FYI: E60 M5 S85 Valeo Voltage Regulator for Alternator - Page 18 - BMW M5 Forum and M6 Forums
 24Likes
post #171 of 175 Old 4th January 2019, 10:07 PM
UkraineE39
UkraineE39's Avatar
Anybody have symptoms of ABS/DSC/BRAKE trifecta lights on the dash?
Symptoms are:
heavy steering as if its always in M Mode.
oil temperature gauge jumping around on dash.
car starts but seems to be a "weak start" .
having slight idle fluctuations when stationary.
Could a VR be the cause of (some) of these symptoms ?
Garage - E39 M5 / E63 M6
UkraineE39 is offline
post #172 of 175 Old 5th January 2019, 01:40 AM
texsn95
texsn95 is offline
post #173 of 175 Old 6th January 2019, 06:43 AM
Garfunkgrin
Garfunkgrin's Avatar
Symptoms are:
Yeah, especially the jumpy gauges. I wouldn't wait - usually when the VR fails it oversupplies voltage, so it can toast much more expensive modules. In my case it was a rapid decline and it ended up with the car stalling a block from home (thankfully). You can buy the valeo part (same company that supplies the OEM alternator) for less than $50.
Garfunkgrin is offline
post #174 of 175 Old 8th January 2019, 04:52 AM
UkraineE39
UkraineE39's Avatar
The thing is im not getting over supplied voltage. Im not getting any voltage from the alternator. Could the IBS be responsible for this or failed alternator ?
in other words im getting the same 12.2-12.5 volts from the battery - does not matter if the car is running or not. Eventually battery dies out.
post #175 of 175 Old 15th March 2019, 05:54 PM
Makoi
Makoi's Avatar
I just want to say Thank You to the OP for taking his time to write up this DIY.
I tackled this DIY yesterday and my beast is running well again.
A few stuff I want to add:
Watch this YouTube video on how the brushes on the voltage regulator makes contact on the slip ring.
https://www.youtube.com/watch?v=aVvPzwtxdrM
I know some of you guys are still having problems after replacing the VR. My guess is, the slip ring of your alternator is dirty and its not making a good contact with the brushes of the new VR.
I cleaned the slip ring of my alternator with some strips of sandpaper to make sure it will have a good contact with the brushes of the new VR.
Also, to remove the plug, its alot easier with a pry tool. With your left hand, reach the plug through the top of the alternator and push the down the tab with your thumb. With a pry tool on your other hand, gently pry the plug away from the alternator. You'll be amazed on how easy it was.
Here are some picture of my install:
Old Voltage Regulator:
Old vs New Regulator:
New Regulator only has one prong and the old one has two prongs. No worries, the plug only has one wire.
The brushes is being held by the round plastic cup. They will release once you push the round plastic cup in.
Round Plastic Cup - you need to push this in after you securely screwed in the VR to the alternator so the brushes releases to the slip ring.
Picture of the Slip Ring:
Cleaned Slip Ring:
If you guys have any question. HMU, I might be able to help or answer your question.
Good Luck....
Turbocharging? In an M car? That’s like putting gravy on an ice cream. -Jeremy Clarkson
Makoi is offline
Alternator Regulator Replacement Technique Query! IvanDias E34 M5 Discussion 1 7th October 2014 08:07 PM
Normal operating voltage? Bad alternator? HarvesterOfBeer E39 M5 and E52 Z8 Discussion 6 29th July 2011 12:30 PM
Ovalised slip ring on the Alternator, plus alternator rebuidl services, UK? IvanDias E34 M5 Discussion 1 26th February 2010 05:57 PM
ABS/Battery light pause since regulator blew on 140A replacement for 110A Alternator! IvanDias E34 M5 Discussion 2 10th June 2006 12:58 PM
