Wiring for rearview mirror - BMW M5 Forum and M6 Forums
post #1 of 11 Old 11th May 2019, 11:25 PM Thread Starter
Haywood
I'm about to hook up my radar detector and ordered a cable that comes with positive and negative pins to be plugged into the rearview mirror harness. Can someone tell me which cables I need to plug both of these wires into? Here is what the cable looks like. Thanks.
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
2003 LMB e39 M5
1997 AW e36 M3
Haywood is offline
post #2 of 11 Old 12th May 2019, 03:03 AM
Samsam11
Here is the pinout https://www.newtis.info/tisv2/a/en/e39-m5-lim/ZVeyrUG, you will want to connect positive to terminal 15 (green with a white tracer I think) and ground to ground (Brown).
Samsam11 is offline
post #3 of 11 Old 12th May 2019, 03:23 AM Thread Starter
Haywood
Thanks! I'll try that.
2003 LMB e39 M5
1997 AW e36 M3
Haywood is offline
post #4 of 11 Old 16th May 2019, 05:30 AM
Silent
Silent's Avatar
If I recall the green wire is key ignition and brown is typically ground, but using chassis ground is better. Less stuff conncted to the CANBUS the better. However, get yourself an inexpensive tester and always check before cutting into it.
02 Blue Water Metallic Sport, S/C and much much more.....
05 Alpine White/Black E46 M3
15 Alpine White/Sakhir Orange F10 M5 Comp Pkg, pursuing 1k
Sold
08 Black/Black X5 4.8i
08 Alpine White/Black E60 M5
11 Alpine White/Black F10 550i M
09 Alpine White/Black E60 550i M
08 Alpine White/Black E60 550i M
06 LeMans Blue/Black X5 4.8is
03 Imola Red/Black X5 4.8is
Silent is offline
post #5 of 11 Old Yesterday, 06:06 AM
Samsam11
Well at the end of the wire it is "chassis ground", after going to a comb conector a larger wire conects it to the body of the car under the seat https://www.newtis.info/tisv2/a/en/e39-m5-lim/WH26Kor. I don't really get what you mean by "CANBUS" here, it's not connected at all.
Samsam11 is offline
post #6 of 11 Old Yesterday, 06:56 PM
Silent
Silent's Avatar
What are you doing here then?
Sold
Silent is offline
post #7 of 11 Old Yesterday, 07:21 PM
Samsam11
I am trying to understand what you are saying, is there some CAN bus device that uses ground to actually transmit packets that I don't know about? Am I just reading your post wrong?
Samsam11 is offline
post #8 of 11 Old Yesterday, 10:34 PM
Silent
Silent's Avatar
I guess google took the day off today. Iíll try to explain it in a very simple form.
CAN bus, Contoller Area Network. Itís the freeway where all of your sensors and car information runs on. The freeway does not like it when foreign cars are on it, i.e. another module that did not come from factory. So why is this bad? If your car stars acticting funny like error codes you wonít know the real issue until you disconnect all foreign devices and run diagnostic again.
How do people add all of that after market stuff? Two part answer.
1. You can borrow power from the freeway, but should always use chassis for ground.
2. Those people who add stuff and run onto trouble, run here for their answers cause no one out there can identify the problem.
Lastly, when posting a comment one should have a general knowledge on what they are talking about vs. opinions which even they wonít consider.
Sold
Silent is offline
post #9 of 11 Old Today, 05:32 AM
Samsam11
The E39 M5 only has 3 CAN nodes, DME, instrument cluster and the DSC/ABS unit, other buses handle other interconnections and their nodes would probably be more susceptible. Interference affecting the actual bus signals is unlikely, however interference to modules or sensors can be coupled through the ground path. And I do agree with you that accessories can cause all kinds of odd problems.
BMW chose to use series connected single-point grounds for most low current items, this is not strictly optimal but given the one hundred or so ground wires, connecting them to the body individually would be very impractical.
Such problems would be more likely if the device installed drew a large current. In this case the ground path is only slightly more complex than that for the lighter socket, if it does not cause problems plugged in there I would not think that it would cause them when connected through the ground to the mirror.
But automotive EMI and common mode interference is complicated and to fully understand the consequences of installing equipment is a guessing game without manufacturer level knowledge of the cars systems.
Samsam11 is offline
post #10 of 11 Old Today, 05:52 AM
Silent
Silent's Avatar
Some of us tinkered with the car so much that we have that knowledge. Hence the purpose of this board, to pass the knowledge to the next gen of e39 owners.
Sold
Silent is offline
E39 M5 side mirror wiring?? ans77030 E39 M5 and E52 Z8 Discussion 7 15th August 2016 05:52 AM
Mirror Repair Spajo E39 M5 and E52 Z8 Discussion 2 24th January 2016 06:56 AM
E39 For Sale: Driver and Passenger Mirror Glass Never2Low Parts / Other For Sale or Wanted 4 30th September 2015 06:48 PM
E39 For Sale: Passenger Side M5 Mirror Carbon Black Complete or Parted Manny G. Parts / Other For Sale or Wanted 14 23rd March 2014 09:24 PM
How To: CF lower mirror cover install ///Pete E60 M5 and E61 M5 Touring Discussion 10 11th March 2011 02:57 AM
