Adaptive Headlamps Error - BMW M5 Forum and M6 Forums
post #1 of 4 Old 28th September 2012, 10:29 PM Thread Starter
AngelSlayer
AngelSlayer's Avatar
[FYI - my car is now fine. I am posting this in case someone in the future has a similar issue and can make use of this information.]
I got the Adaptive Headlamps error in my dash display and on idrive a few days back. Usually errors go away after a while leaving the /!\ triangle in the dash display but in this particular case, the error would not go away. Pushing the 'check' button on the stalk removed the message but it would come back immediately after about 5-10 seconds. So basically it was retriggering constantly.
I had someone stand in front of my car when I started it and they saw that both sides were no longer exhibiting the normal movements that are a signature of the adaptive headlight system.
I took it into Sonic and had them check the codes and basically the system could not communicate with either of the ALC adaptive headlamp modules in the car.
After getting home, I took out the ALC modules. They are found under the main headlights (you have to remove your headlight cluster on each side). I unplugged the battery first. The modules are held in by 3 torx screws and plug in under the light. The right side looked fine. The left side was in bad shape. The connector had corrosion and one of the pins was loose.
The BMW master tech at Sonic had told me that he's seen corrosion issues with the ALCs many times on E60s. Any moisture that gets into your headlights (for whatever reason) always makes its way onto the ALC connector because of where the ALC is situated.
So I bought a replacement ALC at my local dealer. The part online costs $120 + shipping:
BMW E60 M5 S85 5.0L > Search > 63127189312 > ES#173012 Control Unit For Adaptive Curve Lighting - Priced Each - 63127189312
The dealer wanted $152 after a 15% BMWCCA discount ($180 normally). I decided to take the local option as online it's a special order item that could take a few days to acquire and I didn't feel very patient.
I popped the new unit into the left side, put the headlights back in, reconnected the battery, and started the car. Both headlights were working fine again and the error was gone from my display. I believe these ALC units need to be coded but I have not had an issue after popping this new unit into the car. Not sure if the coding is only necessary if there's a new revision of the module .. but no coding was necessary for now. I'm going to take the car to Sonic again to have them rerun diagnostics to see if any coding is needed. But so far so good.
Hope this helps anyone running into this issue in the future.
2008 Alpine White BMW M5 ::: SOLD
2010 Carrara White Porsche 911 Turbo ::: Sharkwerks, EVOMS, RSVforged, Cargraphics, Bilstein, IPD, Precision Porsche, Vorsteiner, DCTMS
AngelSlayer is offline
The Following 4 Users Say Thank You to AngelSlayer For This Useful Post:
abyars (30th September 2012), Blendercloud (28th September 2012), PRM5 (29th September 2012), RedRum5 (17th December 2012)
post #2 of 4 Old 15th December 2012, 12:13 AM
e39_415
e39_415's Avatar
Did you have to replace both? or just one of them. Your second to last paragraph says "I popped the new unit into the left side".
I retrofitted my headlights about a year ago to LCI. About couple weeks ago I received left (low beam) malfunction error on my iDrive display, my low beam was out. One day later adaptive headlamps error. So I replaced the bulb and no luck bulb still out. I ended up replacing ballast and ALC on the car. So I fixed the (low beam) error, but now I need to get the new ALC coded.
Did you ever have moisture inside your headlights?
- RH
e39_415 is offline
post #3 of 4 Old 28th March 2019, 11:19 PM
chrishoche
chrishoche's Avatar
How hard is it to replace a e60 M5 headlamp assembly, D1S bulb, control unit and adaptive control unit? Dealership wants $2700+... seems a little excessive.
I put the parts together online and can get them for about half that price it seems...
chrishoche is offline
post #4 of 4 Old 29th March 2019, 02:54 AM
Ferris
Headlights come out quite easily, unlike other bmw's the bumper does NOT need to come off. The headlights ,iirc come as one unit with all the parts you listed.
2001 E36/7 MRoadster
2001 E39 M5
2010 E60 M5
2008 E90 335xi
Ferris is offline
Pulled Front Bumper and now have Adaptive Headlight Error kendall993 E60 M5 and E61 M5 Touring Discussion 12 3rd August 2012 07:14 AM
Adaptive Headlight error. ACG E60 M5 and E61 M5 Touring Discussion 11 23rd February 2012 04:32 PM
FS: US Spec e63 M6 adaptive headlamps RussRamz Parts / Other For Sale or Wanted 0 21st June 2007 09:45 PM
Adaptive Headlamps w8pmc E60 M5 and E61 M5 Touring Discussion 19 24th August 2006 06:15 AM
adaptive headlight error Corey Voss E60 M5 and E61 M5 Touring Discussion 2 3rd January 2006 06:07 PM
