DIY: Replacing throttle actuator motor with pics - BMW M5 Forum and M6 Forums
 13Likes
post #1 of 147 Old 9th May 2012, 09:44 PM Thread Starter
vantaam5
Failing throttle actuators are quite common on the S85,so here is a DIY.
I am NOT liable if you screw up your car or health in any way following this DIY!
It is necessary to carry out initializing of the new throttle motor using DIS or ISTA after the replacement.
First,disconnect battery.
I also removed the micro filters and the panels for easier access to the back of the air boxes(it is possible to remove the vacuum lines without removing the panels,but it is easier when they are removed).
Then remove the air filter boxes(open the clamps on the air filter boxes,disconnect the MAFs and open the clamps of the pipes going into the air boxes)
Then disconnect the hoses on the back sides of the air boxes,the breather hoses on the sides and the hoses for the idle air in the front.
Use a flexible screw driver with a 6mm socket to open the clamps that attach the air boxes to the throttle bodies and remove the air boxes.
Cover butterflies with a cloth to protect debris falling in them.
Remove the bolt in the front and nut in the rear that hold the wiring loom down(tightening torque 10NM)
In the pic above the two vacuum hoses connecting to the air boxes are also visible.
Next is removing the plus wire coming from the jump starting point on bank1 as well as the second plus wire on the terminal(plasitc nut,see pic below,17mm socket,25NM tightening torque) and the cover of the ionic current unit on bank 2(10mm socket,tightening torque 10NM).
Also remove the bolt for the wiring loom(see pic below,10mm socket,tightening torque 10 NM)
Next disconnect the two plugs on the bank2 wiring loom side(mark then to connect the right ones again)
Disconnect also the bank 1 connector
Disconnect the throttle linkage of the actuator you replace(pry gently with a screw driver between linkage and ball pin of actuator) and remove the electrical connector.
The actuator has 3 bolts that attach it to the engine(10mm socket,tightening torque 10NM).
By moving the wiring loom carefully,it is possible to remove the bolts.
It is a bit tricky to remove and install the new actuator as it is very tight between the throttle bodies and the wiring loom.
But being careful,it is possible without breaking anything.
New actuator:
Assemble in opposite order to removing.
I usually leave the air filter boxes and air boxes away when initializing the new actuator.
This way also it is possible to see if everything works.
After everything is done,get yourself a beer and call it a day.
I would estimate it takes about 3-4h for the first timer.
vantaam5 is offline
The Following 13 Users Say Thank You to vantaam5 For This Useful Post:
4braid (19th October 2015), bayerischemotor (1st July 2012), Clyde (10th May 2012), donniesd (4th June 2012), Finnishfan (1st June 2012), Jessem (20th April 2013), Miguex (9th May 2012), Minimization (18th May 2014), petesamprs (10th May 2012), tju317 (10th May 2012), TZ04XJR (9th May 2012), unfoundhorsepower (1st July 2012), whatheheck (16th May 2012)
post #2 of 147 Old 9th May 2012, 09:49 PM
Miguex
Miguex's Avatar
Great! send it to DIY thread.
2015 BMW X6M F86: Custom ECU flashed by ECUPROGRAM.com
" I am more terrified of a suburban mom on her cell phone with 3 kids in the back of the SUV, than an enthusiast who had undertaken specialized training, driving their pride and joy."
Miguex is offline
post #3 of 147 Old 9th May 2012, 10:45 PM
mdyaman
mdyaman's Avatar
+1. Post in DIY thread.
Retired: 2006 e46 ///M3 Silver-Gray SMG (sold)
Current: 2008 e60 DINAN
///M5 Interlagos Blue SMG
DINAN 3.91 Differential, Stage 2 Suspension, Free-flow exhaust, Stage III Software, Front strut braces,
High Flow Air mass meters and intakes, 13% Underdrive pulley, RPI Scoops. 12.5mm TMS Spacers.
mdyaman is offline
post #4 of 147 Old 10th May 2012, 12:04 AM
petesamprs
petesamprs's Avatar
will add. Good DIY (though slightly advanced for the novice).
vantaam5, can you host the pics here rather than imageshack?
Recently sold:
2008 ///M5 | Space Gray | Black perforated leather | Aluminum | SMG
M167 wheels, Rogue Engineering exhaust (Section 3), Eibach springs, 12mm front/rear spacers, matte black grill/side gills/trunk badge, painted calipers (black) with ///M decal, body color reflector, 50% 3M tint, V1 hardwire
petesamprs is offline
post #5 of 147 Old 10th May 2012, 07:01 AM Thread Starter
vantaam5
This is nothing really for the novice,but a bit mechanical inclined owner.
Am changing on the same car also the Vanos high pressure oil pump,write up follows.
Will try to host the pics here.
vantaam5 is offline
post #6 of 147 Old 10th May 2012, 02:38 PM
douglas_ngo
douglas_ngo's Avatar
Thanks. I am looking forward to your writeup for the vanos pump. Mine is still working fine but I went ahead and brought a spare just in case. Hopefully I dont need to buy any special tool when it is time to change mine out.
douglas_ngo is offline
post #7 of 147 Old 1st June 2012, 07:35 AM
abcdkv
Do you need to clear the error data after replacing? The stealer wants to charge me $1,000 for the labor of replacing, I plan to get another merchanic shop to do this for me.
abcdkv is offline
post #8 of 147 Old 1st June 2012, 10:57 AM
Finnishfan
Finnishfan's Avatar
Hmmm, that car looks strangely familiar...
2005 E60 M5. Black/Black. Work in progress. So far: H&R springs, CF emblems, kidneys and side gills. AC Schnitzer rear spoiler. Eisenmann Sport mufflers, secondary cats and resonator removed. Tinted windows. Angelibrights.
Ex 2000 E39 M5. Le Mans Blue/Black.
Driveability: KW Variante 3 coilovers, AC Schnitzer Sway Bars, Weicher strut bar. Rogue Engineering SSK, TCD sway bar brackets. Powerflex bushings
Sound: Inside: Infinity Subwoofer/JBL amplifier. Outside: Kellener SuperSound exhaust, SuperSprint X-pipe
Looks: Facelift, G-Power front flippers, Black Kidneys, M-pedals, AngelIBrights 3.0, 19" Dotz Mugello wheels
Finnishfan is offline
post #9 of 147 Old 1st July 2012, 04:16 PM
Fuddy
Fuddy's Avatar
Fuddy is offline
post #10 of 147 Old 1st July 2012, 05:58 PM
unfoundhorsepower
unfoundhorsepower's Avatar
Originally Posted by Fuddy View Post
how do you initialize the actuator after install?
Marking Pen...
See you all at the:
Mmmmm meet...in Massachusetts, It was good to see all of you !!
unfoundhorsepower is offline
Throttle Actuator Tendencies? eve-slow E60 M5 and E61 M5 Touring Discussion 60 15th July 2014 01:04 PM
fuel and throttle actuator kyu79 E60 M5 and E61 M5 Touring Discussion 3 5th March 2012 02:56 PM
E39 Want to buy: Throttle actuator sproule905 Parts / Other For Sale or Wanted 2 18th January 2012 07:18 PM
throttle actuator advice sdc77 E60 M5 and E61 M5 Touring Discussion 3 26th October 2011 12:43 AM
E39 For Sale: FS: E39 M5 Throttle Actuator mmzcee Parts / Other For Sale or Wanted 1 16th May 2011 07:51 AM
