VANOS actual vs. expected positions - BMW M5 Forum and M6 Forums
 1Likes
  • 1 Post By jcolley
post #1 of 7 Old 13th January 2013, 04:28 PM Thread Starter
jcolley
jcolley's Avatar
So, I'm messing around a bit with some datalogging software and noticed that for several (3 of 4) of my VANOS readings, the actual value is a bit off from the expected value.
3169 RPM, 20% Throttle, 3rd gear, 37 MPH
Bank 1
Intake Expected: 150
Intake Actual: 147.3
Exhaust Expected: 131.5
Exhaust Actual: 130.3
Bank 2
Intake Actual: 146.6
Exhaust Actual: 127.6
Does anyone have any idea what an expected delta should be between expected and actual?
jcolley is offline
post #2 of 7 Old 17th January 2013, 03:07 AM
evan 535
That is very interesting, is the expected value coming from the ecu, as a function of what it would expect at that point? If so, then potentially the VANOS is seeing something sometimes that makes it shift the cams in a different amount than normal. Perhaps the expected value is a "best-case" or "ideal" scenario? Very interesting.
evan 535 is offline
post #3 of 7 Old 17th January 2013, 03:52 PM Thread Starter
jcolley
jcolley's Avatar
Yes, the DME actually controls (orders) the VANOS units, so I believe "expected" actually means "ordered."
The only reason I can think that the VANOS can't achieve what was ordered is if a solenoid is not operating properly (ISTA tells me I have 3 drawing high current) or if a VANOS adjustment unit is not moving freely forward and aft.
Hopefully, someone more knowledgeable about vanos (like gjs) will chime in and offer their thoughts.
jcolley is offline
post #4 of 7 Old 18th January 2013, 12:34 AM
RS-MAD
Im sure that you have expected , then you have some tolerance for deviation from what is expected.
When that tolerance is over , then you have CEL.
Your actual is quite close to expected.
If you have around you some BMW equipment you can always make the VANOS test procedure.
RS-MAD is offline
post #5 of 7 Old 18th January 2013, 12:53 AM Thread Starter
jcolley
jcolley's Avatar
I'm reading out the VANOS information using BMW's ISTA/D application. I have performed the VANOS ventilation procedure and then the VANOS test. Attached below are the results of the test. It would be nice if I knew what a perfectly running car looked like
jcolley is offline
The Following 2 Users Say Thank You to jcolley For This Useful Post:
Mover (25th June 2016)
post #6 of 7 Old 25th June 2016, 01:07 AM
Mover
Mover is offline
post #7 of 7 Old 26th June 2016, 06:55 PM
Mover
Originally Posted by Mover View Post
Did you ever get other results to compare yours to ?
Never mind, I found some others to compare to.
Mover is offline
New Seats - Recaro Pole Positions nizmo E39 M5 and E52 Z8 Discussion 59 28th January 2019 03:38 AM
Jlevi SW | Two Sales Positions Still Available [email protected] SW USA West Forum 1 10th December 2010 11:52 PM
Spring positions LJM5 E60 M5 and E61 M5 Touring Discussion 4 21st January 2007 07:33 PM
What is you M5driving positions ? mfettara E39 M5 and E52 Z8 Discussion 10 24th January 2003 02:34 PM
