Clutch kit from RMS - BMW M5 Forum and M6 Forums
 2Likes
  • 2 Post By Silent
post #1 of 4 Old 6th June 2019, 07:13 PM Thread Starter
mustuning
Clutch kit from RMS
good evening gents...
I bought clutch kit (STAGE 3) from RMS (race marque systems) , when i recieved the kit i found it CM (clutch masters) , was stage 2 but they charge me for stage 3 , i have seen the same kit in CM web site the price was around 200-300$ less.
I try so many times to contact RMS again to explain there mistake but no answer.
mustuning is offline
post #2 of 4 Old 6th June 2019, 09:01 PM
gsfent
gsfent's Avatar
Can't tell your location, but if you did not receive what you ordered, contact your credit card company about a charge back. Wrong item sent, vendor is unresponsive.
If they agree, tell them the parts are available to be sent back to RMS at their expense (generally you can't get a credit and keep the product). RMS should send a prepaid sticker for the return.
The fact you found it cheaper is on you, not RMS, although if they mislead you about it being manufactured by RMS as opposed to CM, that might be an additional ground for charge back. Again, you did not get what you ordered.
Do a search here about past dealings with RMS.
Dinan Stage 3 suspension, SS jet coated headers, ESS SC kit w/ 1 range colder NGK's, 92mm pulley, 440 Big Greens, TTFS alpha N tune for meth, RK plenum plates, SBC Endurance Stage 3 Kevlar performance clutch setup, "Jed" lightened DMFW, open brake ducts, TEC cupholder, U.S.(Euro style) tilt/slide armrest, 6k HID fogs, Umnitza bi-xenon flamethrowers w/6k super white low beams, rear fogs, V1/Stealth1, dual head LI, 2.65 diff w/40% lockup/2x dynamic, compact spare, M5 logo trunk carpet, Euro trailer hitch, Mocal oil cooler, ACS type rear spoiler, Rogue custom SSK and tranny mounts, ST 355 BBK (fronts), BP sway bar brackets, Bluetooth retrofit, Speedhut boost gauge (20 psi), Dinan TB's and VS, KB BAP, Howerton/HFS-3 Aquamist WI trunk setup (50/50), with 2nd gauge in rear view mirror, aftermarket trunk mounted sound system integrated into stock unit (amps, crossovers, sub and speakers).......
gsfent is offline
post #3 of 4 Old 7th June 2019, 06:14 PM Thread Starter
mustuning
post #4 of 4 Old 12th June 2019, 04:07 AM
Silent
Silent's Avatar
A little research on this board would have saved you a lot of $, time and headache
02 Blue Water Metallic Sport, S/C and much much more.....
05 Alpine White/Black E46 M3
15 Alpine White/Sakhir Orange F10 M5 Comp Pkg, pursuing 1k
Sold
08 Black/Black X5 4.8i
08 Alpine White/Black E60 M5
11 Alpine White/Black F10 550i M
09 Alpine White/Black E60 550i M
08 Alpine White/Black E60 550i M
06 LeMans Blue/Black X5 4.8is
03 Imola Red/Black X5 4.8is
Silent is offline
