e60 M5 Spark Plug & Air Filter DIY w/ Pics (Good Resource for DIY-ers) - Page 4 - BMW M5 Forum and M6 Forums
 17Likes
post #31 of 85 Old 17th October 2012, 08:52 PM
E61M5
Bear in mind this was a RHD car so the configuration of the engine compatment is different. I removed the entire pollen filter tray assembly but it didn't really improve access, just visibility.
E61M5 is offline
post #32 of 85 Old 18th October 2012, 03:12 PM
jcolley
jcolley's Avatar
So, looking through TIS, I don't see anything specific, but there is a comment in the Complete Vehicle PDF that mentions the importance of following the service directions when replacing plugs.
"The information provided in the repair instructions must be followed precisely when replacing the spark plugs as the spark plugs are an integral part of the ionic current measuring circuit."
Is there anything that should be done after replacing plugs for Ionic Current module to calibrate properly to the new plugs? I've never heard this mentioned before, just curious.
Sort of like the General Info buried in TIS that tells you to change the transmission fluid and clean the filter with every other oil change or something like that...
jcolley is offline
post #33 of 85 Old 18th October 2012, 03:47 PM
E61M5
Can't see anything special in the TIS BMW TIS - 12 12 011 Replacing all spark plugs (S85) expect the tightening torque of 23 Nm (less than the 22 ft lbs quoted in the DIY) and to install them dry.
E61M5 is offline
post #34 of 85 Old 19th October 2012, 01:22 AM
kaa
kaa's Avatar
I changed my plugs a few months ago and didnt need any special tool. And after all i did was to reset the maintenance reminder and showed 60kkm for spark plugs. And yes it makes a difference in mpg.
kaa is offline
post #35 of 85 Old 19th October 2012, 08:49 AM
SR71
SR71's Avatar
What great write ups! Cheers to the OP; i'd buy you a beer if I could. Haha
The e60 M5:
"It is an idiosyncratic, hyperactive, twitchy, pent up bull in a china shop. It takes attention to drive it, whether you are trying to drive smoothly or hard."
When the E60 came out, it blew away supercars..... When the F10 comes out, it will be middle of the pack even in a straight line.
-T Bone
SR71 is offline
post #36 of 85 Old 13th November 2012, 04:45 PM
ModestHT
Okay, so I just finished with changing oil and installing new spark plugs. Thanks for the detailed summary and pictures. It made the process so much easier. Here are a few things I learned while doing the job. It took me about 6 hours start to finish with a prolonged lunch in between. Nothing overly difficult about the job just a little time consuming as you have to remove a bunch of crap just to get at the plugs. It's also a great time to clean many of these parts including the engine block. The hardest part as everyone will attest is getting the coil packs removed from the #5 and #10 cylinders. Here's how I managed it.
I cut a scrap piece of 1 x 4 stock lumber down to 1 x 2.5 to use as my fulcrum. I layed it perpendicular to the #4 and #9 cylinders and used a 9" + 6" extension for leverage. They both popped out with some force; in fact, it was easier than pulling the others by hand with my 6" extension. I used this technique for the #4 and #9 cylinders as well.
Now, how to remove and install the new plugs back in the #5 and #10 cylinders. I used a 3" + 3" extension. I first put the spark plug in the 5/8" spark plug extension plus the 3" extension. I put the spark plug and 3" extension into the cylinder head without dropping it in all the way. I simply held it with one hand keeping just the 3" extension connection above the cylinder head while adding the other 3" extension with the other hand. That way I didn't need to "fish" for it with my other 3" extension. From there I added my ratchet and either removed or installed the plugs.
Also, when re-installing the coil packs you should hear a "pop". It takes some force to seat the coil pack onto the new plug and you'll hear a "pop" when this occurs. Thanks again for taking the time to write up your summary with pictures. It saved me about $400-$500 in labor.
ModestHT is offline
post #37 of 85 Old 17th November 2012, 02:35 AM
5.7 silver bullet
5.7 silver bullet's Avatar
My Number 5 clip broke off? Any sugestion? Also notice I have chrome Valve covers, Wish I could see them>>>Thanks for this help on this thread I just wish Number 5 clip would not have broken off, Now I have a Problem But I will wait to try something untill I order a new coil. And then get out the Dyson to suck it out!!!
Name:	My M5 spark plug change.jpg
ID:	168114   Click image for larger version
Name:	My M5 spark plugs.jpg
Dinan Everything, 13% Underdrive pulley,High Flow Middle Racing Exhaust with 4" Resonators, Free Flow Exhaust (E60) M5 full cat delete manifolds, High Flow Air Mass Meter/ Intake Assemblies, High Flow large Throttle Bodies, Stage 3 Engine Software, Replacement Filter for High Flow Air Mass Meter/Intake Assemblies, 3.91 Limited Slip Differential, Dinan Carbon Fiber Front Strut Tower Brace, Dinan Carbon Fiber Rear Shock Tower Brace, Dinan Stage 3 Suspension System (E60) M5, Dinan Lower Control Arm Monoball Racing Kit M5/M6, DinanHigh Performance 5.7 Liter V-10 Engine, Euro SMG upgrade 4k launch, LIQUI MOLY 10W-60 Motor Oil, Wix 57694 Oil filter. Special Thanks All the great forum members.
20" BBS RS-GT Wheels,20" Michelin PS2,Tinted Windows, Carbon Fiber Steering Wheel, Billet Aluminum Parking Brake Handle, Aluminum Pedal set, BMW Factory iPod Adaptor, Custom installed Escort Radar/jammer System, LED Interior lighting, Angel Eyes light Upgrade, LED Side Markers Clear, Sprint Booster Throttle.
Brembo 4 Wheel Big Brake Kit, 2010 LCI Euro Tail lights, Apex EC-7 18x10.5 wheels Hoosier 315-30-18 Drag Radials.
Best 1/4 E.T 11.74 Best MPH 123.86 - 60' 1.69 11/18/12
5.7 silver bullet is offline
post #38 of 85 Old 17th November 2012, 02:56 AM
tdonnell
You could try to plug the harness into the coil, put the clip over it to lock the harness in and then zip-tie the clip to the coil. Otherwise a new coil comes with the clip. They run about $75-85 at the dealer..
tdonnell is offline
post #39 of 85 Old 17th November 2012, 06:16 AM
5.7 silver bullet
My problem is getting it out now?? I will just wait till I can get a new coil and have it ready if I break this one trying to get it Out!! You can see in the picture the lower ear on the white top of the coil is broken off!! I will say some of the coils came out easyer and others were like trying to suck start a Harley Davidson. Be very careful when pulling and prying on the clip you do not want this to happen...
Name:	#5 coil broken.jpg
post #40 of 85 Old 17th November 2012, 04:39 PM
ModestHT
Dang, that doesn't look like fun. That's something that generally happens to me. I'm glad you decided to just get a new coil pack.
ModestHT is offline
DIY Spark Plugs, as requested. (Pics inside) rdm190 E39 M5 and E52 Z8 Discussion 134 14th September 2016 04:03 AM
Kmoy's DIY $5 OEM Hella Remote Angel Eyes DIY (Lots of Pics) Kmoy2002 E39 M5 and E52 Z8 Discussion 36 13th February 2015 06:24 PM
Bay Area DIY'ers Tortuga E39 M5 and E52 Z8 Discussion 2 12th April 2007 05:42 AM
Are Spark Plugs a DIY? 00M5MD E39 M5 and E52 Z8 Discussion 11 19th September 2006 05:11 AM
Okay DIY'ers: what OBD-II and/or reset tool do you recommend? Teutonaddict E39 M5 and E52 Z8 Discussion 9 15th February 2005 12:41 AM
