e60 M5 Spark Plug & Air Filter DIY w/ Pics (Good Resource for DIY-ers) - Page 2 - BMW M5 Forum and M6 Forums
 17Likes
post #11 of 85 Old 24th November 2011, 04:05 PM
Fuddy
Fuddy's Avatar
Originally Posted by petesamprs View Post
Any reason we don't have a DIY subforum or sticky thread of all consolidated DIY posts? Would be a huge resource.
I have website space, I'd be willing to setup a repository of DIY pdf's
Fuddy is offline
post #12 of 85 Old 24th November 2011, 05:07 PM Thread Starter
mdyaman
mdyaman's Avatar
I just PM'd the moderators to see about a sub-forum creation for DIY
Retired: 2006 e46 ///M3 Silver-Gray SMG (sold)
Current: 2008 e60 DINAN
///M5 Interlagos Blue SMG
DINAN 3.91 Differential, Stage 2 Suspension, Free-flow exhaust, Stage III Software, Front strut braces,
High Flow Air mass meters and intakes, 13% Underdrive pulley, RPI Scoops. 12.5mm TMS Spacers.
mdyaman is offline
post #13 of 85 Old 24th November 2011, 05:39 PM
5.7 silver bullet
5.7 silver bullet's Avatar
Is there a link to takeing the injector box off, I was going to have mine dipped in Carbon Fiber. thanks for the post..
Dinan Everything, 13% Underdrive pulley,High Flow Middle Racing Exhaust with 4" Resonators, Free Flow Exhaust (E60) M5 full cat delete manifolds, High Flow Air Mass Meter/ Intake Assemblies, High Flow large Throttle Bodies, Stage 3 Engine Software, Replacement Filter for High Flow Air Mass Meter/Intake Assemblies, 3.91 Limited Slip Differential, Dinan Carbon Fiber Front Strut Tower Brace, Dinan Carbon Fiber Rear Shock Tower Brace, Dinan Stage 3 Suspension System (E60) M5, Dinan Lower Control Arm Monoball Racing Kit M5/M6, DinanHigh Performance 5.7 Liter V-10 Engine, Euro SMG upgrade 4k launch, LIQUI MOLY 10W-60 Motor Oil, Wix 57694 Oil filter. Special Thanks All the great forum members.
20" BBS RS-GT Wheels,20" Michelin PS2,Tinted Windows, Carbon Fiber Steering Wheel, Billet Aluminum Parking Brake Handle, Aluminum Pedal set, BMW Factory iPod Adaptor, Custom installed Escort Radar/jammer System, LED Interior lighting, Angel Eyes light Upgrade, LED Side Markers Clear, Sprint Booster Throttle.
Brembo 4 Wheel Big Brake Kit, 2010 LCI Euro Tail lights, Apex EC-7 18x10.5 wheels Hoosier 315-30-18 Drag Radials.
Best 1/4 E.T 11.74 Best MPH 123.86 - 60' 1.69 11/18/12
5.7 silver bullet is offline
post #14 of 85 Old 24th November 2011, 06:04 PM
DFrankm5
DFrankm5's Avatar
DIY Maintenance
5.7 Silver Bullet
I am with you. I would also like to see an illustration of how to remove the air-intake over the throttle-bodies. Looks to be a bit tedious.
DFrankm5 is offline
post #15 of 85 Old 24th November 2011, 06:38 PM Thread Starter
mdyaman
mdyaman's Avatar
Mods are going to run it by the staff to see about creating a DIY sub-forum
if approved, it would be a m5board first
mdyaman is offline
post #16 of 85 Old 25th November 2011, 09:04 AM
tdonnell
Only things I would add:
If you have access to compressed air, blow out the bores before removing the plugs to ensure no debris is left in them that could potentially fall into the cylinder or damage the threads in the head upon installation of the new plug.
I always keep track of what cylinder which plug came out of by marking numbers on the new boxes and swapping old plugs for new plugs one at a time. This way you can thoroughly examine them later and know what cylinder each individual plug came from.
It probably isn't entirely necessary but I would mark each coil with masking tape and a marker for what cylinder it came out of just in case the ECM is used to the reaction time of each coil once a signal is sent to it.
Also NEVER remove plugs from a warm cylinder head, especially an aluminum one. Removing plugs from a warm/hot cylinder head dramatically increases the odds of pulling the threads out of the plug bores (when un-screwing the plugs) which requires heli-coils to be installed and thats if you want to risk metal shavings in the cylinder.
Excellent write up, thanks for sharing!
tdonnell is offline
post #17 of 85 Old 29th January 2012, 01:31 AM
nonford
These instructions are very well detailed and allows for a quicker remove and replace! Great job Sir. Appreciated the tips, made it so much easier for me.
nonford is offline
post #18 of 85 Old 7th June 2012, 09:19 AM
kaa
kaa's Avatar
Thanks Mdyman for the great post. I used it to replace my spark plugs about a week ago. The only thing I can add is that; I personally do one spark plugs at a time. It means, I take one coil out, change the spark plug and replace coil. Then move on to the next one. In that way there is little chance of something dropping inside. And for the last two spark plugs closest to the windshield, you have to remove the interior air filter and the housing under it (right under the windshield). Its very easy to do and I am sure its design like that to access those last two spark plugs. There is no need for "special magnetic tool" to get the plug out. By doing it myself, it only cost me $201.60 including 12% tax. It would cost between $845 to $949 (two quotes from dealerships) if I would've taken it to the dealership.
kaa is offline
post #19 of 85 Old 7th June 2012, 11:36 AM Thread Starter
mdyaman
mdyaman's Avatar
So you bought new coil packs as well?
Do you need to replace the coil packs when installing new spark plugs or can you leave the old ones in there?
mdyaman is offline
post #20 of 85 Old 7th June 2012, 05:06 PM
DFrankm5
DFrankm5's Avatar
DIY
Mdyaman
I don't believe the coils need to be replaced when you do the spark plugs unless a coil is not performing, defective or broken. OKD makes a higher performing coil for our M's but they are $2,500-$2,800 for a set.
DFrankm5 is offline
DIY Spark Plugs, as requested. (Pics inside) rdm190 E39 M5 and E52 Z8 Discussion 134 14th September 2016 04:03 AM
Kmoy's DIY $5 OEM Hella Remote Angel Eyes DIY (Lots of Pics) Kmoy2002 E39 M5 and E52 Z8 Discussion 36 13th February 2015 06:24 PM
Bay Area DIY'ers Tortuga E39 M5 and E52 Z8 Discussion 2 12th April 2007 05:42 AM
Are Spark Plugs a DIY? 00M5MD E39 M5 and E52 Z8 Discussion 11 19th September 2006 05:11 AM
Okay DIY'ers: what OBD-II and/or reset tool do you recommend? Teutonaddict E39 M5 and E52 Z8 Discussion 9 15th February 2005 12:41 AM
