Brake booster needs replacing - BMW M5 Forum and M6 Forums
post #1 of 10 Old 7th June 2019, 05:26 AM Thread Starter
zazbeam
zazbeam's Avatar
Booster sucked water while drain was plugged. You've heard the story before. I let it dry up and have driven it about a year and a half with no problems... Until now.
Anyway, I don't know if I have the diy skills/ ability to do the job. There's something about the brake fluid, master cylinder etc that makes me nervous and I need it done right.
How many hours of labor am I looking at at an Indy shop you think?
Thoughts?
Thank you!
zazbeam is offline
post #2 of 10 Old 9th June 2019, 02:37 AM Thread Starter
zazbeam
zazbeam's Avatar
zazbeam is offline
post #3 of 10 Old 11th June 2019, 07:52 PM Thread Starter
zazbeam
zazbeam's Avatar
zazbeam is offline
post #4 of 10 Old 11th June 2019, 09:05 PM
OjaiM5
Im going to just guess $500-$750
you have to figure they are going to mark up the parts and charge at least 2 hrs labor and a brake bleed.
OjaiM5 is online now
post #5 of 10 Old 12th June 2019, 08:32 PM Thread Starter
zazbeam
zazbeam's Avatar
zazbeam is offline
post #6 of 10 Old 12th June 2019, 08:38 PM
OjaiM5
De nada!
I think you can do it your self, especially if you get a pressure bleeder and some flare nut wrenches, might not even need these. There are some good DIY videos and post to guide you.
I did mine not that long ago and as far as projects go it was pretty simple.
Cool you have a Buick GS, I have owned many muscle cars. Probably why I like the M5 so much, total German Muscle car.
post #7 of 10 Old 12th June 2019, 09:36 PM
hsulei1
Hi, I had this issue happen to me about a month ago. I managed to suction the water out and all is well now. What kind of issues are you having at this time? I plan on replacing mine but was wondering what the long term effects were. Thanks
hsulei1 is online now
post #8 of 10 Old 16th June 2019, 01:38 AM Thread Starter
zazbeam
zazbeam's Avatar
Yea you are kinda right. Bought the GS in socal back in 2000 because I wanted a V8 four seat convertible. The car is frickin awesome... Ended up needing a car after I sold my truck so in 2015 I went looking for a V8 powered sedan WITH a manual transmission... Ended up with the M5, and bought it coincidentally in the same town in socal. Meant to be? I don't know, but the cars seem compliment each other in a really cool way. : p
2003 M5 mostly stock
1969 Buick GS 400 convertible
zazbeam is offline
post #9 of 10 Old 16th June 2019, 01:42 AM Thread Starter
zazbeam
zazbeam's Avatar
My booster went out about 2 years ago and while it did dry out, during the last month or two the car has showed symptoms of the booster going bad occasionally when I first start to drive it. Vacuum lines are good but I just feel like the diaghram inside the booster got wet, then dried out and seems to have now lost its pliability thus not sealing the vacuum needed to brake the car normally. It will slowly get worse I think.
zazbeam is offline
post #10 of 10 Old 16th June 2019, 03:31 PM
gsfent
gsfent's Avatar
If you are going to have to bleed the brake system anyway, consider doing the master cylinder at the same time. Great discussion on a recent thread about using the E60 master cylinder for improved brake feel.
Dinan Stage 3 suspension, SS jet coated headers, ESS SC kit w/ 1 range colder NGK's, 92mm pulley, 440 Big Greens, TTFS alpha N tune for meth, RK plenum plates, SBC Endurance Stage 3 Kevlar performance clutch setup, "Jed" lightened DMFW, open brake ducts, TEC cupholder, U.S.(Euro style) tilt/slide armrest, 6k HID fogs, Umnitza bi-xenon flamethrowers w/6k super white low beams, rear fogs, V1/Stealth1, dual head LI, 2.65 diff w/40% lockup/2x dynamic, compact spare, M5 logo trunk carpet, Euro trailer hitch, Mocal oil cooler, ACS type rear spoiler, Rogue custom SSK and tranny mounts, ST 355 BBK (fronts), BP sway bar brackets, Bluetooth retrofit, Speedhut boost gauge (20 psi), Dinan TB's and VS, KB BAP, Howerton/HFS-3 Aquamist WI trunk setup (50/50), with 2nd gauge in rear view mirror, aftermarket trunk mounted sound system integrated into stock unit (amps, crossovers, sub and speakers).......
gsfent is offline
