Alignment Help - BMW M5 Forum and M6 Forums
 1Likes
post #1 of 11 Old 18th May 2019, 12:09 PM Thread Starter
haliaman
Alignment Help
Just finished installing Dinan springs/Koni Yellows, Control arms.thrust arms and new tires, Went for alignment and front Camber is: Left:-0,1 degree, Right:-1.6 degree. Shop recommended SPC 72180 Camber plates. Any advise/thoughts? Alignment specs below
haliaman is offline
post #2 of 11 Old 18th May 2019, 03:36 PM
josiahg52
josiahg52's Avatar
You installed both of the Dinan top plates?
That's pretty far off so I'd suspect an installation error or significant damage to the vehicle.
The Ground Control camber plates are exceptional.
josiahg52 is online now
post #3 of 11 Old 18th May 2019, 06:43 PM Thread Starter
haliaman
No plates. The car was aligned lat year before the upgrades and alignment was spot on. I guess installation error can be a factor. Any advise as to what to check? Thanks
haliaman is offline
post #4 of 11 Old 18th May 2019, 07:24 PM
AZM588
AZM588's Avatar
AZM588 is offline
post #5 of 11 Old 18th May 2019, 07:43 PM
caslvre39
do you have old and current alignment print outs. both side look out of whack. I would check the hub for play and all the control arms, would be pretty cheap and ez to put in an lower control arm 1st before taking apart the struts to install bandaid camber plates before knowing what your issues are.
caslvre39 is online now
post #6 of 11 Old 18th May 2019, 07:51 PM Thread Starter
haliaman
I installed new lemforder control arms and thrust arms. I loaded the suspension before torquing frame side. Anything I could of missed? The bushings on the thrust arms were torn and I had slow speed rattles over bumps and steering wheel vibration when braking. All that has been gone and the front is tight. Just the camber numbers being off
haliaman is offline
post #7 of 11 Old 18th May 2019, 07:58 PM
caslvre39
I would double check everything if installed correctly and the hub for play. the fact one side is little extra neg and other side it too positive camber, with lower springs. what are the caster reading are they pretty even?
post #8 of 11 Old 18th May 2019, 10:01 PM Thread Starter
haliaman
left castor: 6.2 degrees
Right Castor: 6.3 degrees
haliaman is offline
post #9 of 11 Old 19th May 2019, 12:55 AM
caslvre39
thats good, usually if caster is off then likely it was in an impact incident. I would double check the springs if they seated correctly and strut tube in the spindle.
more interested why the lf has almost no camber after lowering springs?
post #10 of 11 Old 19th May 2019, 06:14 PM
josiahg52
josiahg52's Avatar
I thought the Dinan kit came with fixed camber plates. I guess not.
Wheels, Tires, and Alignment.... Oh my CrazyJew89 E39 M5 and E52 Z8 Discussion 37 12th December 2014 02:29 AM
Alignment issues on lowered M5 boostaddict E39 M5 and E52 Z8 Discussion 20 20th August 2012 06:36 AM
To the Dealer for an alignment?? gherardini E39 M5 and E52 Z8 Discussion 10 2nd June 2012 05:19 AM
LA Area Alignment Shop - Strong Recommendation BKH E39 M5 and E52 Z8 Discussion 7 2nd March 2007 06:07 AM
20" Wheels, Dinan 3.91 & Alignment Issues from Factory freddydi E60 M5 and E61 M5 Touring Discussion 4 15th December 2006 10:47 PM
