Coolant Change Bleeding Process Clarification - BMW M5 Forum and M6 Forums
 1Likes
  • 1 Post By roarf
post #1 of 4 Old 3rd July 2019, 08:02 PM Thread Starter
TBONE1
Hello All: after the drain/refill is complete, with turning heater on high heat/low power and getting engine to normal operating temps:
1) are these done simultaneously
2) is the expansion tank cap ON or OFF during this process
I have seen conflicting suggestions on this and just looking for some guidance before I tackle this.
Thanks!
TBONE1 is offline
post #2 of 4 Old 4th July 2019, 03:31 AM
roarf
roarf's Avatar
You really don't have to bleed an E39 M5 since the expansion tank is the highest point in the system. I don't even think there is a bleed screw. The way I've done it is to turn the key to run (engine off) and set the heat to max so the heater valve opens all the way and the aux water pump is running. Then just fill slowly until it's at the full cold mark. Put the cap back on and go drive it and get it warmed up all the way. Then recheck the coolant level after the car has sat overnight and had a chance to fully cool down.
'14 Evora S - Chrome Orange/Ebony
'02 M5 - Carbon Black/Silverstone
'01 M3 - Imola Red/Black (gone but not forgotten)
'08 RS4 - Imola Yellow/Black (gone but not forgotten)
roarf is online now
The Following 2 Users Say Thank You to roarf For This Useful Post:
TBONE1 (4th July 2019)
post #3 of 4 Old 5th July 2019, 07:32 AM
chowdah
Super Moderator
I followed this advice. IIRC had the cap on but since I was stationary off probably would have also worked. Definitely recheck and monitor no matter which way you do it.
https://www.m5board.com/vbulletin/e3...ml#post1730487
chowdah is offline
The Following User Says Thank You to chowdah For This Useful Post:
TBONE1 (5th July 2019)
post #4 of 4 Old 6th July 2019, 01:34 PM
technician117
technician117's Avatar
Agree with above... you don't need to do anything IMO. I just replaced my t-stat a few weeks back. All I do is fill it to the line, start it up and while it's warming up I just make sure the tank stays pretty much topped off. Then I do a test drive, park it overnight so it's fully cooled down and then top the tank one last time. This method has always worked for me.
Tim
2013 M5 Imperial Blue/Silverstone II, 6MT 64k miles
2000 Anthracite daily driver
UUC dssr and shifter
Supersprint headers with Tubi catback
Jailbreak tuning
Dinan 3.45 JED lightened flywheel
286,000 miles and counting
'00 Imola/Imola 107k stock
'00 Silverstone/Silverstone 129k (SOLD)
technician117 is online now
