Next steps advice on an ESS VT560 Kit - BMW M5 Forum and M6 Forums
post #1 of 4 Old 18th May 2019, 10:38 AM Thread Starter
sayanthan
Hi Iíve got an ESS VT560 kit fitted to my car (96.5mm pulley)
Other power related mods are:
Russ Fellows 4-2-1 headers & 100 cell cats /Dinan rear exhaust
Evolve plenum
Stock ESS Tune which i understand is conservative
The car is running really well, no boost leaks (smoke tested), boosting to around 5.5psi and no leaks when smoke tested. Itís daily driven and very reliable.
On the road it does feel a bit more quick than before in the mid range when I compare to when it was NA, mapped and had headers, - I would like a bit more here though.
....the power gains do become much more noticeable and you can really feel the car opening up over 5000 rpm
- i.e. on a track days (donít do more than 2-3 a year) or an open empty b-road (not often you get that where I live!) then you really do notice the extra power.
The car is also a little lighter than before (bucket seats, CF roof and CF front / rear bumper carriers, forged bbs RGR 18x10 rims all round, so some difference in acceleration may be attributable to this). It puts the power down really well, no fuss at all, so the chassis feels like it can handle more power. (Intrax coilovers/os giken diff/subframe reinforced/front & rear strut braces)
Iíd like a bit more mid range power/torque without sacrificing the top end and ideally power that is Re-producible with extended use, when the car was NA, at track day at Bedford , Iíd stop every 5 laps to allow the car to cool down, (better drivers than me might stop more often!); Iíve not done a track day yet with the car supercharged.
Iím thinking:
92mm pulley, bigger injectors & remap
Delete under plenum heat exchanger+add oil cooler with gulf filter housing mod
RK radiator
Decat pipes (will this help with heat also?)
And see how this runs, adding water injection if necessary.
The car is dynoing at 525-535bhp (4 consecutive dyno runs); it was previously putting out ~450-460bhp.
Iím also aware sometimes you can tinker too much when youíre onto a good thing, so thoughts and advice welcome! Itís still a family car (Iíve got oem child booster seats) and I do the school run a couple of times a week....
Thoughts/feedback welcomed.
2002 BMW E39 M5
2019 BMW M4 30th Ed Jahre Vert
Sent from my iPhone using Tapatalk Pro
sayanthan is online now
post #2 of 4 Old 18th May 2019, 09:08 PM
Silent
Silent's Avatar
Smoke test won’t do much against boost leaks since a smoke is not pressurized same as blowing air into the pipe and saying there are no leaks.
You may also want to look I to an oil cooler as well.
If this is a family car I wouldn’t recommend removing the cats, you’ll like it but only for about 2 minutes. Plus the smell of fumes since it’s now less restricted.
This can’t be wheel power, if it is it’s way off. No way on this universe you are making the power you stayed with 5.5 psi. This would mean your car makes more N/A power than the factory claimed.
You are probably close 440-450 whp.
I’d say meth injection is a must no matter what size pulley or if the car sees track or not. I’ve found that 80/20 seems to be the perfect mix based on altitude and weather condition where I live.
What fun is it when the power comes on right before you have to shift. Now if the power comes on between 2500-2800 rpm
02 Blue Water Metallic Sport, S/C and much much more.....
05 Alpine White/Black E46 M3
15 Alpine White/Sakhir Orange F10 M5 Comp Pkg, pursuing 1k
Sold
08 Black/Black X5 4.8i
08 Alpine White/Black E60 M5
11 Alpine White/Black F10 550i M
09 Alpine White/Black E60 550i M
08 Alpine White/Black E60 550i M
06 LeMans Blue/Black X5 4.8is
03 Imola Red/Black X5 4.8is
Silent is offline
post #3 of 4 Old 18th May 2019, 09:23 PM Thread Starter
sayanthan
Itís BHP not WHP
Yes Iím looking at an oil cooler
2002 BMW E39 M5
post #4 of 4 Old 18th May 2019, 09:35 PM
Silent
Silent's Avatar
Few more things that I forgot to mention, I opted out for the factory clutch fan as I found that electrical fans arenít as efficient. And I got a vented hood as much as I didnít want to, but it helps with fighting the heat.
Sold
Silent is offline
The Following User Says Thank You to Silent For This Useful Post:
sayanthan (18th May 2019)
E39 For Sale: ESS VT1-560 supercharger kit genius Parts / Other For Sale or Wanted 12 20th November 2017 03:49 PM
ESS Vortech VT560 Installed! nightkrawler E39 M5 and E52 Z8 Discussion 100 11th March 2015 03:36 AM
About ESS supercharger kit...2007-2009MY update rod bearings? M V10 E90 M3 Sedan, E92 M3 Coupe, E93 M3 Convertible, E46 M3 and E36 M3, Z4 M and Z4 M Coupe 6 30th December 2012 03:07 PM
ESS S85 Vt1 SC Kit ThugSleeper E63 BMW M6 Forum and BMW M6 Convertible | m6board.com 25 28th September 2011 10:00 AM
Supercharged 4.6is (long) Curtis BMW 1 Series M Coupť, X5M and X6M Forum 9 10th April 2004 11:25 AM
