Oil leak right front end - Page 2 - BMW M5 Forum and M6 Forums
post #11 of 17 Old 25th January 2014, 05:28 AM
Griffin
Griffin's Avatar
Griffin is offline
post #12 of 17 Old 10th February 2014, 03:59 PM
yachtgoat
Exact same here as well! Strut fluid?
Anyone else had this issue? I have only just discovered the problem, but feel i could spend a bunch of time and learn nothing!
yachtgoat is offline
post #13 of 17 Old 11th February 2014, 03:12 PM
335xi
I had what I thought was an oil leak. Saw a little puddle right behind the bumper/right front wheel. Took the plastic cover off. Nothing. I think it was puddled water that had accumulated in there, mixed with the gunk/oil/crud that was in there and then leaked out at some point. I had a small fist sized hole in the plastic cover, probably from hitting something.
335xi is online now
post #14 of 17 Old 29th April 2017, 11:13 PM
DavidJWaters63
David W
I have a BMW M5 2013 that appears to have an engine oil problem. Since buying the car six months ago, just outside warranty, 31k miles, i have replaced two lots of Oxygen/lambda sensors, removed catalytic converter errors, replaced four injectors, and constantly watch blue smoke bellowing out of the silencers.
BMW want to remove and rebuild the engine to find the fault for £5k - no surpise there! and reckon the bill could approach £12k.
There appear to be lots of online postings regarding excessive engine oil use - can anybody provide any guidance on whether this is my only route forward.
BMW have washed there hands of the problem - the BMW careline basically dont care. Any possible advice greatly appreciated.
David
DavidJWaters63 is offline
post #15 of 17 Old 4th September 2017, 12:00 AM
mubarak
mubarak's Avatar
Old threats
I have the same issue now on my e63 m6
Small paddle of oil ,,power steering ,,water,, I do now know.
It is under the front passenger tire.( rights side).
I smell it ,,smell like oil.
I do not know.
Any help.
Thank you.
mubarak is online now
post #16 of 17 Old 5th September 2017, 09:48 AM
mubarak
mubarak's Avatar
Updates...it was the front shocks..I changed both fronts left and right.
Car was feeling jumpy in the roads.
Thank you
post #17 of 17 Old 5th September 2017, 11:36 AM
Awbimmer
I have the same issue but itís not red oil. Also, it doesn't leak if parked on a flat road. I was parked at my friend's last week, nose down, and when I left he called to say there seems to be a leak from the underneath, towards the front. When I had the car on the ramp few weeks before, I noticed some old gunk/grime/dirt oil coming from behind the front centre jacking point (e63 m6). I did have my rod bearings done about 1800 miles ago so Iím hoping if anything itís a simple gasket or something.
Booked in for Tuesday next week with my indy to have it checked out.
Awbimmer is offline
Oil Leak - Replace upper/lower oil pan & solenoids?? duc748_2003 E39 M5 and E52 Z8 Discussion 14 7th August 2014 06:38 PM
Took off my front skid plate to install a new oil pan (oil consumption or oil leak...?!) blks4 E39 M5 and E52 Z8 Discussion 7 19th August 2011 10:34 AM
Front end push and rear end slide Perrodulce E39 M5 and E52 Z8 Discussion 22 4th December 2009 01:47 AM
Front Cover Parts List -- Massive Oil Leak ilovemy_e34 E34 M5 Discussion 0 29th October 2006 08:03 PM
Oil Leak from front of engine under head scotta1 E28 M5 Discussion 9 7th January 2002 06:35 AM
