DIY Help on '03 E39 M5 - Charlotte, NC - BMW M5 Forum and M6 Forums
 2Likes
  • 1 Post By Sailor24
  • 1 Post By Silent
post #1 of 10 Old 16th May 2019, 05:58 PM Thread Starter
fkosarek1
Hey M5Board,
I have an '03 jet black M5 that needs a little love. When I engage reverse, first gear, or second gear, I can hear a metallic clack coming from the driveshaft area. My hunch is that the driveshaft CSB and guibo need to be replaced.
I'm looking for a lift and some know-how to get this done DIY. Anyone in the Charlotte area who can help?
Thanks!
fkosarek1 is offline
post #2 of 10 Old 16th May 2019, 09:14 PM
Trizzuth
Trizzuth's Avatar
Hello fellow E39 member...
I had the center support bearing go and let me tell you, when the car was cold and I drove it just down the street, I could literally feel the driveshaft wobbling and slapping around if I reached back and put my hand on the carpet area above the transmission/driveshshaft tunnel. it was incredibly noticeable and you could also feel it in the driveline. Once the car warmed up and I was on the highway or even around town at that point, this symptom went away.
I will tell you that I have read a few threads on here where people have swapped the stock shifter out for the E60 short shifter or the UUC short shifter and part of the shift linkage starts to come in contact with the guibo and can rub and make horrible sounds.
Was this metallic clack only when engaging the gear, or while driving in it too? At all RPM's or only low? At all speeds? Any worse or better at varying RPM's or Speeds?
Unfortunately, because the CSB is buried up under everything, it's almost impossible to physically get a hand or even eyes on the part to determine if it's bad since it's hidden by the exhaust, and heat shield. I even snaked an inspection camera up in there and while I could see the CSB, it looked fine and there was no obvious catastrophic sign of failure, but man did it feel that way when driving. Even removing the CSB it did not look half bad, boot was not totally torn and it wasn't badly destroyed or even appear to be badly worn, but once the pressure of the driveshaft spinning was in there, it was horrendous.
New (old): 2003 E39 M5 TiAG
Old: 2001 E46 330i Steel-Grey Metallic (Totalled)
Trizzuth is online now
post #3 of 10 Old 16th May 2019, 10:24 PM Thread Starter
fkosarek1
@Trizzuth : Thanks for the reply. The clack happens when I take off from a stop in first or reverse, and I can still hear it when I shift into second or get back on the gas after coasting in second. It goes away at high speeds and high RPMs.
The issue definitely doesn't rattle the whole driveline as you described. The car still drives smoothly down the street, so maybe it's something to do with the rear end. I'll do some more digging too.
post #4 of 10 Old 16th May 2019, 10:57 PM
gsfent
gsfent's Avatar
Rear subframe?
Dinan Stage 3 suspension, SS jet coated headers, ESS SC kit w/ 1 range colder NGK's, 92mm pulley, 440 Big Greens, TTFS alpha N tune for meth, RK plenum plates, SBC Endurance Stage 3 Kevlar performance clutch setup, "Jed" lightened DMFW, open brake ducts, TEC cupholder, U.S.(Euro style) tilt/slide armrest, 6k HID fogs, Umnitza bi-xenon flamethrowers w/6k super white low beams, rear fogs, V1/Stealth1, dual head LI, 2.65 diff w/40% lockup/2x dynamic, compact spare, M5 logo trunk carpet, Euro trailer hitch, Mocal oil cooler, ACS type rear spoiler, Rogue custom SSK and tranny mounts, ST 355 BBK (fronts), BP sway bar brackets, Bluetooth retrofit, Speedhut boost gauge (20 psi), Dinan TB's and VS, KB BAP, Howerton/HFS-3 Aquamist WI trunk setup (50/50), with 2nd gauge in rear view mirror, aftermarket trunk mounted sound system integrated into stock unit (amps, crossovers, sub and speakers).......
gsfent is online now
post #5 of 10 Old 16th May 2019, 11:37 PM
technician117
technician117's Avatar
Sounds like a bad front differential bushing. They're not too bad to replace but you need a special tool or some good variety of press tool adapters and a little ingenuity to compress the bushing so it will slide in.
Tim
2013 M5 Imperial Blue/Silverstone II, 6MT 50k miles
2000 Anthracite daily driver
UUC dssr and shifter
Supersprint headers with Tubi catback
Jailbreak tuning
Dinan 3.45 JED lightened flywheel
282,000 miles and counting
'00 Imola/Imola 104k,
'00 Silverstone/Silverstone 129k (SOLD)
technician117 is offline
post #6 of 10 Old 17th May 2019, 01:51 AM
Sailor24
Sailor24's Avatar
I guess we all have different experiences. Sounds similar to what I was feeling when I had a bad half shaft. I doubt that is it because I have only ever read one other person have one fail. Easy to check though just by jacking each rear wheel up and turning it by hand back and forth.
Sailor24 is offline
post #7 of 10 Old 17th May 2019, 04:37 AM
Silent
Silent's Avatar
Sounds like shaft. Easiest way to check jack up both rear tires. Put a brick or 2x4 in front of the front tires first. Once itís in the air, the car can be in gear or neutral. Turn the tire in either direction, quick jerk back and forth. If itís the shaft youíll hear the same noise that you were hearing in the car.
I and several board members have experienced this. Itís somewhat common. Mine started around 60-70k miles. I replaced it with another used one but should have either got it rebuilt or bought a new one. You might want to check the flex disk as well for any cracks. Try pushing it with a weighted tool. If you notice a lot of resistance then the disk should be fine otherwise it may be a good time to replace if the shaft is going to come out. Itís also a good time to explore everything else.
02 Blue Water Metallic Sport, S/C and much much more.....
05 Alpine White/Black E46 M3
15 Alpine White/Sakhir Orange F10 M5 Comp Pkg, pursuing 1k
Sold
08 Black/Black X5 4.8i
08 Alpine White/Black E60 M5
11 Alpine White/Black F10 550i M
09 Alpine White/Black E60 550i M
08 Alpine White/Black E60 550i M
06 LeMans Blue/Black X5 4.8is
03 Imola Red/Black X5 4.8is
Silent is offline
post #8 of 10 Old 17th May 2019, 04:39 AM
Silent
Silent's Avatar
Saw this after I posted my comment.
Sold
Silent is offline
post #9 of 10 Old 17th May 2019, 01:43 PM
Trizzuth
Trizzuth's Avatar
Based on what you are now saying about it giving this "clack" when you engage the gear and take off, but not really a driveline vibration, it dos sound more like a bad rear diff bushing. This one is not too bad to see if you can get the rear end of the car up. If you suspect this is it, you could always try to mount a small camera under the car pointed at the diff bushing and drive around a bit while recording to look for deflection on that point. If it clacks like you say, I'd suspect that if it were the diff bushing you would be able to visibly see the bushing torn, failing, squishing out, etc. Without that bushing taking the flex of the rear end, it's a metal pin inside a metal housing so a clack makes sense there.
But I have not personally had this bad diff bushing yet so I cannot really say about this clack, I am only speculating on what you've said here.
post #10 of 10 Old 17th May 2019, 02:16 PM
technician117
Usually the bushing is covered in oil/grease and this is what makes the older bushings fail (combine age and being attacked by the oils/grease breaks down the rubber).
To check, you could put the car on stands and have someone let out the clutch in first gear, you should be able to watch the movement at the front of the diff. It might not show as much since the suspension is unloaded, or on the other hand, it might be more pronounced?
I second checking the driveshaft for play as well. Just realize that you will have gear backlash too, so don't freak out when you get some movement. Usually if the u-joint on the DS is bad you will hear a higher pitched "ding" as it echo's off the hollow shaft.
Tim
Jailbreak tuning
UK Owners List ianskiman E39 M5 and E52 Z8 Discussion 92 21st May 2019 12:58 PM
M5 E39 Body Style S62 engine FACTS...Long V-10 4 Me E39 M5 and E52 Z8 Discussion 64 30th December 2013 08:35 PM
E39 For Sale: PARTING OUT 2001 BMW E39 M5 Carbon Black AlpineM3503 Parts / Other For Sale or Wanted 65 24th July 2012 10:51 PM
M5 owners in the UK jgfabs E39 M5 and E52 Z8 Discussion 62 4th June 2010 06:28 PM
