92mm pulley question ESS Re: Belt - BMW M5 Forum and M6 Forums
post #1 of 3 Old 16th June 2019, 02:41 PM Thread Starter
sayanthan
Hi what belt length are people running
The original kit with the 96mm pulley came with a 6pk1509
ESS recommended the same length for the 92mm pulley , but when this was tried it was too loose.
A 6pk1503 was fitted which seemed tight
However it has completely slipped off!
When I had a look thereís a tiny amount of play in the tensioner pulley - is this normal and Iím wondering if this might be the cause? Or do I need a different belt length? Iím using gates.
2002 BMW E39 M5
2019 BMW M4 30th Ed Jahre Vert
Sent from my iPhone using Tapatalk Pro
sayanthan is offline
post #2 of 3 Old 26th June 2019, 06:14 PM
ECB
ECB's Avatar
I used a 1510 belt with the 92mm pulley. That was the one supplied by ESS when I ordered the pulley. Sounds like your tensioner pulley could be part of the issue. Good luck!
03 M5 Titanium Silver/Black Luxury/Burl Walnut
ESS VT 550 S/C 88mm pulley, Supersprint headers and Race cats, Eisenmann Sport Exhaust, Nick G / CES Motorsport tune,
Aquamist HFS-3 water methanol injection, Rogue SSK w/ RP Synchromax fluid, fog light delete,
H&R Springs, Dinan 17mm rear sway bar, TCD sway bar brackets, Ultimate Pedals, Euro Armrest,
Hardwired V1, Angel iBrights v.2, 6000K Low beams, 70W High beams,BSW Speaker Upgrade & 10" Sub
04 M3 Jet Black/Black Nappa/6 spd
Max PSI Turbo, Aquamist HFS-3 water methanol injection
Rogue Exhaust dump valve, Eisenmann Race Muffler
Rogue SSK, H&R springs, Koni Yellows, Squared 18's
07 Porsche 911 Turbo/Slate Gray/6 spd
ECB is offline
post #3 of 3 Old 27th June 2019, 01:23 AM
Trevor7008
Trevor7008's Avatar
Trevor7008 is offline
