DIY: auxiliary input E60 - Page 2 - BMW M5 Forum and M6 Forums
 7Likes
post #11 of 39 Old 6th January 2013, 03:09 AM Thread Starter
bimma328
bimma328's Avatar
bimma328 is offline
post #12 of 39 Old 6th January 2013, 03:22 AM
IndyRedBeast
IndyRedBeast's Avatar
Originally Posted by bimma328 View Post
I will pass by no worries ! Want me to make you an aux cable. By the way what's the build date on your m5. Is it pre 03-2007? And your friends build date ?
Thanks man! if you could do this for us we'd love it, my m5 is 2006 but i think my build date 05.
Performance:
Meisterscahft Section 1 Pipes
Meisterschaft Section 2 X-Pipe
Eisenmann-Race Section 3 Cans
Catless Headers
Eurocharged ECU Tune
Evosport Power Pulley
BC-Racing Coilovers
Stoptech SS Brake Lines
Stoptech Street Brake Pads
ATE Super Blue Brake Fluid
M Sprint Booster V2
Simota CF CAI
RPi Scoops
Wheels/Tires:
20" Varrstoen ES1
Hankook V12 Evo's
TMS Spacers
Rolled Fenders
Gloss Black Calipers
M Caliper Decals
Exterior:
Hamann Painted Splitter
Custom Black Extension Lip
Hartge Painted Diffuser
Custom Rear Bumper Grille
Gloss Black Sideskirt Extensions
Gloss Black OEM Grilles
Gloss Black Side Gills
Gloss Black Vinyl Roof
Gloss Black M5 Emblem
Gloss Black/White BMW Roundels
Interior:
Alcantara E-brake/SMG Boots
Alcantara/Perforated Leather Wheel
Alcantara Steering Wheel Trim
Alcantara Full Headliner
CF 3M Di-Noc Trim Wrap
CF Steering Emblem
CF Door Pins
Lighting:
Custom Painted Headlights
Orion V2's/Euro Reflectors
OEM LCI Euro Taillights
V6.1 Bruce Cables
Full LED Interior Lights
LED Clear Side Makers
LED License Plate Lights
LED Reverse Lights
Solaris Invisi-Bulbs
6000k HID Bulbs
SOLD
Mikelll M5
IndyRedBeast is offline
post #13 of 39 Old 6th January 2013, 03:48 AM Thread Starter
bimma328
bimma328's Avatar
bimma328 is offline
post #14 of 39 Old 6th January 2013, 04:43 AM
IndyRedBeast
Ok no prob I will make both. For the euro we won't have any problems.
Ok great! You thinking you might leave this week or next week?
Performance:
Catless Headers
BC-Racing Coilovers
M Sprint Booster V2
Simota CF CAI
RPi Scoops
Wheels/Tires:
20" Varrstoen ES1
Hankook V12 Evo's
TMS Spacers
Rolled Fenders
M Caliper Decals
Exterior:
Interior:
CF Steering Emblem
CF Door Pins
Lighting:
V6.1 Bruce Cables
LED Reverse Lights
6000k HID Bulbs
SOLD
Mikelll M5
post #15 of 39 Old 6th January 2013, 05:01 AM
Smeagol
Smeagol's Avatar
Smeagol is offline
post #16 of 39 Old 6th January 2013, 09:10 AM Thread Starter
bimma328
bimma328's Avatar
bimma328 is offline
post #17 of 39 Old 6th January 2013, 09:11 AM Thread Starter
bimma328
bimma328's Avatar
Originally Posted by Smeagol View Post
Sorry for my ignorance, but isn't there an aux port in the glove compartment?
It's an option on 05-06 m5. It's more common on 07+ models but its also an option.
bimma328 is offline
post #18 of 39 Old 7th January 2013, 03:32 AM
AGM5
AGM5's Avatar
I finally decided to install the aux input in my e60 m5. After some research in the forums and finding out that buying an 80$ cable from the dealer just to remove the little green resistor board got me thinking, Im paying 80$ for a wire that i could be making for under 10$. So total cost for this project was actually around 7$
It's my 2nd DIY post so bare with me im a little bit rusty! I will answer all questions if anything is unclear.
First here is a list of the tools you will need:
Philips screwdriver
Drill with 7/32nd universal drill bit (plastic wood metal)
Electric Tape,
Xacto knife,
Strong glue (gel crazy glue, polyurethane or contact cement)
Welding iron
little bit of elbow grease
Now for the parts:
3.5mm audio female input (stereo very important)
3 female connector pins (tyco)
any audio cable with 3 wires inside(or 2 wires and a ground) about 1.5 to 2 feet in lenght
For the coding part you will need the K+DCAN usb cable and the software INPA with NCSEXPERT loaded into a 32 bit windows laptop.
Step 1: Code the car to make sure you can enable the AUX input before you do all this for nothing!
-Using the software NCSEXPERT you need to find the following module and change the following option:
For CCC systems, with navigation, add $NAUX in VO or module CAPPL : AUX_CONFIG = mounted (default is not_mounted)
For MASK systems 04-06 without navigation, add $NAUX in VO or module MASK : AUX_CONFIG = mounted
As soon as this is coded you should see your idrive screen reboot, once on double check is AUX all the way to the right.
If it is showing then you can build the cable and install it.
Step 2: The Cable
-It's pretty straight forward, you need to weld 3 wires to the 3.5mm female jack and weld the other end to 3 female connector pins.
One of them will be the ground, the other one Left Channel, the other Right Channel. Pics attached.
Step 3: The install location
-You can mount the cable in the glove box on the left side close to the emergency flashlight or you can mount the input under the radio.
-Once you decide the final location you will need to remove the trim where the air vents are. To do this open the passenger front door.
-Using a small prying tool gently pop the cover by starting from the edges and moving toward the middle.
-Once the piece is out, pop the hazard/unlock button and remove the connector.
-On the top left and right corner of the climate control buttons you will see 1 screw in each corner, remove with philips.
-Then gently pull the climate controls towards you, they should come out easily, apply a prying tool for the lower plastic board on each
side and pull towards you.
-Once the panels are out you need to remove 4 screws on the CCC unit (the metal plate under the cd slot) and 2 screws for the mask
unit.
-Pull the radio unit out, then unplug the big radio connector. (pic attached)
-Visually locate the black 12 pin connector (pic attached)
-for the MASK unit you wont find that 12 pin black connector, you can either purchase one from the dealer or connect the pins directly
if you connect the pins directly make sure they are all well insulated so they wont touch each other and short the input.
I attached 2 pics of the connector, one from the front and one from the back
-Before you put the radio back in it's location you will need to test fit the connector (attached pic) and make a whole to make space
for the newly installed input jack.
-Drill a hole where you want to mount the aux input and mount the connector, apply glue, let it dry before you install inside the car.
-Before you close everything, you need to test the system, turn the radio on and connect your smart phone, tablet or computer to the
aux input. Go to youtube and find the left-right audio test video. See if the sound comes out from the left and right speakers. If the
sound is reversed just change the left and right pin on the harness. If everything works reverse the installation and close everything.
Thats it!
Here are the pics!
1-Cable finished
2-Female 3.5mm stereo jack
3- Different type stereo jack
4- Tyco push pin female
5-Connector back view behind radio
6-Black 12 pin connector
7-Front view of 12 pin connector
8-Rear view of plastic board under radio
9-Hole to cut under radio
10- Final result!
Nice write-up.
Are the "3 female connector pins (tyco)" the Tyco MQS 0.5mm P/N: 962885-5?
///M - The most powerful & expensive letter in the alphabet
1 of 123 ANTHRAZIT METALLIC (397) / WALK NAPPA/SCHWARZ (M1SW)
Tuned by BMW Motorsports 4/2001, Bone Stock at 185,000 Miles. 355.78 WHP / 345.33 WTQ
2 facts you might not know: Ducks cannot fly and they nest in trees.
Updates:
BM53 Radio / Gen-13 ULF / OEM Sirius / MK-IV Navigation / Aux input / Intravee II / KCA-410c / KCA-420i / 5th Gen i-Pod Nano / CHA-S634 / Umnitza VXX Angel Eyes / F10 ///M5 Shift Knob /
Schmiedmann Shadow Chrome Grills / Rear Fog Lights
DIY: Retro-Fit Auxiliary Audio Input Harness /// DIY: E39 - BM53 & (BMW) Sirius Radio Retrofit /// DIY: E39 - Replacement of the Left and Right Firewall Covers
For Sale:
BMW Style 5 17" 2 Piece Wheels And Tires
AGM5 is offline
post #19 of 39 Old 7th January 2013, 09:43 PM
tommyleinen
How freaky! I installed my cable in back in Oct as not having this was really peeing me off. It wasn't until last weekend that I did the programming to finish off. I could have done with a guide like yours so was considering posting my method for others (not far off from this). Looks like you saved me the effort and did a thorough job to boot!
My dash looks slightly different to yours - it's a UK '05 2.5l M5 Diesel.
tommyleinen is offline
post #20 of 39 Old 8th January 2013, 12:34 AM
Cool Cat
Great DIY, thanks!
Was just trying to begin doing this, but I am not familiar with NCSEXPERT and I cannot figure out how this works!
Possibly a cable problem as well; I am trying to use a Evolve cable they have send me to program my ECU with their Alpha N tune. Do you know if this cable should work, or a simple way of testing if it is compatible with NCSEXPERT?
A link to some help using it would be great as well, as I can't find anything that helps me.
Cool Cat is offline
Auxiliary Input questions? Majestic E63 BMW M6 Forum and BMW M6 Convertible | m6board.com 8 15th May 2010 04:13 AM
Auxiliary Input Question Boomer E39 M5 and E52 Z8 Discussion 3 12th August 2004 04:24 AM
Auxiliary Audio Input jbetlyon E39 M5 and E52 Z8 Discussion 2 23rd November 2003 02:41 AM
Auxiliary Audio Input jbetlyon E39 M5 and E52 Z8 Discussion 8 5th March 2003 06:16 PM
Auxiliary Audio Input MarcK E39 M5 and E52 Z8 Discussion 3 7th July 2001 02:32 AM
