4fa0 smg code - BMW M5 Forum and M6 Forums
 1Likes
  • 1 Post By Hasan Shaikh
post #1 of 7 Old 19th December 2012, 05:55 AM Thread Starter
Viper966
4fa0 smg code
Got a red cog every time I come to a stop, broke out the gt1 tool and found this code... I had the same symptoms before about 6 months ago and my slave cyl popped, but it was different codes... And I don't see any obvious fluid leak..
Car has been driving fine recently, randomly getting high battery drain warnings though..
Any suggestions? I randomly get the rear end bump from the throw out bearing... Like only once a month if that
Need to order parts to get them here by the weekend so I can get my car back..
Viper966 is offline
post #2 of 7 Old 19th December 2012, 06:07 AM
lumi
lumi is offline
post #3 of 7 Old 19th December 2012, 06:30 AM Thread Starter
Viper966
Battery is less than 6 months old (auto zone direct replacement, never registered to the car)
Car is a 2006 with 104k
Viper966 is offline
post #4 of 7 Old 19th December 2012, 06:30 AM Thread Starter
Viper966
Viper966 is offline
post #5 of 7 Old 19th December 2012, 06:45 AM
lumi
What exactly is the description to the SMG code you pulled? sounds like your getting battery codes/issues. See if autozone has warranty for that battery and try changing it out. I would find someone who can register the battery aswell.
lumi is offline
post #6 of 7 Old 19th December 2012, 07:24 AM
Hasan Shaikh
Hasan Shaikh's Avatar
Looks like your throw out bearing is worn out.
I would suggest you replace and if your clutch and flywheel have not been replaced recently, I would suggest you get it all done in one go.
Good Luck!
Hasan Shaikh is offline
The Following User Says Thank You to Hasan Shaikh For This Useful Post:
MKSixer (19th December 2012)
post #7 of 7 Old 19th December 2012, 02:20 PM
jcolley
jcolley's Avatar
I agree. Plan for the worst, hope for the best. Buy the clutch kit and sundries then wait until you really have to change it.
I was getting the 4FA0 code (position deviation) every single morning for 3 seconds as I warmed up the car. Strange thing is, twice it happened after letting the engine warm up for 5 minutes (it's winter in Maine) as I opened the door and sat down in the driver's seat. I hadn't even touched the SMG stick.
I read the codes in ISTA and ran the Test Program it generated which ran me through the SMG adaptations, etc and the SMG is so much smoother now. I still get an occasional red cog with 4FA0 attached ot it, but it lasts a bout 2 seconds and it's gone. I'm not fooling myself that it fixed all my problems, but maybe now the clutch will go out gracefully and just start slipping like it should and I can get another 4-5k miles out of it.
jcolley is online now
Peak Code: 1b code d4 - Misfire during warm up cyl#8 dmalhi1 E39 M5 and E52 Z8 Discussion 20 19th January 2012 08:23 PM
Recurring Peake code assistance, table 18 code C1 Misfire Cyl 1 Brent_M5 E39 M5 and E52 Z8 Discussion 3 8th November 2011 07:20 PM
Read/decipher ecu code - or - what tuner code am I running ? mkaehly E39 M5 and E52 Z8 Discussion 2 29th January 2011 11:05 AM
NEW PEAK RESEARCH R5 FCX3 CODE READER.......Indicates Incorrect Code Table for E39 M5 (Known Issue). Jim Green E39 M5 and E52 Z8 Discussion 12 10th May 2008 02:14 AM
Peake code error: timeout SMG-CAN (edited) Absinthe E39 M5 and E52 Z8 Discussion 11 8th April 2006 12:11 AM
