Overheating - BMW M5 Forum and M6 Forums
 3Likes
LinkBack Thread Tools Rate Thread
Old 13th July 2011, 01:11 PM Thread Starter
M5Doctor
Overheating
Hi,
Currently down in the south of France and after flogging my own "engine" cycling around the etape du tour I have been out on the mountains in the m5. I have found that with some pretty spirited driving going up the mountain passes the engine temp is getting to 130. The car has twice informed me that it is too high and asked me to "drive moderately". I would say that the ambient temperature was up to 33C and I was driving pretty hard up steep mountains.
I've never had this happen before and have pushed the beast to its limits off the public road, albeit not in such a hot climate. Should I be concerned about this, as I would have thought it should be capable of dealing with these conditions?
Thanks for any experience,
Steve
M5Doctor is offline
Old 13th July 2011, 01:14 PM
IndyRedBeast
IndyRedBeast's Avatar
you will overheat your engine. You need to get the RPi SV1 oil cooler if your going to track, Look into it.
Performance:
Meisterscahft Section 1 Pipes
Meisterschaft Section 2 X-Pipe
Eisenmann-Race Section 3 Cans
Catless Headers
Eurocharged ECU Tune
Evosport Power Pulley
BC-Racing Coilovers
Stoptech SS Brake Lines
Stoptech Street Brake Pads
ATE Super Blue Brake Fluid
M Sprint Booster V2
Simota CF CAI
RPi Scoops
Wheels/Tires:
20" Varrstoen ES1
Hankook V12 Evo's
TMS Spacers
Rolled Fenders
Gloss Black Calipers
M Caliper Decals
Exterior:
Hamann Painted Splitter
Custom Black Extension Lip
Hartge Painted Diffuser
Custom Rear Bumper Grille
Gloss Black Sideskirt Extensions
Gloss Black OEM Grilles
Gloss Black Side Gills
Gloss Black Vinyl Roof
Gloss Black M5 Emblem
Gloss Black/White BMW Roundels
Interior:
Alcantara E-brake/SMG Boots
Alcantara/Perforated Leather Wheel
Alcantara Steering Wheel Trim
Alcantara Full Headliner
CF 3M Di-Noc Trim Wrap
CF Steering Emblem
CF Door Pins
Lighting:
Custom Painted Headlights
Orion V2's/Euro Reflectors
OEM LCI Euro Taillights
V6.1 Bruce Cables
Full LED Interior Lights
LED Clear Side Makers
LED License Plate Lights
LED Reverse Lights
Solaris Invisi-Bulbs
6000k HID Bulbs
SOLD
Mikelll M5
IndyRedBeast is offline
The Following User Says Thank You to IndyRedBeast For This Useful Post:
M5Doctor (13th July 2011)
Old 13th July 2011, 01:27 PM
Hasan Shaikh
Hasan Shaikh's Avatar
Originally Posted by M5Doctor View Post
Hi,
Steve
At 33C the car should not overheat. No matter how hard you are driving.
There can be many reasons for overheating.
1) The coolant level is low. The car has a sensor that warns you if the coolant level is low.
2) The radiator fan is not working properly.
3) The oil cooler is blocked or is not working.
The stock oil cooler is pretty good actually. The guys here track and drift their cars at 40C and they don't over heat very easily. In fact, I have only seen them over heat during drifting and even then it would take the car at least 20 minutes of hard drifting to over heat.
Hasan Shaikh is offline
The Following User Says Thank You to Hasan Shaikh For This Useful Post:
Old 13th July 2011, 02:16 PM Thread Starter
M5Doctor
Thanks Hasan, good to have some experience from a guy who lives somewhere very hot!
The coolant level is ok and the radiator fan is definitely working (to some extent anyway - it's moving). I need the brake fluid changing when I get home so I will see what the stealer has to say about it then. Hopefully no damage will have been incurred from it, as I backed it off pretty quick as soon as the warnings came up.
Steve
M5Doctor is offline
Old 13th July 2011, 02:49 PM
Hasan Shaikh
Steve
Dear Steve
If you ease up immediately and don't push the car while the warning is on, there should be no damage.
I just checked with our M5 gurus here and they have told me that it is most likely a weak water pump or a malfuctioning thermostat. Both are known issues with these cars.
The $tealer should be able to pin point the cause. Please share your findings with us.
Good Luck
The Following 2 Users Say Thank You to Hasan Shaikh For This Useful Post:
Ahmed (13th July 2011), M5Doctor (13th July 2011)
Old 13th July 2011, 04:44 PM
V10PWR
V10PWR's Avatar
I Agree. I took the car to track for 2 days back to back about 3 weeks ago, and the temperature was above 100°F. I had no issues with over heating.
Get it checked out.
Good luck.
"One Person Can Make a Difference, and Everyone Should Try." John F. Kennedy
V10PWR is offline
Old 10th August 2011, 10:54 PM Thread Starter
M5Doctor
Follow up
Well, the dealer says they can't find any issues. No faults stored either.
They claim that the altitude, rather than the temperature, and driving it hard between hairpin bends could result in it overheating.
I guess I'll just have to accept that but I would have thought the M5 should be able to cope with giving it some on a mountain pass.
Steve
M5Doctor is offline
Old 11th August 2011, 02:33 AM
Hasan Shaikh
Hi Steve
I am glad that the car turned out ok.
However, I am not convinced that the car would over heat due to spirited driving in mountains.
Good Luck!
Old 11th August 2011, 03:44 AM
impulsoren
Hills are way different than flat tracks. My Isuzu has a huge custom radiator, stays below factory "normal" temp as long as it is moving in any conditions, except during hillclimbs, those are even short races and it overheats then. Maybe running uphill in thin air puts enough load on the engine that it retards timing, which makes it run hotter. Also, at altitude the air is thinner and heat transfers less efficiently. So probably not a big deal, if you intend to make use of your car mainly in the mountains you may want to upgrade the oil cooler.
2006 M5 black/black
1999 A4 1.8 winter beater
1989 Isuzu Impulse 2.6L turbo-397hp/414tq at the wheels
1984 1-ton van
1989 Toyota PU 3RZ swap-on hold, stock 22RE in the meantime
1994 Park Avenue with overdriven Eaton
impulsoren is offline
Old 3rd July 2016, 06:01 PM
maxse01
Hi guys,
I've had my m5 for 3 weeks and 400 miles and I've gotten this message twice with not much hard driving. My oil temp will rise as high as 220-230 and the the warning comes on. It happened once before I had the oil changed and coolant/thermostat changed and now it just happened again. The fan is working, oil cooler doesn't seem blocked.
I'm going to make an appointment again and have it checked out. Could the oil temp sensor be faulty?
2008 M5 BSM/SBM 6 speed manual
Charcoal filter delete, AFE Panel Filters, Corsa Section 3
maxse01 is offline
Rate This Thread
My M5 is overheating :( E39///M5 E39 M5 and E52 Z8 Discussion 22 3rd July 2010 06:37 AM
overheating (maybe) crazyrobbery E39 M5 and E52 Z8 Discussion 19 18th May 2010 02:46 AM
Overheating SoCalJD GTBoard.com: General Sportscars 4 25th April 2006 06:17 PM
overheating !!!! jester5675 E34 M5 Discussion 6 28th May 2004 09:14 PM
Overheating Johnnym5 E28 M5 Discussion 3 17th September 2003 07:24 PM
