Oil Coolers - BMW M5 Forum and M6 Forums
 1Likes
  • 1 Post By Silent
post #1 of 10 Old 21st May 2019, 01:29 AM Thread Starter
sayanthan
Oil Coolers
Hi Iím considering oil cooler option as Iím moving to a 92mm pulley.
When searching posts I couldnít get a clear answer and some posts are quite old.
Whatís the best option?:
- delete under plenum heat exchanger
- delete under plenum heat exchanger and use an additional oil cooler (with gulf oil filter housing etc.)
- keep under plenum heat exchanger and add an additional oil cooler
2002 BMW E39 M5
2019 BMW M4 30th Ed Jahre Vert
Sent from my iPhone using Tapatalk Pro
sayanthan is offline
post #2 of 10 Old 21st May 2019, 06:00 AM
Silent
Silent's Avatar
My opinion is number 2 but modified.
HE delete, with CSF radiator with oil cooler combo or RK oil cooler with CFS radiator. The aluminum radiator helps. In my experience, the car runs anywhere from 10-15 degrees cooler pending on outside temps.
Deleting the HE will imply that it will take longer for your car to warm up, but I think the benefits outweigh the cons. At least for me. Also it’s not just install oil cooler and call it a day. A well designed shrout will increase efficiency of the oil cooler.
Also, initially installing the oil cooler in front of the bottom grill sounds logical, but it’s not optimal. Look at the Dinan design, e60 and F10 design. They have something in common when it comes to the location of the oil cooler.
02 Blue Water Metallic Sport, S/C and much much more.....
05 Alpine White/Black E46 M3
15 Alpine White/Sakhir Orange F10 M5 Comp Pkg, pursuing 1k
Sold
08 Black/Black X5 4.8i
08 Alpine White/Black E60 M5
11 Alpine White/Black F10 550i M
09 Alpine White/Black E60 550i M
08 Alpine White/Black E60 550i M
06 LeMans Blue/Black X5 4.8is
03 Imola Red/Black X5 4.8is
Silent is offline
The Following User Says Thank You to Silent For This Useful Post:
sayanthan (21st May 2019)
post #3 of 10 Old 22nd May 2019, 09:23 PM
gsfent
gsfent's Avatar
2002 BMW E39 M5
I would also say #2. I did not bother removing the HE, but I would if I had reason to pull things apart.
I have Setrab oil cooler mounted behind the grill, gulf oil filter housing, and Zionsville (stock size) aluminum radiator. No track work to date.
Dinan Stage 3 suspension, SS jet coated headers, ESS SC kit w/ 1 range colder NGK's, 92mm pulley, 440 Big Greens, TTFS alpha N tune for meth, RK plenum plates, SBC Endurance Stage 3 Kevlar performance clutch setup, "Jed" lightened DMFW, open brake ducts, TEC cupholder, U.S.(Euro style) tilt/slide armrest, 6k HID fogs, Umnitza bi-xenon flamethrowers w/6k super white low beams, rear fogs, V1/Stealth1, dual head LI, 2.65 diff w/40% lockup/2x dynamic, compact spare, M5 logo trunk carpet, Euro trailer hitch, Mocal oil cooler, ACS type rear spoiler, Rogue custom SSK and tranny mounts, ST 355 BBK (fronts), BP sway bar brackets, Bluetooth retrofit, Speedhut boost gauge (20 psi), Dinan TB's and VS, KB BAP, Howerton/HFS-3 Aquamist WI trunk setup (50/50), with 2nd gauge in rear view mirror, aftermarket trunk mounted sound system integrated into stock unit (amps, crossovers, sub and speakers).......
gsfent is offline
post #4 of 10 Old 6th July 2019, 10:23 PM Thread Starter
sayanthan
Deleting the HE will imply that it will take longer for your car to warm up, but I think the benefits outweigh the cons. At least for me. Also itís not just install oil cooler and call it a day. A well designed shrout will increase efficiency of the oil cooler.
Also, initially installing the oil cooler in front of the bottom grill sounds logical, but itís not optimal. Look at the Dinan design, e60 and F10 design. They have something in common when it comes to the location of the oil cooler.
Got RK oil cooler, RK radiator and shadyís HE delete kit on the way.....so I can run this with the stock oil filter housing? No need for gulf oil filter?
2002 BMW E39 M5
post #5 of 10 Old 6th July 2019, 11:34 PM
Silent
Silent's Avatar
2002 BMW E39 M5
In theory yes..
Your ďRK oil cooler/radiatorĒ solution should include everything you need and you donít need Golf oil filter housing.
Sold
Silent is offline
post #6 of 10 Old 8th July 2019, 03:58 PM
uhad2point
uhad2point's Avatar
what's up with all the hate for the stock heat exchanger? I get that it actually heats the oil during any condition where the oil temp is less than the coolant temp, but I'm not really looking to keep the oil temp lower than 200-210F anyways. Why would you? The stock heat exchanger, being a liquid-to-liquid exchanger, is efficient and I imagine that it becomes very efficient at higher delta T, for example when oil temps get up to 240F+ on track.
uhad2point is offline
post #7 of 10 Old 8th July 2019, 07:03 PM
Silent
Silent's Avatar
You should read the purpose behind this. No one is hating on the stock HE... but why read right...
Sold
Silent is offline
post #8 of 10 Old 8th July 2019, 07:27 PM
uhad2point
uhad2point's Avatar
I'm filing a hurt feelings report
You're talking about how the location of the stock HE radiates heat into the plenum? Extra-bad on supercharged cars. Or are you talking about another issue?
post #9 of 10 Old 8th July 2019, 09:03 PM
Silent
Silent's Avatar
[QUOTE=uhad2point;7569924]I'm filing a hurt feelings report
Must be a generational thing.
In this specific thread we are only discussing one question.
Sold
Silent is offline
post #10 of 10 Old 8th July 2019, 11:55 PM Thread Starter
sayanthan
Yes, my question applies to supercharged M5ís
2002 BMW E39 M5
DIY: I changed my oil on my 2007 M6 Convertible passdanachos E63 BMW M6 Forum and BMW M6 Convertible | m6board.com 33 10th May 2018 10:08 PM
S85 V10 oil level service bulletin cobradav E63 BMW M6 Forum and BMW M6 Convertible | m6board.com 6 7th February 2018 06:24 AM
WTF 1.5 Oil!? G4Titan E63 BMW M6 Forum and BMW M6 Convertible | m6board.com 27 17th April 2009 05:27 AM
Oil Type - BMW Manuals JFB M5 E39 and E60 tips & tricks 10 23rd October 2008 10:35 AM
