secondary fuel pump? - Page 2 - BMW M5 Forum and M6 Forums
 2Likes
post #11 of 13 Old 3rd July 2019, 07:33 PM
Sailor24
Sailor24's Avatar
Sailor24 is offline
post #12 of 13 Old 3rd July 2019, 09:13 PM
Freude_am_Fahren
Originally Posted by Sailor24 View Post
? Vacuum pump?
You are justifiably surprised seeing an 'air pump for vacuum control' in my list. Didn't do a detailed check on the Realoem 'list', until now.
At Realoem plot (Engine > Air pump for vacuum control, see the link below), you can see that only the electrical (PWM) control valve 11747810831 plus some attached hoses are highlighted. That valve is hardly to be called a 'pump' ...
https://www.realoem.com/bmw/enUS/sho...diagId=11_2671
Line #4 in the above plot is attached to one of the carburetor housings, the provider of the vacuum. No need for a vacuum pump on the S62B50 indeed.
Line #9 is attached to the shut-off valve (#8, 11721433713) of the secondary air pump, I guess? Not a pump either.
Freude_am_Fahren is offline
post #13 of 13 Old 5th July 2019, 05:42 PM
Blockdoc
Blockdoc's Avatar
Originally Posted by Freude_am_Fahren View Post
No high pressure fuel pump on the engine/ in the engine bay of the S62B50. It is only present on diesel engines like:
E39 type ------------ Engine type -- HP-fuel pump BMW-no.
E39 520d ----------- M47 ---------- 13517787532
E39 525td or 525tds M51 ---------- 13512244966
E39 525d or 530d -- M57 ---------- 13517787632
The S62B50 engine however does have several other pumps in the engine bay. Maybe you meant one of these:
Lubrication system oil pump
Lubrication system compressor
Emission control air pump
Semantics. I did not mean later model E39, and after rereading my post, I see the confusion. I meant later model BMWs. I am specifically talking about the N54 and S55 engines. My point being that the E39 is becoming old enough that many shops don't see them nearly as often as the F series, so that an assumption is somewhat understandable. That was my only point
2003 Sterling Grey M5 SOLD
ESS kit #1 with RK AUTOWERKS Upgrade! (RK/EVO software, Injectors, Fuel Pump)
Dinan Free Flow Exhaust, Dinan Rear Sway Bar
Super Sprint Headers
Rogue Octane SSK and WSR
DICE Ipod connectivity
Bimmian Black Kidney Grilles
Ultimate Pedals
Rear Wheels Up Front (275s all around)
Aquamist HFS3/Howerton Engineering Tank (pre/post SC nozzles)
RK Autowerks CNC Plenum Plates
2015 M4 Coupe DCT (BootMod flash Custom Paul Johnson Tune, downpipes, Methanol 100 percent , E30 map, Pure Turbos 700WHP+, 295/275 tires with Vorsteiner wheels)
2018 Jeep Hellcat Trackhawk (707HP Supercharged)
Blockdoc is offline
