Good news, Bad news? Not clutch but.... - BMW M5 Forum and M6 Forums
post #1 of 10 Old 29th November 2005, 11:35 PM Thread Starter
lsdvm
lsdvm's Avatar
Angry Good news, Bad news? Not clutch but....
Well, I got another call from the SA today letting me know that the problem isn't the clutch, but rather that the drive shaft is somehow "separating from the differential...hence no lockup and total loss of power".
They plan on opening up the diff tomorrow to see what's going on, and what part(s) failed and then they'll let me know what comes next.
I called my independent shop to run this by the head guy, and he thinks this is BS...and is probably due to the fact that the driveshaft wasn't bolted on correctly, and the whole clutch job may have been botched to begin with.
Anyone have any thoughts on this? I know our drive shaft is bolted onto the diff with 4-5 relatively large bolts which should not shear, break or separate with normal use...especially after only 30K miles!!
More importantly, should I be concerned that there may be a problem with the clutch/trans secondary to the diff-drive shaft problem...or whatever the he!! they're calling it?
How strongly can I push to have this taken care of by BMW given that the car is outside the factory warranty period?
'01 M5
Titanium Silver/Black/Imola red extended leather, Hardwired V1, custom CAI, 35% window tint, 4300K fogs, Silvervision indicators, SuperSprint exhaust with X-pipe, CCFL angel eyes, Euro lock delete...
'07 - E63 AMG - Blk/Caramel - "The Loaner"
Ayecaramba!!!
'00 Passat GLX
Daily driver
lsdvm is offline
post #2 of 10 Old 30th November 2005, 12:55 AM
Stickman
Stickman's Avatar
Re: Good news, Bad news? Not clutch but....
This sounds really strange. I'd wait for more information as they dig deeper. But I think you are right to be questioning everthing.
Stickman is offline
post #3 of 10 Old 30th November 2005, 01:00 AM
mottati
mottati's Avatar
i thought the original problem was the trans got stuck in gear, right? how does a diff problem cause that..... smells like.....
94 M5 Touring Madeira Schwarz, Black 10/93 production
84 728i - M88 powered
mottati is offline
post #4 of 10 Old 30th November 2005, 04:01 PM Thread Starter
lsdvm
lsdvm's Avatar
Mottati - the original problem was clutch, then when they changed it, it was tough to get the trans into 1-2-R...so I brought it back and they bled the clutch reservoir. This supposedly "fixed" the problem for a few hours...but later on that evening, the clutch failed again after 60 miles...now they're telling me the problem's not the clutch but where the drive shaft meets the diff...I've asked for a schematic with specifics and will ask that a BMW rep look at it to determine exactly what the hell is going on...I'll add more info to the post when I hear back from them later on today.
Thanks guys.
LS
'01 M5
Ayecaramba!!!
'00 Passat GLX
Daily driver
lsdvm is offline
post #5 of 10 Old 30th November 2005, 06:23 PM
gsfent
gsfent's Avatar
Hey, anything is possible, it is often hard to tell about a problem from a keyboard. However, my confidence level is this dealership would not be very high.
Even if they forgot to bleed the clutch (didn't know the hydraulic system had to be opened to replace the hardware), which is error #1, they didn't even bother to road test the car after replacing the clutch?? Error #2. And if they did, they didn't feel how difficult the gear box was to shift? Error #2a. While the car is on the lift, most mechanics will look to make sure everything is tight and suspension looks good. Loose diff bolts?? Unlikely, but if so, they missed that. Error #3. Flex disc? Possibly, takes 15 seconds to inspect. Error #3a.
Hard shifting is either tranny linkage out of adjustment, or clutch not properly disengaging (for a variety of reasons). After the diagnosis is made but before the covered repairs are made, I would have a discussion with the SA and the Service Manager about the skills of your tech. On a "bring back", typically it will be the same technician to redo the work. I think you want someone else and you want to know that tech's experience with cars in general, and M cars in particular. My $.02 (at least!!).
Dinan Stage 3 suspension, SS jet coated headers, ESS SC kit w/ 1 range colder NGK's, 92mm pulley, 440 Big Greens, TTFS alpha N tune for meth, RK plenum plates, SBC Endurance Stage 3 Kevlar performance clutch setup, "Jed" lightened DMFW, open brake ducts, TEC cupholder, U.S.(Euro style) tilt/slide armrest, 6k HID fogs, Umnitza bi-xenon flamethrowers w/6k super white low beams, rear fogs, V1/Stealth1, dual head LI, 2.65 diff w/40% lockup/2x dynamic, compact spare, M5 logo trunk carpet, Euro trailer hitch, Mocal oil cooler, ACS type rear spoiler, Rogue custom SSK and tranny mounts, ST 355 BBK (fronts), BP sway bar brackets, Bluetooth retrofit, Speedhut boost gauge (20 psi), Dinan TB's and VS, KB BAP, Howerton/HFS-3 Aquamist WI trunk setup (50/50), with 2nd gauge in rear view mirror, aftermarket trunk mounted sound system integrated into stock unit (amps, crossovers, sub and speakers).......
gsfent is online now
post #6 of 10 Old 30th November 2005, 07:24 PM
Need4Spd
Need4Spd's Avatar
I agree with Jerry. As for the quoted comment, I think it does have to be opened up because the slave cylinder is on the transmission case, and the case has to be pulled to change the clutch.
Need4Spd
'01 M5 (now my brother's car) UUC SSK + Rogue WSR/RE Tranny Mounts+Royal Purple Synchromax/Axxis ULT Pads/StopTech SS Lines/TC Design from BeastPower Anti-roll Bar Brackets/Dinan LtWtFlywheel and Stage 3 suspension/4xOEM rear 275 Goodyear F1 Asymmetrics/Vines thrust arms/IATS relocation/10w-60 oil/hardwired Escort 9500i/Euro Armrest/TEC Cupholder/IceLink/PowerChip 91 Gold/TUBIs!/Strong Strut/BSW Stage 1/BT/Angel iBrights 3.0/space-saver spare by Bimmerzone
'11 Jaguar XFR, Quicksilver exhaust, Escort 9500ci
Unnamed weekend Italian 2 seater with DCT
Future - F10 M5 with manual transmission?
Need4Spd is offline
post #7 of 10 Old 30th November 2005, 07:41 PM
emccallum
emccallum's Avatar
ISDVM,
Having just replaced my clutch, and only going by what you have written, I would offer these thoughts. To remove the tranny the driveshaft must be partially removed. Three large bolts at the tranny (guibo) and two bolts at the center bearing (in b/n the tranny and diff. The driveshaft connects to the diff via a cv joint like a front wheel drive car half shaft. You must support the driveshaft when it is unbolted in order to avoid damaging the cv joint. Also, during installation, the center bearing must be properly aligned to keep the driveshaft running true, if not it could wearout the center bearing and cause the driveshaft to wobble, usually a banging noise like a bad u joint. If the cv joint failed, which is where the driveshaft enters the diff, my guess is it was from not supporting it properly during tranny removal. The BMW manual is very explicit about this. FWIW, older bmw's used to require a preload on the center bearing during installation, they dont anymore. It is possible to bolt the center bearing in upsidedown, but I dont think you can get the heat shields on over it. Just some food for thought. If it were me I would want to look at the car closely on the rack as the disassembled it. Sounds to me like something wasnt done right, like tightening the center bearing bolts or not supporting the driveshaft.
ernest
emccallum is offline
post #8 of 10 Old 1st December 2005, 08:40 PM Thread Starter
lsdvm
lsdvm's Avatar
Re: Drive shaft and diff out of sync??
Emccallum - thanks for the technical advice. My gut tells me something wasn't done right the first time around...hence my predicament. I received a call from the SA today, and he indicated that they have to order a new part (where drive shaft enters diff)...which will bein tomorrow and hopefully everything will be fine from there.
He mentioned something else which I thought was completely odd...that the drive-shaft was engaging-disengaging from the diff just by being jolted. Is this even possible?? I thought these things were tightly bound together by bolts and casing??
I've asked for the schematic of what failed, but they're hesistant to fax it to me. I'll have to wait until Sat AM to go and see this whole fiasco for myself.
I wish someone would just come out and say they screwed up...guess that's too much to ask these days?? Such a shame.
Originally Posted by emccallum
ISDVM,
ernest
'01 M5
Ayecaramba!!!
'00 Passat GLX
Daily driver
lsdvm is offline
post #9 of 10 Old 2nd December 2005, 12:10 AM
emccallum
emccallum's Avatar
Cant speak for the tech. But it doesnt sound good. Are you getting a new driveshaft, has the center bearing been damaged? You can go to realoembmw.com (I think that is right) and they have the parts cd online that will show you how it all fits together. If they are footing the bill, then be nice and insist it is right, if you are footing the bill ask for all the parts, so you can see what is going on. You are buying the ticket ask to see the show! Best of luck.
post #10 of 10 Old 2nd December 2005, 01:13 AM
ard
ard's Avatar
www.realoem.com/bmw
or
http://www.realoem.com/bmw/select.do
close...
A
ard is offline
just had clutch replaced and... m5jmh E39 M5 and E52 Z8 Discussion 30 21st October 2008 11:55 PM
Teach wife how to drive stick on M5? good or bad idea? E39 MFIVE E39 M5 and E52 Z8 Discussion 40 26th August 2005 04:36 AM
we have a NEW CLUTCH OPTION! dbox E39 M5 and E52 Z8 Discussion 34 23rd February 2005 05:54 PM
Stage 3 (6-puck ceramic) clutch 1st impressions 1badm5 E39 M5 and E52 Z8 Discussion 11 2nd November 2004 09:00 PM
good news and bad news Dr.Mike E39 M5 and E52 Z8 Discussion 9 11th January 2001 06:41 AM
