Reduced Power + DSC + DBC + Start assistant FAILURE ! - Page 35 - BMW M5 Forum and M6 Forums
 21Likes
post #341 of 366 Old 26th April 2019, 09:43 PM
filipcstroe
I had this on mine turned out it was throttle actuators and leaking air at the intakes.
filipcstroe is offline
post #342 of 366 Old 1st May 2019, 01:30 PM
tripletop
tripletop's Avatar
M6 E63 S85 V10
After replacing the internal Nicad batteries in the anti theft alarm and re soldering the battery wiring the M6 performed with no error codes for 3 months.
The car was not used for 6 weeks and the trickle charger was not hooked up.
Unfortunately the error codes returned.
The OBD2 reader was showing multiple and changing DTC error codes.
Mainly these were
277C DME: oxygen sensor,diagnosis , trim control bank 1
271A DME Vanos Control ,intake bank 1
271C DME Vanos Control ,intake bank 2
27B6 DME : Vanos oil pressure
A391 Telematic fault main telephone aerial
Putting the trickle charger back on and using the car has seen these codes disappear except for
2B59 Coolant thermostat
Hopefully driving a some more Kms will get the O2 sensors working to lean out the fuel mixture so the engine can warm up quicker on these colder mornings.
tripletop is offline
post #343 of 366 Old 11th May 2019, 03:43 PM
socalsk8r
After 450 miles since I last reset the codes I got the same set of faults popping back up. I am going to drop it off at the dealership as I still have an extended warranty.
socalsk8r is online now
post #344 of 366 Old 13th May 2019, 03:24 PM
horse86
horse86's Avatar
keep us posted
- Justin
/// 2008 Space Grey M5 (SMG)
2009 Triumph Speed Triple 1050
2008 Range Rover FullFat
horse86 is online now
post #345 of 366 Old 20th May 2019, 10:08 PM
horse86
horse86's Avatar
socal....any updates?
- Justin
post #346 of 366 Old 23rd May 2019, 07:35 PM
socalsk8r
Well life got crazy so I have had no time to bring it in. Since my last update I had reset the codes and now itís been another 300 miles with no problems. (Just jinxed myself)
Iím sure itíll pop up again. But this leads me to my next thought....if it happens again and I reset the codes, the shop wonít be able to recreate the problem. I guess Iíll have to bring it in while Iím limp mode if it truly only ops up every few hundred miles.
post #347 of 366 Old 23rd May 2019, 09:08 PM
horse86
horse86's Avatar
WHEn you say limp mode what happens? Mine never goes into limp mode with my errors . It will just change my shift setting to go to a max of S5 instead of the S6 that I always leave it on
- Justin
post #348 of 366 Old 23rd May 2019, 11:32 PM
socalsk8r
So I got an error saying reduced power...throttle was limited to 4K and it went there SLOWLY.
post #349 of 366 Old 28th May 2019, 03:15 PM
horse86
horse86's Avatar
ahh you have the CIC nav...maybe that's why you get the slightly different/additional errors. Mine is an 08. I can deal with it though bc mine doesn't go into limp....just drops from s6 to S5....I can live with that.
- Justin
post #350 of 366 Old 4th June 2019, 03:33 AM
horse86
horse86's Avatar
Just scanned again for the heck of it and I gained a ďsteering angle sensorĒ error. Hoping this is all bc of a dirty Szl. Going to try and clean it this weekend so should find out shortly.
- Justin
Engine Malfunction reduced power to 3,500 AUTOG4 E60 M5 and E61 M5 Touring Discussion 13 30th November 2018 08:28 PM
"Engine failure, reduced power" error message! seckindogan E60 M5 and E61 M5 Touring Discussion 14 7th August 2007 08:47 AM
Reduced power / increased emissions AUTOG4 E60 M5 and E61 M5 Touring Discussion 9 22nd May 2007 06:14 PM
Engine fault reduced power Webby E60 M5 and E61 M5 Touring Discussion 5 26th November 2005 06:48 PM
Engine Failure. Reduced Power. DSC Failure BradM5 E60 M5 and E61 M5 Touring Discussion 2 19th October 2005 07:59 PM
