Who makes the brightest LED angel eye for a E60? - Page 3 - BMW M5 Forum and M6 Forums
 8Likes
post #21 of 73 Old 23rd January 2013, 11:59 PM
ra0507
What do you mean by "240 High output LEDs". That is not a designation I can find. I am assuming that 240 is the lumens. Is the "DD 328" the original bulb in the 08-10?
Thanks.
Richard
ra0507 is offline
post #22 of 73 Old 24th January 2013, 03:43 AM Thread Starter
BMWMenthusiast
BMWMenthusiast's Avatar
Originally Posted by bimma328 View Post
they have the mtec v3 bulbs on ebay, i firsthad the v3 installed on one side and popped the 30watt bulb on the other, i noticed a small difference in brightness the 30watt bulb was stronger, now the 25 watt bulb on ebay i havent tried since the seller told me to try 30watt instead, it had just came out about 1 month ago.
Now as far as quality i will let you know in a few months, i would think the mtec v3 would last longer, thats why im keeping mine and if needs be i will sell them at the end of the coming summer
Would you mind linking me a set of MTEC V3 bulbs on ebay bimma328? I'm not too keen on having to open up the headlight case and change the angel eye rings for some more powerful ones that's a little too extensive and not worth the effort in my opinion but thanks for the suggestion. I'm currently eyeing the 25 watt cree bulbs on ebay, but if these MTEC V3 bulbs are just as good then I will purchase those instead.
BMWMenthusiast is offline
post #23 of 73 Old 24th January 2013, 03:47 AM
EuroCarFan
You only have to open your headlights if you want to use the Orions or change your CCFL rings. The MTECs and the 25W/30W Cree bulbs are all plug and play. It's just a matter of preference....and price. The MTEC V3s are going for $179 on eBay compared to $75 for the 25W Cree (wonder what the 30W Cree bulbs cost?).
2006 M5 Blk/Blk/Alum Fully Loaded
Engine: FAMS Tune | RPI Ceramic Coated Headers + GTS Exhaust w/Gloss Black Tips and Red RPI Logo + Ram Air Scoops + BMC Filters + Block-Off Plates + Pulley + Oil Cooler | Dinan 3.91 Diff | Sprint Booster V2 | Euro SMG LC Tune
Wheels, Susp & Brakes: Neez QD7s 20x9-10 | PSSs | KW V3s | Dinan FRC + Rear Sway Bar + Front & Rear CF Strut Braces | Brembo 380mm BBKs
Exterior: Modified Hartge Splitter | Hartge Diffuser | Vorsteiner CF Trunk Spoiler| Side Skirt Extensions | CF Lower Mirror Covers | CF Side Gills
Interior: RDSport Alum Pedals | Hardwired V1 | BlackVue DR750S-2CH Dash Cams | iPod Integration Kit | BSW Stage 1 Speakers | Earthquakes SWS Subs w/HiFonics Zeus 500W Amp | Flat Bottom Steering Wheel w/CF Trim | AS Designs Red Tachometer
Lighting: LCI Headlights and Taillights Conversion | MTEC V3 AEs | Trinity Autosport Interior LEDs | F10 Style Smoked LED Side Markers
Coded Options: Folding Side Mirrors, Windows and Moonroof w/Remote | Deleted "Accept" Screen | Turn Signals in HUD | Real Speed in OBC Screen | Automatic Heated Seats Controls in iDrive
EuroCarFan is offline
post #24 of 73 Old 24th January 2013, 03:48 AM
EuroCarFan
Oh and here are the eBay listings for the MTEC V3s: bmw mtec v3 e60 | eBay
The Following User Says Thank You to EuroCarFan For This Useful Post:
BMWMenthusiast (24th January 2013)
post #25 of 73 Old 24th January 2013, 03:14 PM Thread Starter
BMWMenthusiast
yea the orion are the best choices, i just dont feel too confortable cutting my headlight open right now, maybe once the temperature warms up, i will take daylight shots this week, i usually get back to work and its already night, i'll keep you guys posted
as for the bulbs they just came out and theyre hard to find, i did locate the manufacturer tho, the seller of these on ebay has the contact
BMW CREE 25WATTS Angel Eye LED White for E39 E53 E60 E61 E63 E64 E65 E66 E87 E53 | eBay
they are bigger then mtec v1,2 or 3 and the passenger one is easy to install but the driver one, you will need to unscrew the 4 bolts holding the headlight and slide the headlight about 3-4 inches to get clearance for your hands
Are these ones above the exact same ones you put in your M5 bimma328? In part of your other comment you mention about the 25 watt and 30 watt so I'm kind of confused as to which one you got and which one you highly recommend to buy 25 watt or 30 watt.
When you say they are hard to find where did you purchase yours? from the above seller? I'm going to process some tonight if you can help me out with my above questions.
Cheers- You have been a massive help to me
post #26 of 73 Old 24th January 2013, 05:30 PM
EuroCarFan
I believe he got the 30W but that listing for the 25W is the only one he found and that seller can get us the 30W or refer us to someone who has them.
I'm looking for a new set as well. I had some 5W ones and one of them burned out so I got a set of 24W bulbs but their connections are very loose. My shop tried bending the prongs and taping them but they're still turning on and off occasionally. Trying to decide if I should go back to the 5Ws, get the MTEC V3 or these 30W ones that bimma is suggesting. Just worried if it's one of those "you get what you paid for" scenario if I go with the cheaper 30W.
Any other vendors carry the MTECs besides for what's on eBay?
post #27 of 73 Old 25th January 2013, 02:20 AM Thread Starter
BMWMenthusiast
It would be good if bimma328 can confirm where I can get the 30 watts???? I want his honest opinion on which one he thinks is better so I can order straight away.
post #28 of 73 Old 25th January 2013, 05:38 AM
bimma328
bimma328's Avatar
Hey BMWMenthuisiat, i found a seller on ebay that had 25watt bulbs but he told me to try the 30watt ones for an extra 10$ i can give you his email if you want, let me know!
E60 ///M5 White on Black oem 166's
Quote Taken from member QuickSilv3r : Stupid to buy an ///M and not drive it, it's like paying a hooker for a hug
bimma328 is offline
The Following User Says Thank You to bimma328 For This Useful Post:
BMWMenthusiast (25th January 2013)
post #29 of 73 Old 25th January 2013, 05:41 AM
bimma328
bimma328's Avatar
a few years ago i tried reselling mtec bulbs and the profit margins were pretty small, so the mtec v3 on ebay are prety much the easiest way of buying these, as for the 30watt bulbs i can give you the email of whom i ordered from, let me know, if i can tomorrow i will take day light shots of the rings
bimma328 is offline
post #30 of 73 Old 25th January 2013, 05:41 AM
EuroCarFan
Can you give me his email as well?
Brightest LCI LED angel eyes upgrade whatheheck E63 BMW M6 Forum and BMW M6 Convertible | m6board.com 11 1st September 2014 11:31 PM
WeissLicht LED Angel Eye V2 for Pre-LCI E60 (V1 vs V2 comparison) [email protected] SW M5 E60 Group Buy Forum and Sponsor Discussion and Offerings 38 7th January 2011 06:57 PM
New Forum Sponor: AngeliBright.com -Brightest Plug&Play, Angel Eye Upgrade on Market AngeliBright.com M5 E39 Group Buy Forum and Sponsor Discussion and Offerings 3 13th March 2007 05:15 PM
New Forum Sponsor: AngeliBright.com -Brightest Plug&Play, Angel Eye Upgrade on Market AngeliBright.com M5 E60 Group Buy Forum and Sponsor Discussion and Offerings 2 13th March 2007 07:57 AM
New Forum Sponor: AngeliBright.com -Brightest Plug&Play, Angel Eye Upgrade on Market AngeliBright.com M6 E63 Group Buy and Sponsor Discussion and Offerings 0 13th March 2007 05:31 AM
