Knowledge base on Peake codes for E39 M5 - BMW M5 Forum and M6 Forums
 12Likes
LinkBack Thread Tools Rating: Thread Rating: 2 votes, 2.50 average. Display Modes
post #1 of 966 Old 10th July 2007, 06:10 PM Thread Starter
kees
Administrator
A recurring issue are threads asking about the meaning of certain Peake codes as well as likely culprits in troubleshooting issues. It seems logical to collate all these discussions into one Peake code knowledge base for the E39 M5.
Let's start with collecting all the well-known Peake codes and repairs. After that members with Peake codes that haven't been discussed can post in this thread for advice.
Please refrain from posting new threads about the subject of Peake codes from now on but post in this thread.
Tips:
1. Document your current codes, then reset/clear them, and then post active codes here for help.
2. Be sure to understand the difference between a B and a 6, as detailed in the next post.
3. Look up the descriptions behind the codes, using these attachments.
4. The first thing a Peake reports is a table number. No matter what you see, look up Table 18.
[Jan 2012 - updated attachments. HT: cab & Sailor24]
"EOBD" = Euro
"FCX2" = readers sold between 8/2003 and 12/2007
Link to Peake manuals.
kees is offline
post #2 of 966 Old 10th July 2007, 07:31 PM
IanS
IanS's Avatar
My first post on this subject would be to make sure the codes you are seeing are read correctly. One of the fairly common errors with reading the codes are the alpha characters, which can look like numbers. For example the letter "b" lower case, looks like a number "6" until you realize that the number "6" in the LCD display has the top horizontal line lit up.
Letter b:
|_
|_|
Number 6:
._
|_
|_|
More info on reading the codes or what reader is meant for your car can be found in the peakeresearch.com faq:
FAQ's
edit:
Table 1b is displayed as:
Code 16 for Cyl. 1-4 Exhaust CPS is displayed as:
01 ///M5 LeMans/Black/Silverstone
IanS is offline
post #3 of 966 Old 11th July 2007, 01:38 PM
bbh03
bbh03's Avatar
For those using the R5 SRS tool, you may read a code with the table number "06" and find there is no table by that number in the manual. This is, in fact, the same as table 04 and table 10 and is an omission from the manual.
bbh03 is offline
post #4 of 966 Old 12th July 2007, 01:06 AM
jcrist
jcrist's Avatar
81 was a code I got along with codes for all 4 O2 sensors (can't remember the exact ones but it was related to the heater?!) The O2 codes were in the Peake manual but the 81 wasn't. Turns out it was a fuse that powers the O2 sensors, located under the hood, 30amp.
JCrist
97 M3/328 JP/GTS2 #360
01 Beast EveryBMW Silver
jcrist is offline
post #5 of 966 Old 12th July 2007, 09:01 PM
KevN23
KevN23's Avatar
I have been getting 69, b2, b3 for a while now, they go back on after a reset after a couple hundred miles. The last time the SES came back on, it was only b2, b3, not more 69. Car runs fine and an indy could not find the problem. Sometimes, rarely, I do get rough idle when the engine is cold.
Still don't know what the problem(s) are.
KevN23 is offline
post #6 of 966 Old 13th July 2007, 07:53 AM
howorks
howorks's Avatar
Peake codes-- should I worry?
Got a couple codes today.
#18 ignition coil cyl #4
E8 Pedal position sensor 2
Are these something I should take care of right away?
thanks.
2000 ///M5 Titanium Silver
howorks is offline
post #7 of 966 Old 13th July 2007, 11:52 PM
gsfent
gsfent's Avatar
Letter b:
|_
|_|
Number 6:
._
|_
|_|
http://www.peakeresearch.com/faq.htm
Excellent on the difference between "b" and "6"!!
Dinan Stage 3 suspension, SS jet coated headers, ESS SC kit w/ 1 range colder NGK's, 92mm pulley, 440 Big Greens, TTFS alpha N tune for meth, RK plenum plates, SBC Endurance Stage 3 Kevlar performance clutch setup, "Jed" lightened DMFW, open brake ducts, TEC cupholder, U.S.(Euro style) tilt/slide armrest, 6k HID fogs, Umnitza bi-xenon flamethrowers w/6k super white low beams, rear fogs, V1/Stealth1, dual head LI, 2.65 diff w/40% lockup/2x dynamic, compact spare, M5 logo trunk carpet, Euro trailer hitch, Mocal oil cooler, ACS type rear spoiler, Rogue custom SSK and tranny mounts, ST 355 BBK (fronts), BP sway bar brackets, Bluetooth retrofit, Speedhut boost gauge (20 psi), Dinan TB's and VS, KB BAP, Howerton/HFS-3 Aquamist WI trunk setup (50/50), with 2nd gauge in rear view mirror, aftermarket trunk mounted sound system integrated into stock unit (amps, crossovers, sub and speakers).......
gsfent is offline
post #8 of 966 Old 16th July 2007, 01:14 AM
Nabio
Nabio's Avatar
I really hope this isn't too long but I made this a while ago and I just noticed this sticky so I figured it couldn't hurt. As I get a chance I'll change some of the fault descriptions into links to various threads on those particular issues. This is a copy of Table 18 in the code book for the Peake R5/FCX-II code reader tool. Table 18 is the only table I've ever used for my MY00 beast, however your table may be different. Enjoy.
Table 18
01 - Fuel pump relay
02 - Idle speed actuator (close)
03 - “Fuel Injector, Cyl #1”
04 - “Fuel Injector, Cyl #3”
05 - “Fuel Injector, Cyl #2”
06 - Timeout SMG-CAN
07 - “Intake camshaft position sensor, Cyl #1-4”
08 - “Intake camshaft position sensor, Cyl #5-8”
09 - “Knock sensor, Cyl #1-2”
0A - “Exhaust camshaft position sensor, Cyl #1-4”
0B - “Exhaust camshaft position sensor, Cyl #5-8”
0C - “PreCat oxygen sensor, Cyl #5-8”
0D - “PreCat oxygen sensor, Cyl #1-4”
0E - Tank small leak
0F - “Crankshaft/Camshaft position correlation, Cyl #1-4”
10 - Crankshaft sensor
12 - Map controlled thermostat actuator
13 - Secondary air pump relay
14 - Starter relay
15 - “Exhaust camshaft VANOS retard valve, Cyl #1-4”
16 - “Exhaust camshaft VANOS advance valve, Cyl #1-4”
17 - “Ignition Coil, Cyl #2”
18 - “Ignition Coil, Cyl #3”
19 - “Ignition Coil, Cyl #1”
1A - “Ignition Coil, Cyl #8”
1B - DM-TL switching valve
1C - Map controlled thermostat control
1D - Idle speed actuator (open)
1E - “Control unit self-test, A/D converter monitoring”
1F - “Fuel Injector, Cyl #5”
20 - “Fuel Injector, Cyl #6”
21 - “Fuel Injector, Cyl #4”
22 - “Fuel Injector, Cyl #7”
23 - “Fuel Injector, Cyl #8”
24 - Evaporative emission purge control valve
25 - “PreCat oxygen sensor heater control, Cyl #1-4”
26 - “PreCat oxygen sensor heater control, Cyl #5-8”
27 - “AfterCat oxygen sensor heater control, Cyl #1-4”
28 - “AfterCat oxygen sensor heater control, Cyl #5-8”
29 - “Air mass sensor, Cyl #1-4”
2A - “Vehicle speed input signal, hardwired ‘A’ signal”
2B - Radiator outlet temperature sensor
2C - Thermal oil level sensor
2D - Drive-by-wire throttle actuator driver
2E - Fuel consumption (KVA) signal output
2F - Engine RPM (TD) signal output
30 - A/C Compressor relay
32 - “Ignition Coil, Cyl #4”
33 - “Ignition Coil, Cyl #6”
34 - “Ignition Coil, Cyl #5”
35 - Electronic fan (relay)
36 - Battery voltage behind main relay
37 - “Ignition Coil, Cyl #7”
39 - “Air mass sensor, Cyl #5-8”
3A - Sensor voltage supply 1
3B - Sensor voltage supply 2
3C - “Pedal position sensor 1, master measurement”
3D - “Pedal position sensor 2, master measurement”
3F - Secondary air switching valve
41 - “Throttle position sensor 2, slave measurement”
42 - EWS interface
43 - “Intake camshaft VANOS advance valve, Cyl #1-4”
45 - “Knock sensor, Cyl #5-6”
46 - “Knock sensor, Cyl #3-4”
47 - “Knock sensor, Cyl #7-8”
48 - “Intake camshaft VANOS retard valve, Cyl #1-4”
49 - “Air mass sensor, plausibility”
4A - “Intake camshaft VANOS advance valve, Cyl #5-8”
4B - “Intake camshaft VANOS retard valve, Cyl #5-8”
4C - Ambient pressure sensor
4D - Intake air temperature sensor
4E - Coolant temperature sensor
4F - Exhaust gas temperature sensor
50 - Switch-chain grip
51 - MFL interface signal
52 - Muffler flap
53 - “Exhaust camshaft VANOS advance valve, Cyl #5-8”
54 - “Exhaust camshaft VANOS retard valve, Cyl #5-8”
55 - “Throttle position sensor, master measurement”
56 - CAN buss offline
57 - “AfterCat oxygen sensor voltage, Cyl #1-4”
58 - “AfterCat oxygen sensor voltage, Cyl #5-8”
59 - “Control unit self-test, Safety Concept slave check”
5A - “PreCat oxygen sensor aging, Cyl #1-4”
5B - “PreCat oxygen sensor aging, Cyl #5-8”
5C - “AfterCat oxygen sensor aging, Cyl #1-4”
5D - “AfterCat oxygen sensor aging, Cyl #5-8”
63 - “Control unit self-test, Safety Concept master check”
64 - Tire pressure left front
65 - Tire pressure right front
66 - Tire pressure right back
67 - Tire pressure left back
69 - “Engine coolant temperature, Plausibility”
6A - Brake light switch
6B - “Control unit self-test, pre-drive check of drive-by-wire system”
6C - Switching valve oil circuit left
6D - Switching valve oil circuit right
6E - Sport switch LED indicator
6F - “Pedal position sensor 1, cross check”
70 - “Pedal position sensor 2, cross check”
71 - “Intake camshaft VANOS position control, Cyl #5-8”
72 - “Exhaust camshaft VANOS position control, Cyl #5-8”
73 - “Control unit self-test, internal ECU temperature”
74 - Servotronic valve current
75 - Servotronic speed signal
76 - Throttle position sensor 1
77 - Throttle position sensor 2
78 - “Throttle position sensors, cross check”
79 - “Throttle position sensors, both bad”
7A - “Control unit self-test, master processor”
7B - “Bus offline, SMG-CAN”
7C - Active engine bearing
7D -Spoiler adjustment
7E - Fuel pump crash shut-off
7F - DM-TL module
80 - Idle speed deviation
82 - “EWS signal, manipulation detected”
83 - “DSC intervention, plausibility”
84 - DSC message timeout
85 - Steering angle sensor message timeout
86 - Instrument Cluster message timeout
87 - Vehicle speed signals (both Discrete & CAN)
88 - Idle speed controller
89 - Jet stream pump
8A - Differential lock
8B - Cruise control system
8C - Engine noise too high
8D - “Fuel level, plausibility”
8F - E-box fan
90 - “Fuel control, Cyl #1-4”
91 - “Fuel control, Cyl #5-8”
95 - Misfire w/ empty fuel tank
96 - “Control unit self-test, memory test master”
97 - “Control unit self-test, driver diagnostics chain”
98 - “Control unit self-test, communication master”
9B - “Control unit self-test, adaption EEPROM master”
9C - “Control unit self-test, adaption EEPROM slave”
9D - “Control unit self-test, memory test slave”
9E - “Control unit self-test, communication slave”
9F - “Control unit self-test, knock detection IC 1”
A0 - “Control unit self-test, knock detection IC 2”
A1 - Knock control
A2 - “Crankshaft/Camshaft position correlation, Cyl #5-8”
A3 - “Control unit self-test, master resets”
AA - “Secondary air system, flow too low”
AB - “Secondary air system, valve sticking”
AC - VANOS pressure storage valve
AD - Starter switch input
AE - “Air-fuel adaptation, Cyl #1-4”
AF - “Air-fuel adaptation, Cyl #5-8”
B0 - “Air-fuel adaptation at idle, Cyl #1-4”
B1 - “Air-fuel adaptation at idle, Cyl #5-8”
B2 - “Catalyst system efficiency, Cyl #1-4”
B3 - “Catalyst system efficiency, Cyl #5-8”
B4 - Tank leak detected
B5 - Filler cap open
B6 - “Injection driver 1, over temp.”
B7 - “Injection driver 2, over temp.”
B8 - “Intake camshaft VANOS position control, Cyl #1-4”
B9 - “Exhaust camshaft VANOS position control, Cyl #1-4”
BA - “Ignition output stage, Cyl #1”
BB - “Ignition output stage, Cyl #2”
BC - “Ignition output stage, Cyl #3”
BD - “Ignition output stage, Cyl #4”
BE - “Ignition output stage, Cyl #5”
BF - “Ignition output stage, Cyl #6”
C0 - “Ignition output stage, Cyl #7”
C1 - “Ignition output stage, Cyl #8”
C2 - “Control unit self-test, cruise control shut-off”
C3 - “Control unit self-test, torque manager monitoring”
C4 - “Misfire, Cyl #1”
C5 - “Misfire, Cyl #2”
C6 - “Misfire, Cyl #3”
C7 - “Misfire, Cyl #4”
C8 - “Misfire, Cyl #5”
C9 - “Misfire, Cyl #6”
CA - “Misfire, Cyl #7”
CB - “Misfire, Cyl #8”
CC - “Misfire, multiple cylinders”
CD - “Misfire during warm-up, Cyl #1”
CE - “Misfire during warm-up, Cyl #2”
CF - “Misfire during warm-up, Cyl #3”
D0 - “Misfire during warm-up, Cyl #4”
D1 - “Misfire during warm-up, Cyl #5”
D2 - “Misfire during warm-up, Cyl #6”
D3 - “Misfire during warm-up, Cyl #7”
D4 - “Misfire during warm-up, Cyl #8”
D5 - “Misfire during warm-up, multiple cylinders”
D6 - “PreCat oxygen sensor slow response, Cyl #1-4”
D7 - “PreCat oxygen sensor slow response, Cyl #5-8”
D8 - “PreCat oxygen sensor slow switching (rich to lean), Cyl #1-4”
D9 - “PreCat oxygen sensor slow switching (rich to lean), Cyl #5-8”
DA - “PreCat oxygen sensor signal size/amplitude, Cyl #1-4”
DB - “PreCat oxygen sensor signal size/amplitude, Cyl #5-8”
E4 - “Drive-by-wire throttle control failure”
E5 - “Drive-by-wire throttle control failure”
E6 - “Drive-by-wire throttle position failure”
E7 - “Control unit self-test, slave processor check”
E8 - Evaporative emission purge valve functional check
F7 - VANOS pressure accumulator valve
F8 - “Intake camshaft VANOS moving time, Cyl #1-4”
F9 - “Exhaust camshaft VANOS moving time, Cyl #1-4”
FA - “Intake camshaft VANOS sealing, Cyl #1-4”
FB - “Exhaust camshaft VANOS sealing, Cyl #1-4”
FC - “Intake camshaft VANOS moving time, Cyl #1-4”
FD - “Exhaust camshaft VANOS moving time, Cyl #1-4”
FE - “Intake camshaft VANOS sealing, Cyl #5-8”
FF - “Exhaust camshaft VANOS sealing, Cyl #5-8”
Black Sapphire Metallic 2012 X5 M
Nabio is offline
The Following 7 Users Say Thank You to Nabio For This Useful Post:
Alpine2002 (14th May 2010), Hdhntr23 (17th June 2009), john535 (11th April 2013), KaliforniaM5 (14th July 2009), mcflan (12th August 2013), mmzcee (11th February 2011), zed.inc (25th February 2012)
post #9 of 966 Old 18th July 2007, 01:39 PM
alquazi
alquazi is offline
post #10 of 966 Old 22nd July 2007, 02:13 AM
Carzzi
Carzzi's Avatar
Should you wish to have an excel sheet for printing and keeping in your Peake carry-case I've attached one. It's already formatted to print on a single letter size sheet (small font though, let the far-sighted be forewarned).
Carzzi
E39 M5 Anthracite/ Caramel, stock, SOLD
E36 M3 Arctic/ Dove, Supersprint/ Sharked, SOLD
190E 2.6 Sportline 5-sp, AMG Headers
Carzzi is offline
The Following 12 Users Say Thank You to Carzzi For This Useful Post:
155plus (25th July 2008), Benzin (27th May 2011), DJ420 (12th May 2014), El Diablo (25th June 2008), fumando (14th June 2011), g9s8r (8th March 2008), john535 (11th April 2013), m5Dreamin (6th October 2008), Mr Adventure (9th December 2008), PatrickW (9th August 2012), Sweetwater (30th June 2012), tstaples (4th November 2008)
Rumours about the E39 M5 pre 1998. Gustav F10 M5 Discussion 15 21st October 2009 12:11 AM
Official: BMW M5 Touring + facelift for the 5-series [New pics 16/3] Gustav E60 M5 and E61 M5 Touring Discussion 142 22nd March 2007 05:08 PM
Press Release 1: World premiere of the new BMW M5 (summary of all press releases) Gustav E60 M5 and E61 M5 Touring Discussion 0 4th July 2004 09:13 PM
Rumours about the E39 M5 pre 1998. Gustav Most Memorable Threads' 13 13th August 2002 02:29 AM
