e60 M5 Spark Plug & Air Filter DIY w/ Pics (Good Resource for DIY-ers) - Page 3 - BMW M5 Forum and M6 Forums
 17Likes
post #21 of 85 Old 7th June 2012, 05:25 PM Thread Starter
mdyaman
mdyaman's Avatar
Originally Posted by DFrankm5 View Post
Mdyaman
I don't believe the coils need to be replaced when you do the spark plugs unless a coil is not performing, defective or broken. OKD makes a higher performing coil for our M's but they are $2,500-$2,800 for a set.
good to know - and yikes on OKD costs
Retired: 2006 e46 ///M3 Silver-Gray SMG (sold)
Current: 2008 e60 DINAN
///M5 Interlagos Blue SMG
DINAN 3.91 Differential, Stage 2 Suspension, Free-flow exhaust, Stage III Software, Front strut braces,
High Flow Air mass meters and intakes, 13% Underdrive pulley, RPI Scoops. 12.5mm TMS Spacers.
mdyaman is offline
post #22 of 85 Old 9th June 2012, 07:56 AM
kaa
kaa's Avatar
Originally Posted by mdyaman View Post
So you bought new coil packs as well?
Do you need to replace the coil packs when installing new spark plugs or can you leave the old ones in there?
No need to change your coils. Unless you break one or one not functioning properly. I didn't change the coils. One more thing I noticed after changing the spark plugs is the gas consumption is way better. I don't know if its my imagination but, the best I could do with a full tank of gas (in the city) was only 230-240km. After I changed the spark plugs I filled up and I just past 220km and I still have a quarter of tank left. mm....!!
kaa is offline
post #23 of 85 Old 9th June 2012, 02:21 PM Thread Starter
mdyaman
mdyaman's Avatar
Thanks! Good to know.
mdyaman is offline
post #24 of 85 Old 9th June 2012, 04:21 PM
latinskllz
latinskllz's Avatar
Same experience for me. Only miles per gallon!
latinskllz is offline
post #25 of 85 Old 23rd August 2012, 07:10 PM
tdonnell
I'm currently in the process of changing the plugs now and improvised a new strategy to remove the rear-most coil packs. Also, I received a tip from a BMW Service Manager: Pull a rag through the clips and pull on it instead of using a socket extension. It makes sense because an extension would put all of the load on a single pin-pointed area on the clip - increasing the chance of breaking it. Well that strategy worked great until I got to the final two and I simply couldn't pull straight up on the coils due to their location, so I devised a plan.
Take the coils out of the cylinders just in front of the last two.
Install a spark plug socket with extensions onto the plugs in those cylinders, the goal here is to have about 2" of extension protruding out of the valve cover.
Pull a rag through the coil clip and apply some force with it by pulling once it's looped.
Put together a length of socket extensions roughly 18" long, make sure you use a 3/8" extension to go through the clip as it's the closest fit to the hole in the clip and will most evenly load the curved section of the clip.
While pulling on the rag, use the length of extension through the clip and push down on the extensions protruding from the next cylinders spark plug bore. This acts as a fulcrum to add force and give you the "straight upwards" pulling force.
Make sure to put the rag between the extensions and the clip as this will further distribute the load the extensions will be placing on the clip.
Here are a couple of photos so you guys can better understand what I mean as I'm sure the above could confuse people:
I struggled for about 10 minutes on the drivers side rear coil and nearly gave myself a hernia trying to pull it out before I thought up this strategy. After doing this it popped right out! Best part is it applies load to the thickest part of the head instead of to the valve cover directly as I'm sure the cover is thin aluminum.
Hope this info helps save you all some stress when performing this maintenance
tdonnell is offline
The Following 2 Users Say Thank You to tdonnell For This Useful Post:
mdyaman (23rd August 2012), screech (19th September 2012)
post #26 of 85 Old 23rd August 2012, 07:33 PM
BADBOY'S M5
BADBOY'S M5's Avatar
Very helpful, Thank you.
E60 BMW ///M5 |Silverstone II on Black Full Leather-Suede Anthracite Alcantara roofliner
|Matt Black Grills|Blk-Carbon Fiber Badges|RPI Ram Air Scoops|Block off Plates|High Performance BMC Filters|Charcoal Filters Removed|RPi ST Pulley Kit |LED plate lights|Interior LED conversion|CODED|Tints 35%|Smoked tail lights|12mm H&R Spacers|H&R lowering Springs|Eurocharged|Sprint-Booster V2|BLK Side Skirt Diffuser's| Gloss Blk Roof wrap|Hamman Front Lip|///M Logo Door Flood lights|
___________________________
2006 E60 BMW ///M5 Current
2008 E70 BMW X5 4.8i Sport Premium Tech PKG Current
2007 BMW E83 X3 ///M package Current
2001 E46 BMW 330ci /Mpkg daily/winter car-retired
2000 BMW E39 540i Modded-retired
1990 BMW E34 535i Racing Dynamics Modded-retired
BADBOY'S M5 is offline
post #27 of 85 Old 23rd August 2012, 08:25 PM
kaa
kaa's Avatar
kaa is offline
post #28 of 85 Old 23rd August 2012, 10:13 PM
tdonnell
Not a problem guys, that is what the Board is for! I'm just glad I was able to contribute...
And another quick FYI, torque specs for the plugs are right on the boxes for them. Its 23 Nm, which equates to 17 lb/ft. The info in the DIY says 22 lb/ft, that's way too much!
tdonnell is offline
The Following User Says Thank You to tdonnell For This Useful Post:
Edmundogonc (22nd December 2018)
post #29 of 85 Old 17th October 2012, 02:26 PM
E61M5
Just did my plugs yesterday on a RHD car. To get the rear-most coils out I used a small block of wood (maybe 0.5 by 0.75 by 1.5 inches) stood on end against the cylinder head cover and used that as the fulcrum with a 12" extension as a lever. The coils popped out quite easily. I was able to get at the left rear plug by moving the ECU harness slightly and then I was able to use 2 extensions coupled with a universal joint. Space for the right one is tighter still so I used a 3/8s drive spark plug socket connected to a 3/8s universal joint connected to a 3/8s to 1/4 adapter connected to a 1/4 extension connected to a 1/4 inch universal joint connected to a 1/4 inch ratchet. All easy peasy lemon squeezy.
A tiny bit of rubber lube on the inside of the "top hats" on the coils helped them pop in very positively. Engine definitely runs smoother when cold - curious if the MPG climbs at all.
E61M5 is offline
post #30 of 85 Old 17th October 2012, 07:59 PM
kaa
kaa's Avatar
Didnt need all those extentions. All u had to do was to remove the internal air filter assembly under the windshield and that gives u access to the last two spark plugs. Remember its german engineering. They always leave simple solution!!
kaa is offline
DIY Spark Plugs, as requested. (Pics inside) rdm190 E39 M5 and E52 Z8 Discussion 134 14th September 2016 04:03 AM
Kmoy's DIY $5 OEM Hella Remote Angel Eyes DIY (Lots of Pics) Kmoy2002 E39 M5 and E52 Z8 Discussion 36 13th February 2015 06:24 PM
Bay Area DIY'ers Tortuga E39 M5 and E52 Z8 Discussion 2 12th April 2007 05:42 AM
Are Spark Plugs a DIY? 00M5MD E39 M5 and E52 Z8 Discussion 11 19th September 2006 05:11 AM
Okay DIY'ers: what OBD-II and/or reset tool do you recommend? Teutonaddict E39 M5 and E52 Z8 Discussion 9 15th February 2005 12:41 AM
