Do I need to install water/meth system? - BMW M5 Forum and M6 Forums
 7Likes
post #1 of 22 Old 12th May 2019, 11:08 PM Thread Starter
DonutFlame
Iím getting the ESS VT-1 560 kit and swapping for a 92mm pulley. My M5 is completely stock before this.
Is a water/meth system necessary? Or an inter cooler? I am not planning any other modifications besides this supercharger kit. Is it fine to just use whatís in the kit? Iíve read that some people have heatsoak issues when running it as is.
What situations would you need an inter cooler or water/meth setup? I want to maintain reliability as much as possible. Is meth just for additional horsepower or does it help with cooler temperature?
Also, I live in Utah if that matters, so it can get hot during summer
DonutFlame is offline
post #2 of 22 Old 12th May 2019, 11:31 PM
Craze
A non intercooled kit is silly
Intercooler for sure
Meth also keeps temps down but is flammable
Craze is offline
post #3 of 22 Old 12th May 2019, 11:44 PM Thread Starter
DonutFlame
Is an intercooler more ďfool proofĒ?
What I mean is less things to fail and worry about, like installing gauges, installing a tank and rerouting wires, etc?
Or does an intercooler also have its own issues? (Iím aware sometimes you have to trim the bumper but thatís not a big deal to me)
post #4 of 22 Old 12th May 2019, 11:47 PM
mmzcee
mmzcee's Avatar
Meth kit is recommended when you up the boost with the 92mm pulley. I have the same kit with stock pulley and even in moderate temps suffer from heat soak after a few spirited accelerations.
Without additional cooling, the 92mm pulley will yield negligible gains after a few dry runs, maybe even decrease overall performance. There are a few youtube videos from vehicle virgins (racing a S85 M6) where they swap the pulley from stock to 92mm and and the result was same if not worse due to heat soak, and the ambient temp was like 50F.
Primary benefit from the smaller pulley is that the boost kicks in at lower rpm so butt dyno will tell you it's quicker. Not worth the added risk IMO.
mmzcee is offline
post #5 of 22 Old 12th May 2019, 11:49 PM Thread Starter
DonutFlame
Thanks for the advice. So what youíre saying is that the 92mm pulley doesnít actually add any overall horsepower? It just makes boost kick in at lower rpm?
If I stuck with the stock pulley would just an intercooler be sufficient?
post #6 of 22 Old 13th May 2019, 12:00 AM
mmzcee
mmzcee's Avatar
Originally Posted by DonutFlame View Post
Thanks for the advice. So what you’re saying is that the 92mm pulley doesn’t actually add any overall horsepower? It just makes boost kick in at lower rpm?
In theory, the smaller pulley should produce more boost equating to more hp. But in reality, without the added necessary cooling and retune - the gains are negligible.
Watch this vid and decide for yourself
+ YouTube Video
ERROR: If you can see this, then YouTube is down or you don't have Flash installed.
I'd just leave it stock and test if heat soak is an issue enough for you to warrant shelling out extra cash for meth kit or FMIC.
mmzcee is offline
post #7 of 22 Old 13th May 2019, 01:50 AM
Blockdoc
Blockdoc's Avatar
+ YouTube Video
This was my experience exactly. I added meth as there were really no viable intercoolers available during my build. The heatsoak on these E39s is significant in STOCK form (saw many pictures of guys at the track with ice bags on the plenums between runs). Even worse with addition of a blower. I would add meth again in a second (already put a kit on my M4 build)
Happy to help in anyway I can
Brian
2003 Sterling Grey M5 SOLD
ESS kit #1 with RK AUTOWERKS Upgrade! (RK/EVO software, Injectors, Fuel Pump)
Dinan Free Flow Exhaust, Dinan Rear Sway Bar
Super Sprint Headers
Rogue Octane SSK and WSR
DICE Ipod connectivity
Bimmian Black Kidney Grilles
Ultimate Pedals
Rear Wheels Up Front (275s all around)
Aquamist HFS3/Howerton Engineering Tank (pre/post SC nozzles)
RK Autowerks CNC Plenum Plates
2015 M4 Coupe DCT (BootMod flash Custom Paul Johnson Tune, downpipes, Methanol 100 percent , E30 map, Pure Turbos 700WHP+, 295/275 tires with Vorsteiner wheels)
2018 Jeep Hellcat Trackhawk (707HP Supercharged)
Blockdoc is offline
post #8 of 22 Old 13th May 2019, 03:53 AM
DonutRanger
Brian
If I were to use the ESS supercharger kit and upgrade to the 92mm pulley, do you think just an intercooler would be sufficient or would I also need to use meth/water injection in addition to the intercooler?
DonutRanger is offline
post #9 of 22 Old 13th May 2019, 04:09 AM
mmzcee
mmzcee's Avatar
either/or is fine. Both would probably be overkill for your application.
mmzcee is offline
post #10 of 22 Old 13th May 2019, 05:07 AM
gsfent
gsfent's Avatar
I have a similar setup although I do have larger throttle bodies and exhaust headers (you can see my sig).
With stock boost (96mm) you are right on the edge of heat soak. For 1 or 2 pulls on the street, you are OK. But more than that, you will some a difference. 96mm yields about 6 to 6.5 psi.
With the 92mm pulley, I have about 8.5 psi. Boost does come on earlier. I used 80/20 meth/water. I changed the settings on the meth controller to have the meth/water kick in at 5 psi (stock is 3 psi). On a dyno, with a slipping clutch, (getting worse each run) I saw a minimum of 30 extra wheel horsepower on the last run of the day. I suspect the difference is more like 50-60 based on my tuner's observations and experience, but I haven't been back to the dyno since I replaced my clutch. If you use meth, you need to get someone who can tune for it. Otherwise it does nothing but richen the mixture (which is nice but that simply acts as a cooling agent). Quelling heat allows more timing to run; or more precisely, less timing to be taken out by the computer controls.
The advantage of an intercooler is it is pretty foolproof. Air to air gives less cooling, but much more reliable from run to run. Air to water does better, but then the water can heat up, changing its effectiveness. The one thing to consider with an intercooler is that is can rob 1-2 psi of boost, so you need to compensate. If you go that route, you may even want the 88 mm pulley, but make sure you have a really good tune.
Dinan Stage 3 suspension, SS jet coated headers, ESS SC kit w/ 1 range colder NGK's, 92mm pulley, 440 Big Greens, TTFS alpha N tune for meth, RK plenum plates, SBC Endurance Stage 3 Kevlar performance clutch setup, "Jed" lightened DMFW, open brake ducts, TEC cupholder, U.S.(Euro style) tilt/slide armrest, 6k HID fogs, Umnitza bi-xenon flamethrowers w/6k super white low beams, rear fogs, V1/Stealth1, dual head LI, 2.65 diff w/40% lockup/2x dynamic, compact spare, Euro trailer hitch, Mocal oil cooler, ACS type rear spoiler, Rogue custom SSK and tranny mounts, ST 355 BBK (fronts), BP sway bar brackets, Bluetooth retrofit, Speedhut boost gauge (20 psi), Dinan TB's and VS, KB BAP, Howerton/HFS-3 Aquamist WI trunk setup (50/50), with 2nd gauge in rear view mirror, aftermarket trunk mounted sound system integrated into stock unit (amps and crossovers and sub and speakers).......
gsfent is offline
Stock S85 V10 engine and nitrous oxide? rocket5979 E63 BMW M6 Forum and BMW M6 Convertible | m6board.com 201 20th March 2018 06:28 PM
2006 M5 install voice input system + nav system michael33 E60 M5 and E61 M5 Touring Discussion 1 30th October 2013 12:33 AM
V1 Rear View Mirror System - DIY install for E92 M3 RaceMX-M3 E90 M3 Sedan, E92 M3 Coupe, E93 M3 Convertible, E46 M3 and E36 M3, Z4 M and Z4 M Coupe 5 2nd January 2010 05:58 AM
Official: BMW M5 Touring + facelift for the 5-series [New pics 16/3] Gustav E60 M5 and E61 M5 Touring Discussion 142 22nd March 2007 05:08 PM
Nav Sw Ver 18 upgrade - FAQ 1C00lVC M5 E39 and E60 tips & tricks 0 12th March 2002 05:00 AM
