Please post Blackstone Labs oil reports OTHER than TWS 10W60 or BMW 5W30 here - Page 4 - BMW M5 Forum and M6 Forums
 1Likes
post #31 of 42 Old 20th June 2013, 05:19 PM
Diny
Diny's Avatar
Here's a pictorial report of what happens when you don't use 10W60
Fighting Oil Threads since 2007
Diny is offline
post #32 of 42 Old 20th June 2013, 05:29 PM
SidekickChuck
SidekickChuck's Avatar
lol
Well I will hopefully be performing another oil change here shortly. Still on my first batch of Eneos 0w50 at 5k miles. Will be changing the oil with Eneos again, and running it for another 6-7k miles before sending off samples to Blackstone. I did not want to send them a slight mixture of my previous oil with the Eneos.
2001 BMW e39 M5
Eisenmann Race Exhaust
SS X-Pipe resonator delete
Powerchip Tune
South Bend Stage II Endurance Racing Clutch
CNS Lightened Flywheel
KW Variant 3 Coilover Suspension
RDSport 19" RD2
AC Schnitzer Type II Racing 19x9.5F 19x10.5R
Latest Photos
SidekickChuck is online now
post #33 of 42 Old 20th June 2013, 05:33 PM
JohnAnthony
JohnAnthony's Avatar
Originally Posted by bmwMcrzy View Post
Where's JohnAnthony to post up some graphs?
man i missed this call out
the russian thing would make a great addition to my thread on Oil Bottles...ARAL TRONIC bottles FTW
everyone better switch to BMW 5W40 & QUARTZ/TOTAL 10W40... suggested the moderator with heavy sarcasm
JohnAnthony is offline
post #34 of 42 Old 21st June 2013, 05:45 PM
SleeperM5
Originally Posted by SleeperM5 View Post
Interesting read...I switched from Mobil 1 5w30 extended performance due to concern over bearing wear. The new report reveals some better numbers and consumption dropped dramatically.
I get 5 L of LiquiMoly 10w60 for $40, so it's a very affordable change.
Here is the re-uploaded report.
SleeperM5 is offline
post #35 of 42 Old 8th September 2015, 06:23 AM
robinhood
robinhood's Avatar
Hi,
I've read a previous article on MOTUL V300 with Snogard & Lscman but it's dated 2007 so I prefer to post this test here :
Comparatif huiles moteur, Royal Purple, Motul, Castrol? - Renox France
It's in french but you can use Google translate to understand the main ideas...
MOTUL 300V 15w50 isn't good, even for short term protection (compared to other tested), as you can see with the Timken test.
it's not graph or oil analysis report but I though you'd find this interesting.
Robin
1999 E39 M5 70k miles Japan Euro Spec LHD Import
robinhood is offline
post #36 of 42 Old 8th September 2015, 07:18 AM
robinhood
robinhood's Avatar
Also, below is the link of a oil analysis :
TEST ADDITIF HUILE ECOTEC T2S - AutoMotoConso.com
Look at the right column, it's 10 000kms oil test with the product Ecotec T2S. Last line is wear particule indice.
you can see the same kind of resistance test with this product below :
https://youtu.be/IxTjEyhmZPQ
Maybe the kind of product used in RP HPS oil to get its extreme protection.
Personnaly, I'm using this product in all my cars including the E39 M5 for engine & gearbox. (Yes, it's not OEM, but !)
Robin
post #37 of 42 Old 12th February 2016, 02:06 AM
swingwing
swingwing's Avatar
Here's my current oil analysis on 5K miles on AMSOIL Premium Protection 20W-50. Sample #1 in report is the baseline on TWS 10W-60 oil change done by PO. I bought my car in Nov 2014 and have been working steadily on it. Applicable items have been fuel filter, spark plugs, all four O2 sensors; just before sample #2 drawn I replaced all CPS and VANOS solenoid seals.
My current opinion is that this oil is providing excellent protection. Engine runs fine but I need to get it out more on longer, harder drives - the last time I did the fuel mileage was much better than the 16-17mpg I get in "around town" driving. I have yet to address changing the thermostat and MAFs.
swingwing is online now
post #38 of 42 Old 7th April 2017, 03:53 AM
boostmiser
boostmiser's Avatar
oops, revived wrong thread
The Upgrades: Dinan Stg. 1 / Dinan RSB / TCD Sway Bar Brackets / UUC Evo III SSK / UUC DSSR / UUC Tranny mounts / MKIV Nav Unit / JL 500.1 Amp / JL 12w6v2 Sub
boostmiser is online now
post #39 of 42 Old 22nd May 2017, 11:13 PM
uhad2point
uhad2point's Avatar
Liqui Moly 10w60. No idea how many miles were on it or how much oil was added; it was the oil that came in the car when I bought it. Car has 146k miles, MY2000:
WILLIAM: Thanks for the notes. We didn't find any extra bearing wear in this sample. In fact, lead is below
average at 1 ppm, so the bearings in this S62 appear to be getting along well. You mentioned some oil
consumption too, but if the engine only used a quart over 5,000 miles that sounds pretty normal. Something
like a quart per 1,000 miles would be more worrisome, and we'd just keep an eye on how much oil the
engine is losing. The flashpoint being above the expected value shows no measurable amount of fuel. The TBN of 9.7 is well above our 1.0 lower limit.
ALUMINUM 3
CHROMIUM 0
IRON 7
COPPER 3
LEAD 1
TIN 0
MOLYBDENUM 25
NICKEL 0
MANGANESE 1
SILVER 0
TITANIUM 4
POTASSIUM 1
BORON 36
SILICON 5
SODIUM 2
CALCIUM 2506
MAGNESIUM 13
PHOSPHORUS 905
ZINC 1035
BARIUM 0
SUS VISCOSITY @ 210*F 87.1
cSt Viscosity @ 100*C 17.27
Flashpoint in *F 405
Fuel % <0.5
Antifreeze % 0.0
Water % 0.0
Insolubles 0.2
TBN 9.7
uhad2point is offline
post #40 of 42 Old 5th December 2018, 03:59 AM
SleeperM5
Red Face Latest LiquiMoly 10w60 analysis
From Blackstone:
If you did something differently on this fill compared to last time, keep it up - nickel and silicon both
dropped out of cautionary ranges, and the small amount of fuel we'd been seeing for the last four years has
cleared up. With the absence of highlights, this M5 has earned its first perfect report, and we see no issues
with how this engine's operating. Besides having no fuel, there was no other measurable contamination,
either, and viscosity was fine for 10W/60 grade oil. Air and oil filtration both look great. Good-looking BMW
at just under 150,000 total miles.
Please post Blackstone Labs oil reports TWS 10W60 here DavidS E39 M5 and E52 Z8 Discussion 60 10th October 2016 04:08 AM
Oil Type - BMW Manuals JFB M5 E39 and E60 tips & tricks 10 23rd October 2008 10:35 AM
Best source for 10-60 synthetic?? CBarton E39 M5 and E52 Z8 Discussion 18 25th February 2006 02:30 AM
BMW M Manager Bruhnke at Stockholm Open, Sweden and answer to your questions Gustav E63 BMW M6 Forum and BMW M6 Convertible | m6board.com 51 25th March 2005 05:14 PM
WSJ article : "BMW's Push to Broaden Line" howler E39 M5 and E52 Z8 Discussion 15 13th January 2005 05:50 PM
