Our future: swap SMG for 6-speed manual? - Page 18 - BMW M5 Forum and M6 Forums
 113Likes
LinkBack Thread Tools Rating: Thread Rating: 4 votes, 5.00 average. Display Modes
post #171 of 239 Old 4th July 2018, 05:08 PM
jcolley
jcolley's Avatar
Originally Posted by iDev326 View Post
PLEASE PM ME or email me on a price for that! [email protected]. I need one and wasn't hoping to buy one from BMW for $1,200!
Forgot to get back to you. Apologies, all are SMG.
jcolley is offline
post #172 of 239 Old 4th July 2018, 06:35 PM
CHARIOT
Empyre Auto Parts in Rialto has a driveshaft for you. Donor car is an 08 6MT, stock number is "EM415", price is $225. Call them go get that thang!
DIY: E60 M5 SMG to 6MT Conversion:https://www.m5board.com/vbulletin/e6...-manual-2.html
CHARIOT is offline
post #173 of 239 Old 5th July 2018, 06:41 AM
Dr.Dave.DDS
Dr.Dave.DDS's Avatar
Dr.Dave.DDS is offline
post #174 of 239 Old 6th July 2018, 08:46 AM
iDev326
iDev326's Avatar
CHARIOT, you are the man. Thank you so much for all the info you posted here. I owe you a beer and a steak dinner haha. Also Iíve ordered all my small parts from BMW South Atlanta and Mike the Parts manager has been awesome to work with. Even though theyíre back East from me (Iím in Cali) I highly recommend shopping there. Helped me find a lot of the small parts that Iíll be compiling in a list at the end.
Quick small update, MDM switch panel arrived from Germany along with the last hydraulic line running inside the car. Hoping to have the interior in this weekend.
Ordered a 6 speed E90 M3 transmission so thatís coming in two weeks. Going to be a fun side project getting that to work as the M3 6 speeds have trans cooler lines going to the front of the car for a trans cooler. Wonder why BMW never did that on the M5
Sent from my iPad using Tapatalk
iDev326 is offline
post #175 of 239 Old 13th July 2018, 09:14 AM
iDev326
iDev326's Avatar
Got a bit more done over the weekend and put the majority of the interior back together.
The hard to find MDM switch came in and is looking spiffy with the relocated EDC button.
There is a bit of a difference in wiring the MDM switch. On LCI 6 speed cars, the signal from the MDM switch to the DSC module goes to the center console switch center up under the dash in the passenger side fuse panel. Itís connector X16919 and is a black 30 pin connector.
Pin 14 is the deactivation DSC signal that is used on 6 speed LCI cars but empty on LCI SMG cars. What I ended up doing was reusing the wires in the center console from the POWER button and old DSC OFF switch. You will need to remove pin 1 from the POWER switch connector. This wire is the LED activation signal for the button when you press it but since we no longer ave it, we can repurpose it. This wire goes to pin 28 on the X16919 connector. Relocate this from pin 28 to pin 14. Once that is done, youíll then remove pin 3 from the old DSC OFF button connector and splice this to the other wire you removed from the POWER button connector. You will then need to move pin 41 on the DSC module connector to pin 6.
The E90 M3 transmission arrived today along with the harness and some other stuff. Shoutout to Jobe Auto Parts in Madison, AL for shipping the unit to me. Got it for a great deal and happy with the purchase. If you decide to go this route, you will need to figure out if you will run the transmission cooler or not. The ports on the right hand side of the trans next to the electric oil pump have no threads as the factory lines use some kind of plate to sandwich the lines into the port. What I plan on doing is buying a set of used transmission cooler lines from a E9x M3 and welding AN fittings to the stock M3 lines to use a cooler. Most likely will use a Setrab cooler in the front of the car to do so.
iDev326 is offline
The Following User Says Thank You to iDev326 For This Useful Post:
CSBM5 (13th July 2018)
post #176 of 239 Old 15th July 2018, 04:00 PM
pmalik
Is the m3 trans the same physical dimensions as the e60 manual? Custom driveshafts aren't cheap.
pmalik is offline
post #177 of 239 Old 15th July 2018, 06:50 PM
Z3 M Roadster
Z3 M Roadster's Avatar
It's the same transmission just with a cooler, I'm using the same one for swap.
Z3 M Roadster is offline
post #178 of 239 Old 15th July 2018, 11:17 PM
jcolley
jcolley's Avatar
Yes. I'm doing one now, will be manufacturing plugs to block off the cooler ports. I'm also looking at code in the DME to enable the cooler and trigger the same as the mss60 does.
jcolley is offline
The Following 2 Users Say Thank You to jcolley For This Useful Post:
CSBM5 (16th July 2018)
post #179 of 239 Old 16th July 2018, 07:15 AM
pmalik
Jim, a 6 speed conversion kit would sell like hot cakes...
pmalik is offline
post #180 of 239 Old 16th July 2018, 09:51 AM
iDev326
iDev326's Avatar
More progress overnight, I got the SMG transmission out. Exhaust, heat-shield and driveshaft came out pretty easily. I even mentioned to my friend how easy this was going along. You might know this as foreshadowing and probably know what is coming unknown to me! Got to the trans, removed wires, removed rear o2 sensors, etc. Began loosening all the e-torx bolts around the bell housing. Had to use my entire set of locking extensions from HF Tools, made life so much easier not having the extensions fall/pop out. Having a nice time I say......
However, this project really had a close call. One of the starter e-torx bolts had been overtorqued and rounded from the previous clutch job prior to my ownership. Needless to say that was an absolute PITA and came close to possibly dropping the motor and trans together in order to get to this. I used my 8mm bolt extractors to hammer on with my extension train and managed to get it off somehow....luck was on my side. MAKE SURE TO USE THE PROPER E-TORX SOCKETS! IT IS NOT FUN REMOVING THE TOP ONES, especially if they are rounded/over-torqued. Go slow and make sure you are fully seated when getting these off.
Got the old SMG out, surprisingly the wiring didn't look too bad near the PLCD sensor. I HIGHLY recommend a low profile trans jack or having someone with a lift and a trans jack. I did this with a regular jack, that was much more difficult to balance the trans coming down. This thing is heavy and will want to rollover coming down if you are not balancing this as it comes down if you do it this way! For some reason, my pilot bearing popped out with the trans. Not sure what that was about. Haven't pulled the clutch and flywheel out yet but they looked well beat for a unit that has done 50+ launch control starts. It's also a great time to replace all O2 sensors, I will be doing all four since my car has had lambda errors.
I ran the last hydraulic line from the clutch master to the clutch slave. Being that the trans was out, it made it a lot easier to fish the line up from inside the car. The line runs from the master, over the trans tunnel and into a grommet. Look at my photo if you need a reference. Don't forget to check the rubber o-ring and locking clip on both ends.
The interior no longer looks like a absolute mess anymore and is all fully back together and functioning. The EDC and MDM buttons are functioning the way they are supposed to and I tested all the buttons to make sure they work as intended. Off to Hawaii I go for a week and back at this immediately when I get back!
iDev326 is offline
6 speed manual on e60 m5 smg euro tra1ner E60 M5 and E61 M5 Touring Discussion 2 23rd June 2009 05:03 PM
6 speed manual needs much LESS oil than SMG! BogoKi E60 M5 and E61 M5 Touring Discussion 16 15th August 2007 04:00 AM
Is 6 Speed manual really slower than SMG? benfmd E60 M5 and E61 M5 Touring Discussion 35 30th July 2007 06:21 PM
2006 SMG or 2007 6 Speed Manual? jazz4tune E60 M5 and E61 M5 Touring Discussion 39 28th July 2006 04:12 AM
smg, auto or 7 (yes, 7!) speed manual Gus E60 M5 and E61 M5 Touring Discussion 20 20th March 2003 03:09 AM
