e60 M5 Spark Plug & Air Filter DIY w/ Pics (Good Resource for DIY-ers) - Page 6 - BMW M5 Forum and M6 Forums
 17Likes
post #51 of 85 Old 4th February 2013, 01:11 AM
Tim_Mc
Just knocked this out. Been fretting a bit over the coil stick and access.
Using the fulcrum approach and being cautious...no issues other than three grommets (minor ones), one hose clip and three gashes in my digits.
Overall quite successful...nice saving that kind of money for typical maintenance. 30K change interval is a good plan-fresh plugs only helps the engine maintain what its got and minimizes other issues (cats, fuel mileage, driveability, etc)
Thanks for posting all the instructions/images-worked like a champ!
Tim_Mc is offline
post #52 of 85 Old 4th February 2013, 11:44 AM
letitlose
letitlose's Avatar
letitlose is offline
post #53 of 85 Old 30th May 2013, 06:17 AM
5soko
5soko's Avatar
1.) Do the plugs come pre gapped? Can install straight out the box?
2.) Anyone confirm nothing has to be reset when changing to new plugs?
5soko is offline
post #54 of 85 Old 30th May 2013, 06:21 AM
5soko
5soko's Avatar
Originally Posted by jcolley View Post
So, looking through TIS, I don't see anything specific, but there is a comment in the Complete Vehicle PDF that mentions the importance of following the service directions when replacing plugs.
"The information provided in the repair instructions must be followed precisely when replacing the spark plugs as the spark plugs are an integral part of the ionic current measuring circuit."
Is there anything that should be done after replacing plugs for Ionic Current module to calibrate properly to the new plugs? I've never heard this mentioned before, just curious.
Sort of like the General Info buried in TIS that tells you to change the transmission fluid and clean the filter with every other oil change or something like that...
Been trying to find an official answer to this but it seems like the answer is no.
5soko is offline
post #55 of 85 Old 30th May 2013, 06:51 AM
tdonnell
I do not think anything needs to be reset when you replace plugs. There isn't a spark plug service interval listed under the iDrive menu like there was on my old 530i.
When I replaced them 4,000 miles ago I never reset anything and still have no issues...
I did feel a slight gain in torque when I replaced the plugs though. I think the worn out plugs were detecting false knock due to their condition, resulting in less aggressive timing and therefore less power/torque.
tdonnell is offline
post #56 of 85 Old 30th May 2013, 07:08 AM
kaa
kaa's Avatar
The only thing that needs to be reset is the spark plugs maintenance reminder. No need to do anything else!
kaa is offline
post #57 of 85 Old 30th May 2013, 05:08 PM
5soko
5soko's Avatar
Good to know, any info on if the plugs have to be gapped, or they come pre gapped I assume?
5soko is offline
post #58 of 85 Old 30th May 2013, 05:26 PM
kaa
kaa's Avatar
kaa is offline
post #59 of 85 Old 3rd November 2013, 07:52 PM
suprolla
suprolla's Avatar
Spark plugs come pre-gapped to 0.020". I measured my old plugs and they were reading 0.025" but otherwise looked in good condition. I see no reason why these can't be reused with a proper re-gapping. I will try it out at my next change out in 37000miles.
Couple of hints after performing this procedure:
- get yourself a knuckle-joint for the extension
- when pulling up the coil, try twisting it as well
- add some dielectric grease to the tip of the coil and where it seats on the valve cover and it won't be as hard to come out next time.
I did have a coil break on cyl 5 when the retaining clip broke and ended up giving me a misfire. So I had to purchase one online (about $60) and It took me about 15 mins to complete the swap from a completely assembled system. I do have the Dinan intakes so that may have been a factor too.
2007 Black Sapphire, Sepang interior, all options except ventilated seats.
Dinan Exhaust, Agency Power Cat Headers, ESS VT2, H&R springs, StopTech BBK
20" BBS CH-R, 295/30/20 PSS on rear
V1 hardwired, BMWCCA Member# 444949
suprolla is offline
post #60 of 85 Old 26th September 2014, 02:02 PM
BigZachE60
When I took mine in for the last oil change, my tech told me that the spark plugs were at 21% life remaining. I would assume that would need to be reset? Or will resetting the service reminder change that?
BigZachE60 is offline
DIY Spark Plugs, as requested. (Pics inside) rdm190 E39 M5 and E52 Z8 Discussion 134 14th September 2016 04:03 AM
Kmoy's DIY $5 OEM Hella Remote Angel Eyes DIY (Lots of Pics) Kmoy2002 E39 M5 and E52 Z8 Discussion 36 13th February 2015 06:24 PM
Bay Area DIY'ers Tortuga E39 M5 and E52 Z8 Discussion 2 12th April 2007 05:42 AM
Are Spark Plugs a DIY? 00M5MD E39 M5 and E52 Z8 Discussion 11 19th September 2006 05:11 AM
Okay DIY'ers: what OBD-II and/or reset tool do you recommend? Teutonaddict E39 M5 and E52 Z8 Discussion 9 15th February 2005 12:41 AM
