e60 M5 Spark Plug & Air Filter DIY w/ Pics (Good Resource for DIY-ers) - Page 7 - BMW M5 Forum and M6 Forums
 17Likes
post #61 of 85 Old 26th September 2014, 06:10 PM
gride
gride's Avatar
Originally Posted by BigZachE60 View Post
When I took mine in for the last oil change, my tech told me that the spark plugs were at 21% life remaining. I would assume that would need to be reset? Or will resetting the service reminder change that?
Did you recently change your spark plugs?
gride is offline
post #62 of 85 Old 27th September 2014, 01:42 PM
BigZachE60
BigZachE60 is offline
post #63 of 85 Old 11th October 2014, 06:39 AM
Braheem24
Braheem24 is offline
post #64 of 85 Old 12th October 2014, 02:26 PM
M5_SNOW
M5_SNOW's Avatar
M5_SNOW is offline
post #65 of 85 Old 24th February 2015, 05:22 PM
SMGenius
Threads like this are useless when they link to dead websites. Why didn't someone copy the text and pictures over to this site?
SMGenius is offline
post #66 of 85 Old 24th February 2015, 06:04 PM
paulclaude
paulclaude's Avatar
Guys, here is an active link/guide;
DIY: BMW E60 M5 Spark Plug Replacement - Cuccaro Garage
-2005 Euro E60 ///M5 Silverstone II-
Macht Schnell Pulleys - Pipercross Panel Filters - Concept One CSL 19x9.0/19x10.5 - Michelin PSS - BC Coilovers - RD Sport ARB's - PB 380mm 8-Pot Brakes - Pagid RS29 Pads - Supersprint F1 Race - BrenTuning Remap - WPC Big End Bearings
-2005 Euro E46 ///M3 Silver-Grey SMG-
PB 380 8-pot brakes - KW V3 Coilovers - Stripped rear/Corbeau Bucket Seats - Scorpion Exhaust - Rogue Pulleys - Apex Arc-8 18x9.5" +22 Square setup - Turner Motorsport ARB's - Powerflex Bushes - GC Camber Top mounts / Rogue RSM's
paulclaude is offline
post #67 of 85 Old 27th May 2015, 05:17 PM
mattcon
I just want to point out that on the plates that cover the coils the little rubber things on the top and the bottom are not clips that should be poked at in any way. They are simply little rubber feet probably to make sure the covers don't touch the side of the engine and rattle. These are only held on by two rubber gaskets that pop onto posts protruding from the engine and they just pull off. If you poke at these little rubber things on the top and bottom you will probably cause them to fall off. If you have have done this and here a rattle under the hood I would check these plates.
Edit: I'm referencing the DIY in the link posted by paulclaude which is the same DIY I used which is very good otherwise especially with description on plugs 5 and 10.
mattcon is offline
post #68 of 85 Old 3rd December 2015, 07:41 PM
Redleg9
Redleg9's Avatar
Having trouble removing coils #5 and #10? Try this method. The coils pops out damage free. I know everyone has their own way of doing things, but this worked for me without special tools, busted knuckles, broken coils, or massive frustrations.
The picture shows a 10mm bolt head screwed into the passenger bulkhead (same location on driver side).
After you remove the connector, insert a long flat-tipped screwdriver through the clip's cap until it reaches the hex head.
Place the flat tip on the bolt flange (or hex head) and apply firm pressure as you pull up on the screwdriver's handle. Pull towards you at an angle, not straight up (assuming you are standing next to the car).
Redleg9 is offline
post #69 of 85 Old 26th June 2016, 04:17 PM
rt7085
rt7085's Avatar
rt7085 is offline
post #70 of 85 Old 27th December 2016, 07:44 PM
DRMCEO
DRMCEO is offline
DIY Spark Plugs, as requested. (Pics inside) rdm190 E39 M5 and E52 Z8 Discussion 134 14th September 2016 04:03 AM
Kmoy's DIY $5 OEM Hella Remote Angel Eyes DIY (Lots of Pics) Kmoy2002 E39 M5 and E52 Z8 Discussion 36 13th February 2015 06:24 PM
Bay Area DIY'ers Tortuga E39 M5 and E52 Z8 Discussion 2 12th April 2007 05:42 AM
Are Spark Plugs a DIY? 00M5MD E39 M5 and E52 Z8 Discussion 11 19th September 2006 05:11 AM
Okay DIY'ers: what OBD-II and/or reset tool do you recommend? Teutonaddict E39 M5 and E52 Z8 Discussion 9 15th February 2005 12:41 AM
