SMG fault? - BMW M5 Forum and M6 Forums
post #1 of 2 Old 5th October 2007, 03:35 PM Thread Starter
Qs06M5
Qs06M5's Avatar
SMG fault?
I noticed that my car would not downshift into second gear or first with plenty of RPMs left to go before red line. This happens when I am in power mode with traction control on and the SMG setting is in S5. For an example, I will be cruising at about 60ish and then I drop it to second with my foot floored on the gas, and it wont go into second when the RPMs in third is sitting at about 4.5K . If I let off the gas and then try to downshift again the car will go into gear. I am not sure if this happens with traction control off. I have not tried yet. Is this common? I take it this is just the traction control kicking in although I don't see the flashing DSC unless I punch it from a stop in first gear.
Qs06M5 is offline
post #2 of 2 Old 5th October 2007, 06:27 PM
pvr
pvr's Avatar
If you're in the S mode, it won't downshift for you in the situation you describe... needs to be in D mode for that. As for decelerating to a near or complete stop, there will be downshifts when it gets to the 20 mph level, more or less, even in S mode.
Paul
2006 M5, Sapphire Black/ Black Full Leather/Walnut
pvr is offline
2007 M6 SMG Failure RockM6 E63 BMW M6 Forum and BMW M6 Convertible | m6board.com 23 23rd June 2007 01:59 AM
Is SMG only for the M5 confirmed? SOMA E60 M5 and E61 M5 Touring Discussion 26 5th June 2004 01:19 PM
SMG Confusion???!!!! AzN_M5 E90 M3 Sedan, E92 M3 Coupe, E93 M3 Convertible, E46 M3 and E36 M3, Z4 M and Z4 M Coupe 13 17th January 2003 10:42 PM
SMG II Mr. Grinch E39 M5 and E52 Z8 Discussion 10 14th March 2001 12:40 AM
SMG Press Release Omar E39 M5 and E52 Z8 Discussion 12 18th February 2001 10:45 PM
