e39 M5 sss program cannot find zcs file help - BMW M5 Forum and M6 Forums
post #1 of 5 Old 9th June 2019, 05:16 PM Thread Starter
e39_frap*
Hi,
My 2000 M5 that I recently purchase I cannot code the new abs module since only 3 module show from ncs expert EWS KBI AND IKE nothing else.. so I can’t code the dsc with ncsexpert and from sss progman he doesn’t find zcs file and cannot load.
Should I try to code the zcs file first?
e39_frap* is offline
post #2 of 5 Old 15th June 2019, 01:01 AM
Maguiver
Maguiver's Avatar
Maguiver is online now
post #3 of 5 Old 15th June 2019, 11:24 AM Thread Starter
e39_frap*
I try with the odb port, I not so sure but I think it wouldn't even let me start a session with the pacman connector, but I will try again today and paste some screenshot.
post #4 of 5 Old 15th June 2019, 04:23 PM
Maguiver
Maguiver's Avatar
post #5 of 5 Old 18th June 2019, 06:31 AM
Sailor24
Sailor24's Avatar
If you are using the OBD port you will not have data from some of the modules UI. You need to add these jumpers from what I understand, I use the round plug under the hood because it seems way more convenient but is the designed UI.
Name:  obd bypass-Read in car plug2.jpg
Sailor24 is offline
