Flashing DME...any tips - BMW M5 Forum and M6 Forums
 1Likes
post #1 of 15 Old 6th June 2019, 06:53 PM Thread Starter
mech9t8
mech9t8's Avatar
So I want to use ecuworx binary modification tool to turn off check engine light for secondary air and re-map throttle.
Process seems to be straight forward but after doing more reading seems that some people have had issues after flashing or worst case bricked their DME. Obviously I don't want this to happen to me so I'm asking the community for their expertise and help in answering a few questions.
- BMWflash or MSSflasher - is one better than the other?
- anything lessons learned from people who have done this?
- anything else?
mech9t8 is offline
post #2 of 15 Old 6th June 2019, 07:05 PM
motoman650
motoman650 is offline
post #3 of 15 Old 8th June 2019, 04:24 PM
terraphantm
Just do it, it'll be fine. BMWFlash is free, MSSflasher is more capable. If you plan on doing multiple flashes, MSSflasher is worth having since its writes are much faster and it can clear the flash counter.
I must have flashed my DME hundreds of times by now. The only times anything went wrong was if I wrote bad data to the DME. Since you're using a tool to modify your binary files instead of doing it by hand, your risk is basically nil.
terraphantm is offline
post #4 of 15 Old 9th June 2019, 03:56 PM Thread Starter
mech9t8
mech9t8's Avatar
mech9t8 is offline
post #5 of 15 Old 11th June 2019, 02:31 AM
blackknight530i
blackknight530i's Avatar
mtech9t8, if you have any issues with your DME after trying to flash, PM me and I can help you recover it. Just make sure before you modify anything to do a full read with bmwflash and store it somewhere safe. That will be a good backup of your ISN and VIN info in case a full restore is needed. I have a BDM tool that will allow writing the entire contents of the DME as long as it will power up.
-Paul
2003 "M5" - S62/420g swap, M5 diff, M5 driveshaft, M5 brakes, M5 Traction Bars, M5 Bumpers, M5 Full Leather Interior Swap, M5 Gloss Shadowline, M5 Mirrors, M5 Gauge Cluster,
M5 Ground Control Coilovers, Eibach Sway Bars, UUC Evo3/DSSR, M5 Borla Exhaust w/Muffler Delete, BMW NBT Retrofit, Hella G4 Bi-Xenon Retrofit, APEX PS-7s, e60 Hubs 530i 6-speed swap build thread
2003 530it6 - M54b30/S6S-420g swap, 3.15 540it diff, e60 SSK, VMR VB2 19" Wheels, M5 Gauge Cluster, Hella G4 Bi-xenon Retrofit, NBT Retrofit, Koni Sports, 540i Brakes
2002 540it - For Sale
2002 330Ci5 - Project "Track Car" - ZHP Control Arms, BavSound, Bi-Xenons, LED Tail Lights
2004 X5 4.8is - Stock for now
blackknight530i is offline
post #6 of 15 Old 11th June 2019, 04:26 PM Thread Starter
mech9t8
mech9t8's Avatar
mech9t8 is offline
post #7 of 15 Old 11th June 2019, 06:56 PM
OjaiM5
I am in a position where I need to flash my ECU back to stock in order to install a Shark Injector (want to clear the SAI code).
I emailed Mike for some feedback. I would like to avoid having to go to the dealership to do this. Do you guys have any suggestions.
OjaiM5 is offline
post #8 of 15 Old 12th June 2019, 03:57 AM
Silent
Silent's Avatar
Connecting a power source to the battery is not a bad idea.
02 Blue Water Metallic Sport, S/C and much much more.....
05 Alpine White/Black E46 M3
15 Alpine White/Sakhir Orange F10 M5 Comp Pkg, pursuing 1k
Sold
08 Black/Black X5 4.8i
08 Alpine White/Black E60 M5
11 Alpine White/Black F10 550i M
09 Alpine White/Black E60 550i M
08 Alpine White/Black E60 550i M
06 LeMans Blue/Black X5 4.8is
03 Imola Red/Black X5 4.8is
Silent is offline
post #9 of 15 Old 12th June 2019, 05:04 AM
mgdmb
mgdmb's Avatar
mgdmb is offline
post #10 of 15 Old 12th June 2019, 08:54 AM
ChrisSKillaZ
MSSFlasher lets you reset the flash limiter, BMWflash doesn't. This shouldn't be a problem for you unless you are making many many revisions, but figured it was worth a mention.
I personally use MSSFlasher, but I also do my own tuning so I'm always making changes.
Chris
2002 BMW M5
2003 BMW 540iA Sport
2002 Pontiac Trans am WS6
Morimoto H7 LED High Beam Install Writeup/DIY
ChrisSKillaZ is offline
