTW single mass FW @157,000 miles, RPi Oil Cooler/Scoops; DINAN High Flow Air Mass Meter/Intake, DINAN TBs, DINAN pulley, DINAN strut, DINAN Monoballs, FastAttack Tune, w/Kung Fu grip!, Einhorn Industries Race Jedders, track pipe, and x-pipe; DINAN Section 3, DINAN LTW 19x9 ET18, 19x10 ET25, Michelin PS4S 275/35/19 and 305/30/19, Macht Schnell 15mm spacers (front); FERODO FRP3000H race pads; StopTech BBK 6/4 380mm/35mm x 380mm/32mm w/SS lines; RDSport F/R sways; MCS 2WNR motorsport coilover, -2.0/-2.5 F/R camber; z3 1.9L SSK, with f10 shifter; F/R G1W-H; Uniden R1, remote ALP 2Rx:1Tx, F/R NetRadar DSP, w/GPS and BT. SprintBooster v3; Euro MDM and DSC off. Fluids: Motul 7100 4T 10w60, Redline ShockProof Lightweight 75w140, Castrol SRF, Unicorn Jizz and Wolfpack Blood; Rod bearings replaced at 84,000 and 150,000 miles!!!
1988 e28 m5 STROKER 420bhp 91 octane(Paul Burke s38b39); VAC LTW flywheel; MegaSquirt G2 DME; Nuke Performance fuel rail and pressure regulator, Carbon Fiber CSL intake; Lifeline Zero 360 FIA 3.0kg Novec fire suppression; Cool Shirt Pro Air/Water system; Euro RestoMod track car: caged, 6 point Schroth FIA harness, FIA Sparco Ergo & Sabelt GT-160 seats...AC/heater, interior, sunroof, rear seat delete; Euro Headers, dump valve, and race cats; CAE Ultra shifter; custom Ground Control Coilovers/camber plates; Mason Engineering front/rear strut bars; Brembo 6/4 BBK; 17x9 BBS Style 42 w/Michelin Cup 2; undergoing Euro restoration, building the e28 CSL ///Motorsport never built. 5.71lbs/hp
Not-spec e30 racercar!!! Fully caged for wheel 2 wheel racing
1996 FZJ 80; LOCKED; Factory TRD Supercharger; Expo/Overland/Backcountry Rig; custom sleeper/drawer system, full rock armor, 33"s on 2.5" OME Heavy Lift; Rigid LEDs F/R; 231,000 miles and counting.
2008 Audi A3 S-Line Quattro w/flappy paddles (Mammoth Mountain Commuter)
2000 e39 m5 TiAg (Gone, but not forgotten) sold 7/2014.
The Indys that I trust for all my Beasts' needs: oceansidemotorsports.com my local physician for service
fastattackmotorsports.com because JColley!
einhornindustires because WolfPack!
~I FRACKING!
~Viva La Wolfpack!
Fiftytwoeighty is online now
post #3 of 24 Old 22nd February 2013, 06:47 PM Thread Starter
Ulyssesd
Ulyssesd's Avatar
there is a tunnel on my way home, i'll take a video and share. You'll be able to get a good feel for the noise.
Ulyssesd is offline
post #4 of 24 Old 22nd February 2013, 09:00 PM
tbrown1985
I have the exact same thing. Between 3k-4k rpm's mostly. Mine's been like that for years. Dealer has heard it and says that a lot of them do it. Really annoying though. Especially if you are driving by a wall or through a tunnel. Sounds like engine ping? That's how I describe it. Usually goes away after about 4.5k rpm. Doesn't do it at idle, only under load, and in 3rd and higher gears. If anyone has a solution, let us know.
tbrown1985 is offline
The Following User Says Thank You to tbrown1985 For This Useful Post:
Ulyssesd (22nd February 2013)
post #5 of 24 Old 22nd February 2013, 09:01 PM
mavster
mavster's Avatar
sounds like a loose trim external, does it get worse as you accelerate, and only starts past a certain speed?
mavster is offline
post #6 of 24 Old 22nd February 2013, 09:04 PM
tbrown1985
Oh. There is a thread on here somewhere, where the noise stopped after clutch replacement. Something to do with slipping clutch changing spark timing.
post #7 of 24 Old 22nd February 2013, 09:13 PM Thread Starter
Ulyssesd
Ulyssesd's Avatar
It gets louder as i accelerate and normally peeks between 3.5k - 5k, after that it goes away. Under normal acceleration and coasting on the highway, i don't hear it. The rattle is very metallic and does seem to come from under the car. I have tried to look for any loose parts, but haven't found anything. I am having the brake fluid changed on Tuesday, i asked my mechanic to see if he can spot anything while the car is on the lift.
Ulyssesd is offline
post #8 of 24 Old 22nd February 2013, 09:25 PM
tbrown1985
post #9 of 24 Old 22nd February 2013, 09:33 PM
rassi
rassi's Avatar
Long shot but... I get a rattle under hard acceleration from what I thought was the right side of the centre console. However, someone suggested that it could be the metal wind breaker from the sun roof (the metal flap that folds down when the roof is closed) and at least in my case it was the problem. Some well-placed window insulation strip cured the vibration.
Anders
'14 BMW M5
ex '13 Audi A6 BiTDI Avant
ex '11 BMW M3 (E92) DCT (Individual Ruby black/Individual oxyd brown extended leather)
ex '11 BMW X3 xDrive 30D (Space grey/saddle brown leather)
ex '11 Mercedes C300 CDI 4Matic Avantgarde (black / beige leather)
ex '08 BMW M5 (Silverstone II / Black merino leather)
ex '08 BMW X3 xDrive 35D (Titan silver / Nevada beige leather)
ex '09 Mercedes C220T CDI Avantgarde (black / black leather)
ex '02 BMW M5 (Carbon black / black leather)
ex '95 BMW 320i Touring (black / black cloth)
ex '01 BMW 530D Touring (Sterling grey / beige leather)
ex '98 Mercedes C43 T AMG (Smaragd schwarz / black leather)
ex '99 BMW M Coupé (Cosmos black/ black-kyalami leather)
ex '93 Alfa Romeo 164 24V Super (Silver / black leather)
rassi is offline
post #10 of 24 Old 22nd February 2013, 09:43 PM Thread Starter
Ulyssesd
Ulyssesd's Avatar
Thanks rassi! i'm not sure if that is culprit, but i'll double check, to be sure.
Ulyssesd is offline
ticking noise driving me nuts apetrov1x5 E39 M5 and E52 Z8 Discussion 12 29th September 2012 12:10 PM
Metallic Noises Driving Me Nuts! Need Opinions... SoCaLE39 E39 M5 and E52 Z8 Discussion 71 11th July 2011 09:32 PM
Dealer Driving me NUTS!!! kosmo E39 M5 and E52 Z8 Discussion 3 5th October 2008 12:08 AM
Creaking window seals driving me nuts bbreneman E39 M5 and E52 Z8 Discussion 24 11th June 2008 11:25 PM
non-lights driving me nuts kcdoyle E39 M5 and E52 Z8 Discussion 25 21st January 2005 07:37 PM
