Knowledge base on Peake codes for E39 M5 - Page 4 - BMW M5 Forum and M6 Forums
 12Likes
LinkBack Thread Tools Rating: Thread Rating: 2 votes, 2.50 average. Display Modes
post #31 of 966 Old 20th December 2007, 06:47 PM
chowdah
Super Moderator
it depends on the model year of the car. earlier takes the round connector in the engine bay; latter takes the trapezoidal connector in the driver footwell. a search in can clarify this for you.
chowdah is offline
post #32 of 966 Old 24th December 2007, 04:34 AM
Diny
Diny's Avatar
Originally Posted by Richbob View Post
I checked the Peak website, but they don't have the M5 listed when choosing which reader to purchase. Which model should I get?
This page should help you decide. If you have a black round connector about 2.5 inches in diameter (with a cap on) right below the windshield washer fluid, then you need the
R5/FCX II. Even if you have a plug above your left knee (in a left-hand drive car), you need the round connector. Ifyou dont have the round connector in the engine bay and only have the connector in the cabin, then get the R5/FCX3-16.
Diny is offline
post #33 of 966 Old 25th December 2007, 09:52 PM
Bread
Bread's Avatar
The Peake reader is a PITA to use. Small which is nice, but extremely limited. Using that list of codes, cross refrencing information. Too many ways to get confused. If you've got a BMW with an OBDII port, get a better reader.
I purchased an Innova 3100 for $100 off Amazon. It reads ALL OBDII vehicles. Showing generic and vehicle specific codes. It gives freeze frame date of vehicle rpm, speed, fuel trim and many other functions. And it displays the trouble code DESCRIPTION on the screen with the code rather than having to look it up on a piece of paper. Plus, you can leave it connected to the vehicle while you're driving and get updated codes every 15 seconds. Very cool. It payed for itself the first time I used it to diagnose and repair some bad ignition coils on my Lexus ES300. Used it on a Saturn, Mercedes CLK, and now the M5.
They have fancier models with backlit screens and more options, but overall the 3100 does 10x more than the peake reader as it is. Peake is a waste of time IMO.
Jason
'00 E39 M5, '88 E30 M3, '78 IHC Scout II, '99 Ducati 996
Bread is offline
post #34 of 966 Old 25th December 2007, 10:10 PM
Richbob
Innova 3100
Thanks for the info - I looked at the Innova, and it seems to be everything you say. My question then is: why do all the BMW forums talk about the Peake as if it were the best, and only, choice?
Richbob is offline
post #35 of 966 Old 25th December 2007, 11:23 PM
Bread
Bread's Avatar
Anything older than 96 is pre OBDII. At least it wasn't required, so you may or may not have it. In those older vehicles you're stuck with the factory BMW round connectors and the peake is the only option. Such is the case with the old E30's that I've taken a shine to over the years. But even then I wouldn't buy one. There's plenty of knowledge online as to resetting the maintenance lights with a jumper wire. The older cars are more simple to troubleshoot as well. There's a lot of good info on the web about the older bimmers.
So for me, anything with OBDII warrants a much better reader than the peake. I couldn't be more pleased with mine. Now if I could just get my reader to FIX the problem for me as well, then I'd be set and life would be easy!
Jason
Bread is offline
post #36 of 966 Old 26th December 2007, 06:42 PM
whatheheck
whatheheck's Avatar
My understanding is - it was the original code reader for BMW specific cars and the only code reader + the ability to reset Oil Change, Service Interval, Inspection 1, II codes, SES (Service Engine Soon) light, etc.
Is the Innova capable of also resetting service codes? If it can, then I'm buying one ASAP. Thanks.
And I agree, the Peake is a PITA to use. The manual is confusing to use. There has to be a better code reader and a service interval reset tool out there combined in one.
Dan
whatheheck is offline
post #37 of 966 Old 26th December 2007, 09:29 PM
Bread
Bread's Avatar
Hmm, not sure about service interval lights. It resets all stored computer codes and data, but it's not clear if that is part of the same program. It's been a while since I've seen a service interval light since using it so I'm not sure. Since my older E30 M3 and 325 don't have OBDII I've just been using the wire jumper method to clear the lights.
Jason
Bread is offline
post #38 of 966 Old 2nd January 2008, 02:50 PM
farquy
farquy's Avatar
Please help interpreting codes
Hello and Happy New Year to all.
Here is the problem.
I was driving down the autobahn, at about 130 mph with a car full of people when I lost loads of power (with my foot full on the gas pedal the car decelerated to below 4k RPM) and the SES light came on.
Luckily it happened at my exit, so I slow down come down the off ramp and stop at the traffic lights. While waiting for the TL to turn green the SES light went out again (it was on less than 2 mins)
The remainder of the drive home (15 -20 miles) was fine. Being new year's day I had to wait till today to take the M5 to the dealers to get the codes read (as I don't have a peake reader)
(Earlier that day I filled up the car with v-power 100ron petrol. I normally use 98 but have used v-power before with no problems. Just adding this info as it was the only different event for the car in a while)
The codes I got were "CB (203)", "51 (081)" and "AA (170)
With my limited German and the technicians limited English the explanation wasn't great of what all the codes meant.
He put a star next to the "AA (170)" and said this was the important one. He pointed to two parts on the engine and said he needed to change them (costing 100 Euro). He couldn't explain what the were in English and I don't know what they are so for the sake of this post I have pointed them out in the attached picture.
Could someone here please help me to understand what went wrong with the car, what the parts are that need to be changed and what other rectification needs to be done.
Thank you all.
Farquy
03/2001 Carbon Black ///M5
MKIV Nav
Complete speaker upgrade
DICE IPOD Integration
Brembo BBK
Bimmernav Bluetooth retrofit.
V3.0 Angle ibright (blue)
Angle ibright xenon match fogs
Angle ibright xenon match mains
Previous Cars (worth talking about)
E90 325i M Sport Black on black
E34 M5 Black on Black
E36 328i Black on grey
Ford Capri 2.8 injection White with a Black stripe
farquy is offline
post #39 of 966 Old 2nd January 2008, 07:51 PM
chowdah
Super Moderator
Presuming those first codes are peake: CB is cyl #8 misfire, 51 is MFL interface signal, AA is secondary air flow too low.
Before you panic over reading about the AA (search on "secondary") you should realize this is a false positive sometimes.
The parts you circled are here (whether they are applicable to your problem, I can't say).
http://www.realoem.com/bmw/showparts...53&hg=11&fg=15
chowdah is offline
post #40 of 966 Old 2nd January 2008, 08:38 PM
farquy
farquy's Avatar
Thanks chowdah, the tech did mention the parts to be changed had something to do with the oil system.
I did look at the table at the top of this thread but what I don't understand is what would cause a cylinder, no 8 in my case, to misfire and what does MFL interface signal mean and once again what would cause a code?
If my translation is ok then it has something to do with the multi function steering wheel. (multifunktionslenkrad) Maybe as I have recently been trying to put a retrofit bluetooth system in and for the first time the voice recognition button works but this is a wild stab in the dark.
farquy
MKIV Nav
Brembo BBK
farquy is offline
Rumours about the E39 M5 pre 1998. Gustav F10 M5 Discussion 15 21st October 2009 12:11 AM
Official: BMW M5 Touring + facelift for the 5-series [New pics 16/3] Gustav E60 M5 and E61 M5 Touring Discussion 142 22nd March 2007 05:08 PM
Press Release 1: World premiere of the new BMW M5 (summary of all press releases) Gustav E60 M5 and E61 M5 Touring Discussion 0 4th July 2004 09:13 PM
Rumours about the E39 M5 pre 1998. Gustav Most Memorable Threads' 13 13th August 2002 02:29 AM
