engine malfunction, reduced power - Page 2 - BMW M5 Forum and M6 Forums
post #11 of 27 Old 10th January 2010, 04:46 PM
M-POWER 77
M-POWER 77's Avatar
whats your mods ( if any ) ?
07 Indy red/ Indy red ///M5
ENGINE:
- Supersprint headers
- ASR engineering headers back exhaust ( arrived finally )
- ASR engineering cold air intake ( not installed )
- Evosport power pulley
- CA AUTOMOTIVE stage 2 tune
- RPI oil cooler ( still thinking )
WHEELS & SUSPENSION:
- Eibach pro kit springs
- HRE P40's gun metal with red pinstripe
EXTRAS:
- Matt black grill & gills
M-POWER 77 is offline
post #12 of 27 Old 10th January 2010, 07:05 PM
Ahmed
Ahmed's Avatar
Originally Posted by jdl92 View Post
Hi Admed,
What specifically are the problems with your SMG transmission?
JDL92
Grinding noise during clutch release, and clunky shifts. No error message.
2013 C63 AMG P31
2009 Lexus GS460
2004 Acura NSX-T
1994 Ferrari 348 Spider
1993 Dodge Viper RT/10 Roadster
1980 Porsche Turbo 3.3
Ahmed is offline
post #13 of 27 Old 10th January 2010, 09:42 PM
Stormster
Mine had these symptons before. It was down to accuators?! apperently. Replaced them and it was fine.
Same thing happened AGAIN this week. Red Cog of *****, engine error, DSC error, Start assist error. Turned on and off a few times every few mins hoping it would go away but it didn't. 30 mins later all was fine... tricky little *****.
Stormster is offline
post #14 of 27 Old 10th January 2010, 11:12 PM Thread Starter
jdl92
jdl92 is offline
post #15 of 27 Old 17th January 2010, 04:24 PM Thread Starter
jdl92
Just to bring anyone who may be following my situation, I dropped the car off at the dealer thursday and here I am waiting to hear what the problem is. Service associate said they have shared to computer readings and waiting to hear back. Keep everyone posted.
jdl92 is offline
post #16 of 27 Old 17th January 2010, 04:39 PM
ur20v
ur20v's Avatar
It happened again this morning. started the car and left the car idling to warm up for 5 minutes. Outside temp is 22 degrees again. when I returned to the car, warning light was on again. I restarted the car and it was gone. This is starting to piss me off and I will call the dealer tomorrow Monday.
Not a happy camper.
Mine had similar problems of the engine check light coming on from a cold start but not straight away and it would go out after a couple of long journeys and starts from warm it turned out to vanos problems and the replaced the pump then all the solnoides, its been fine since.
Regards
Jay
ur20v is offline
post #17 of 27 Old 20th January 2010, 08:48 PM
turton
turton's Avatar
Engine faults, DSC fault, Start assist Fault, Vanos Fault, Transmission fault, Oil Line
Interesting reading, and although I have already posted this as a new thread, I will paste it again here as I am part of this dreaded club at present:
I would be very very worried. I have just been "stung" with a bill that is now in the £7500 range, but see no end in sight yet.
7 days ago, I got a transmission fault light for 5 secs at a time when accelerating moderately. Took it in and £250 later was told nothing was wrong, no faults stored. As I drove off, same light came on. So I took it back. Was initially told not to worry, this light comes on in icy weather. I insisted this was utter cr~p and they agreed to have it back in for a further look. Later the next day they said the clutch was slipping and a vanos solenoid needed replacing- bill would be for £4000. I was livid but had no choice, so said carry out the work if it is necessary. Once collected, ss I drove away 3 more warning lights came on within 5 miles!- this time:
1. Engine fault- reduced power
2. DSC failure
3. start assistant inactive
I took it straight back. They have had it 2 more days now (this is about 7 days in total). Now told, is an internal failure of the oil hose to the VANOS, and failure of the high pressure pump. Also faults registered on a throttle valve on bank 2, and the ? max burner stack that operates the engine coolant. I am told that the original £4000 bill will now therefore be £7500!
All this for a BMW M5 that I have had from new, well looked after with 50,000 miles on the clock. They still have my car, and i have said this is not good enough.
P
turton is offline
post #18 of 27 Old 21st January 2010, 07:33 PM
ur20v
ur20v's Avatar
I'd ask for the old parts and get them inspected, if they are found to be 'good' they should refit for free!! Even if you don't plan to go down this route get the parts, you've paid for them and they will know you are serious!! All you should pay for upto know is some of the diagnostics time and not for parts that didn't need replacing!!
Jay
ur20v is offline
post #19 of 27 Old 21st January 2010, 08:56 PM
Barry Lausch
Barry Lausch's Avatar
You know I took a bit of a hiatus from this site and the number of posts centering on the mechanical failures of the E60 M5 is troublesome. I'm first on the list @ my local dealership for the F10 M5 when it's available.........I'm beginning to believe waiting a year or so might not be a bad idea. This puppy nad alot of bugs during the run-in year and I expect a world of pain as they age out of warranty.
2008 E60 ///M5 Sepang/Sepang/Walnut
Barry Lausch is offline
post #20 of 27 Old 21st January 2010, 11:03 PM
hbomb211
I think alot of the posts give a skewed view of the early models of the e60. Granted there are seemingly more problems with the earlier m5's more owners are gonna post with there problems than with there car is running perfect. That being said the lesson to be learned from all of this is you cannot own this car without a extended warranty and maintenance plan. The fact that a bad sensor can make it feel like there is a serious problem and it seems like some dealers may not really know what they are doing to fix it will lead to HUGE bills for out of warranty fixes. Also I think there are alot of older m5 that have been purchased used out there that have been thrashed pretty hard by the original owner. I belive this because when I was looking for my 06 m5 I ran into them in all types of conditions. I found out that just because a car had low mileage didn't mean the owner took care of the car. Even though i wish these cars were more sturdy if I wanted a car that wouldn't be a headache on occation I would have bought a toyota camry (and hated my life).
HBomb
2006 BMW M5 Gray w/ Gray Interior: Integrated Ipod, Black powdercoated stock rims, Rpi Ram Air, Block-off Plates, BMC Filters, ESS Tune, Eibach pro-kit
2008 Mustang Shelby GT500 (Sold)
hbomb211 is offline
The Following User Says Thank You to hbomb211 For This Useful Post:
DreamofBoost (11th April 2013)
Engine Malfunction reduced power to 3,500 AUTOG4 E60 M5 and E61 M5 Touring Discussion 13 30th November 2018 08:28 PM
"Engine Malfunction: reduced power!" & "Increased Emissions" OTDoc E63 BMW M6 Forum and BMW M6 Convertible | m6board.com 16 2nd November 2008 12:15 AM
"Engine Malfunction; Reduced power!" & "Increased Emissions" OTDoc E60 M5 and E61 M5 Touring Discussion 16 9th August 2008 03:25 AM
Warning message "Engine malfunction, reduced power"? drjeff E60 M5 and E61 M5 Touring Discussion 20 31st October 2007 02:36 AM
Engine Malfunction: Increased Emissions AND reduced power! V10BEAST E63 BMW M6 Forum and BMW M6 Convertible | m6board.com 7 2nd November 2006 03:39 AM
