Smallest wheels for M5? - BMW M5 Forum and M6 Forums
 1Likes
  • 1 Post By mech9t8
post #1 of 7 Old 10th May 2019, 01:30 AM Thread Starter
Jakl15
Jakl15's Avatar
Looking to get my 65s refinished. Would rather just send all 4 at once down to get redone instead of sending them 2 at a time and being out a car twice as long.
My plan was to just venture to one of the local junkyards and pick up some wheels from another e39 and put them on temporarily, but most are 16" wheels. I'm not sure they'll clear the calipers.
Jakl15 is offline
post #2 of 7 Old 10th May 2019, 03:30 AM
mech9t8
mech9t8's Avatar
mech9t8 is offline
The Following User Says Thank You to mech9t8 For This Useful Post:
gsfent (10th May 2019)
post #3 of 7 Old 10th May 2019, 01:52 PM Thread Starter
Jakl15
Jakl15's Avatar
Jakl15 is offline
post #4 of 7 Old 10th May 2019, 06:04 PM
mech9t8
mech9t8's Avatar
mech9t8 is offline
post #5 of 7 Old 10th May 2019, 06:44 PM
Ibmotoren
Ibmotoren's Avatar
Rent a cheap car for a week. Similar cost, less hastle, unless you want an extra set of wheels around for other reasons. Prince(if that’s where you’re sending them) is close to you. Turn around should be pretty quick. Also, you must get all 4 done at once. No way you get the exact same finish doing 2 at a time. If you google search this forum, you will find many threads about which other BMW wheels will fit.
2001 ///M5 ...Anthracite / Black Complete-Heritage
Ibmotoren is offline
post #6 of 7 Old 10th May 2019, 07:44 PM
gsfent
gsfent's Avatar
Originally Posted by Jakl15 View Post
Same for front and rear? Or can I get away with any 17s on the back?
Given your location, you might consider some winter wheels so your "good wheels" don't get beat up in bad weather.
If it was me, I would get 4 fronts (8x18) which are cheap and set it up that way. They will fit. You can probably score wheels in the $100 each range if you are not too picky about cosmetics.
Dinan Stage 3 suspension, SS jet coated headers, ESS SC kit w/ 1 range colder NGK's, 92mm pulley, 440 Big Greens, TTFS alpha N tune for meth, RK plenum plates, SBC Endurance Stage 3 Kevlar performance clutch setup, "Jed" lightened DMFW, open brake ducts, TEC cupholder, U.S.(Euro style) tilt/slide armrest, 6k HID fogs, Umnitza bi-xenon flamethrowers w/6k super white low beams, rear fogs, V1/Stealth1, dual head LI, 2.65 diff w/40% lockup/2x dynamic, compact spare, Euro trailer hitch, Mocal oil cooler, ACS type rear spoiler, Rogue custom SSK and tranny mounts, ST 355 BBK (fronts), BP sway bar brackets, Bluetooth retrofit, Speedhut boost gauge (20 psi), Dinan TB's and VS, KB BAP, Howerton/HFS-3 Aquamist WI trunk setup (50/50), with 2nd gauge in rear view mirror, aftermarket trunk mounted sound system integrated into stock unit (amps and crossovers and sub and speakers).......
gsfent is offline
post #7 of 7 Old 11th May 2019, 09:40 PM
logikfive
I had 17" Style 42's on the rear of my M5 while I was refinishing the wheels after the previous owner had them coated purple. I did two at a time so I could stick the 18" M5 rears on the front while I redid those. 17's won't fit the front, atleast the Style 42's won't.
2003 BMW 525i/Auto (Daily)
2002 BMW M5/6spd
2015 Dodge Challenger SRT 6.4L/6spd
logikfive is offline
E60 For Sale: BRAND NEW Niche Monotec Lucerne 20x9.5 & 20x11 Black Chrome Wheels - TWO DAY ONLY SALE PyroZona Parts / Other For Sale or Wanted 4 2nd June 2014 07:57 PM
✚WHEELSTO | Wheels of SEMA Las Vegas 2010 WSTO E60 M5 and E61 M5 Touring Discussion 3 20th November 2010 01:27 PM
Rays wheels - How are they made? WSTO E39 M5 and E52 Z8 Discussion 2 24th June 2010 06:09 AM
Rays wheels - How are they made? WSTO E63 BMW M6 Forum and BMW M6 Convertible | m6board.com 0 24th June 2010 02:15 AM
