fuel and throttle actuator - BMW M5 Forum and M6 Forums
post #1 of 4 Old 5th March 2012, 05:56 AM Thread Starter
kyu79
Hi, this is first time I write here, although I've been around to get useful infos. My question is, does anyone know whether the fuel that we use can affect the throttle actuator to throw out a fault? I use 95-98 Octane petrol here in New Zealand, but somehow since I changed from Shell to BP, my car began to throw out a fault code relating to the throttle actuator bank 2. The fault resets by itself but it also very depends on the outside temperature. I would like to hear some opinions before I replace the actual throttle actuator. I wondered if it is the actuator itself is at fault, then why is the fault not always there but on/off irregularly. My mechanic told me that it could be either carbon deposit inside the actuator so one of two sensors inside the actuator is throwing out a fault, or a poor plug connection (less possibility). I've replaced the battery to see if it works but no luck with it. Any opinions? Many thanks in advance.
kyu79 is offline
post #2 of 4 Old 5th March 2012, 02:36 PM
Hasan Shaikh
Hasan Shaikh's Avatar
It can be anything. But I would be really surprised if its the difference in fuel unless the fuel at one of the places is really dirty.
Hasan Shaikh is offline
post #3 of 4 Old 5th March 2012, 02:41 PM Thread Starter
kyu79
thanks for reply,, do you know anything on our car, can throw out throttle actuator fault other than the actuator itself? anyone fixed the fault by ECU flash?
kyu79 is offline
post #4 of 4 Old 5th March 2012, 02:56 PM
Hasan Shaikh
If you are running the stock tune then it cannot be caused by the ECU. In addition, I do not believe that the ECU flash will help in any way. It might make it worse though.
Its either a faulty sensor or a bad actuator. I would replace the parts on both banks if I had to change any.
Throttle Actuator Tendencies? eve-slow E60 M5 and E61 M5 Touring Discussion 60 15th July 2014 01:04 PM
Just had my throttle actuator replaced and wow furry E39 M5 and E52 Z8 Discussion 8 31st January 2012 01:36 PM
E39 Want to buy: Throttle actuator sproule905 Parts / Other For Sale or Wanted 2 18th January 2012 07:18 PM
throttle actuator advice sdc77 E60 M5 and E61 M5 Touring Discussion 3 26th October 2011 12:43 AM
E39 For Sale: FS: E39 M5 Throttle Actuator mmzcee Parts / Other For Sale or Wanted 1 16th May 2011 07:51 AM
