With Summer in full swing, what should we do for our Ms? - BMW M5 Forum and M6 Forums
 2Likes
  • 2 Post By mech9t8
post #1 of 8 Old 29th June 2019, 07:10 PM Thread Starter
ryanman
ryanman's Avatar
Hi all. This is the second summer I've been driving my M around and I wanted to toss around ideas for things to do that'll ensure the fickle cooling system on these things is working really well.
What we know so far is the Cadillac option of replacing the radiator assembly with a Zionsville model. From what I understand, the actual cooling performance of these things is still going to be just on-par with the existing system for normal driving, but presumably more longevity compared to the OEM system.
There's a thread on improving cooling for track days. The problem here would be that I'd consider a lot of these relatively extreme - installing new oil coolers, ripping out foglights, etc.
2 recent events got me thinking about doing something with the system: A close-to-overheat event while attempting to teach someone stick (the car frequently starting in an isolated position), and high temps on an extremely hot (~95F) standstill traffic situation. The system was overhauled with all-OEM parts probably 3 years ago at this point, which makes me think the latter situation at least shouldn't be happening.
So some concrete questions:
  1. What are typical/acceptable fluid temps? I've installed a new Head Unit with the I-Bus App and my coolant supposedly hovers around 100C according to it. This is when my coolant temps are in the dead center of the gauge. I'm wondering if I need to calibrate the app?
  2. What preventative maintenance (as opposed to new equipment) do you do for the system? What's your go-to fluid mix?
  3. Any other first hand experiences with non-OEM parts or solutions? I'm the "OEM was 20 years ago" type of owner, and think that often some of the issues in these cars have been solved with revisions or creative solutions in the aftermarket.
02 LeMans Blue - CLT
ryanman is offline
post #2 of 8 Old 29th June 2019, 08:03 PM
mech9t8
mech9t8's Avatar
Does your aux fan work? I owned my car for 4 years and didnít even realize it was fried. Only reason I checked was because my coolant temps got high while idling. I do notice lower temps now that the fan has been replaced.
mech9t8 is online now
post #3 of 8 Old 29th June 2019, 08:14 PM
gsfent
gsfent's Avatar
Coolant temps are pressurized, so I wouldn't worry about overheating. But the aux fan should be running with the AC engaged. There is also an upgrade for the mechanical fan, someone recently did a write-up. That would help at low speeds. I believe it was an E60 fan with more blades.
Dinan Stage 3 suspension, SS jet coated headers, ESS SC kit w/ 1 range colder NGK's, 92mm pulley, 440 Big Greens, TTFS alpha N tune for meth, RK plenum plates, SBC Endurance Stage 3 Kevlar performance clutch setup, "Jed" lightened DMFW, open brake ducts, TEC cupholder, U.S.(Euro style) tilt/slide armrest, 6k HID fogs, Umnitza bi-xenon flamethrowers w/6k super white low beams, rear fogs, V1/Stealth1, dual head LI, 2.65 diff w/40% lockup/2x dynamic, compact spare, M5 logo trunk carpet, Euro trailer hitch, Mocal oil cooler, ACS type rear spoiler, Rogue custom SSK and tranny mounts, ST 355 BBK (fronts), BP sway bar brackets, Bluetooth retrofit, Speedhut boost gauge (20 psi), Dinan TB's and VS, KB BAP, Howerton/HFS-3 Aquamist WI trunk setup (50/50), with 2nd gauge in rear view mirror, aftermarket trunk mounted sound system integrated into stock unit (amps, crossovers, sub and speakers).......
gsfent is offline
post #4 of 8 Old 30th June 2019, 05:02 AM Thread Starter
ryanman
ryanman's Avatar
I'll double check it today for sure, but I kind of assumed if most the time my temps were rock solid/stable then it would be going for me.
ryanman is offline
post #5 of 8 Old 30th June 2019, 12:13 PM
sweeney921
I have a long commute with both standstill and highway cruising, so as the weather gets hotter I've kept a close eye on KTMP. Once the car ia fully warmed up with A/C on the KTMP hovers around 88-91 at idle and 84-86 on the highway. Turning the A/C off brings those temps down about 3 degrees. Should I be concerned that they're too high?
I've recently replaced the water pump, fan clutch, and thermostat (79C). I've also removed all of the debris from around the outside of the radiator and reverse-flushed it.
Sent from my VS988 using Tapatalk
sweeney921 is offline
post #6 of 8 Old 1st July 2019, 04:55 PM
caslvre39
Bad fan clutch? Idling with oil temps hot it should be pulling a lot of heat, you can really feel the airflow and heat.
Thise temps are fine, i like redline watter wetter. Didn't keep track but the needle seem to be on the cooler side after adding it.
caslvre39 is offline
The Following User Says Thank You to caslvre39 For This Useful Post:
sweeney921 (1st July 2019)
post #7 of 8 Old 3rd July 2019, 12:11 AM
curtissp321
curtissp321's Avatar
Had a shock with mine a few weeks ago - hot day in UK, 28-30 degrees C.... just done 100 miles on motorway and was driving last few miles around local roads to office when engine overheat message popped up and I notice needle was climbing rapidly towards red... pulled over and switch off, checked around engine bay and all looked ok. Restarted and it seemed ok and idled without overheating. I had AC on which didnít help.
Further testing shows my aux fan is toast - not working at all despite only being replaced 4ish years ago. Crap design does not seem to last at all.
So Iíd check your aux fan and make sure itís working - if it is your car will stay cool in virtually all circumstances.
Simon
curtissp321 is offline
post #8 of 8 Old 3rd July 2019, 01:52 AM
mech9t8
mech9t8's Avatar
Simon
What was the brand of the fan? Could it be the fuse?
Tags
cooling system
