I have the V1 Radar aftermarket mirror.. what else is needed? - BMW M5 Forum and M6 Forums
 1Likes
post #1 of 12 Old 9th May 2019, 11:14 PM Thread Starter
Bavarianbattleship
Bavarianbattleship's Avatar
Hi Everyone,
I recently took delivery of a 2003 M5 and noticed that my mirror has the cutout inside for the V1 display. The previous owner said he never hooked it up and wasn't sure what was needed. I searched the boards, but most of the posts I found were more about sourcing the mirror itself. I figure since I've already got the mirror it's worth looking into what I need to connect it. Is anyone on here running that setup?
Thanks!
Bavarianbattleship is offline
post #2 of 12 Old 9th May 2019, 11:28 PM
Ferris
I'd assume you'd need a V1 radar detector. Not sure if they've moved away from the RJ11 connector or not though. I assume the display/mirror has an RJ11 for it.
2001 E36/7 MRoadster
2001 E39 M5
2010 E60 M5
2008 E90 335xi
Ferris is offline
post #3 of 12 Old 10th May 2019, 01:03 AM Thread Starter
Bavarianbattleship
Well.. scratch that plan. I was messing around with the mirror looking to see if there were any hidden wires and somehow... somehow.. the pressure I put on the housing cracked the windshield. I didn't even think that was possible. Looks like my money will be going into a new windshield instead of any radar gear... I can't believe that just happened. Well.. 1 month in, 1st M5 repair! Ugh..
post #4 of 12 Old 10th May 2019, 07:45 AM
jasoncjung
When I got my M5, I barely touched the mirror and it fell off as well. I was lucky enough that the crack didn't go all the way through, so I have JB Weld'ed the glass and metal piece back on - but it's still delicate. So I've kicked that can down the road.
That being said, you have to twist on/off the mirror after you remove the base plastic covering.
About your original post, I assume there's an RJ11 (phone cord) in the headliner, which would power a V1. I have the 2nd best option which is a Stealthone that puts text on the stereo and dash. I called Valentine directly and asked for a "refurbished" model and it was 10% off. It looked new in the box and carries all the same warranties and most up to date software. Also has the same 30 day return policy as new ones, in the event you aren't satisfied.
jasoncjung is offline
post #5 of 12 Old 10th May 2019, 02:19 PM
DaveinGigHarbor
OP - I feel your pain, as I did the same thing to my windshield in a 2001 525iT. Tried to change the mirror to self dimming, and BAM, the windshield cracked big time. I was lucky because the people in the insurance office said they would not cover it, but a week or so later, I had a meeting with the insurance broker and mentioned it. He got me covered ($1000).
Sounds like all you need it to hook up a phone cable to a Valentine 1, which you will need.
I also have a StealthOne kit sitting in my garage, which I will be putting in my M5. What a great setup that is, keeping the V1 dark and sending the info to the dash. Very sad that the are no longer in business, as this was a great device.
2000 BMW M5, Anthracite with Heritage black leather
2008 Audi RS4 Cabriolet, Datona Gray with silver leather
2017 Chevy Silverado, my economy car!!!
1999 528iT, black/black, 212k miles. The Black Rat
2002 540iA, Silver with black leather
Gone but not forgotten:
2000 BMW 540/6 - Silver
2000 BMW 540/5 - Blue
2002 BMW 540/6 - Grey
2001 BMW 525it/auto
2001 BMW 525i/auto
DaveinGigHarbor is offline
post #6 of 12 Old 11th May 2019, 12:24 AM
offroadkarter
offroadkarter's Avatar
I might have to bug you about that stealthone, I have the box but the guy I bought it from never took the wires out of the car before selling it. If I can just find out what pin on the harness it uses to feed the ibus data, i can make my own wires.
2000 E39 M5 Carbon Black Evolve CAI / Evolve Alpha-N / Stoptech ST40 BBK / UUC SSK / Dinan front STB / Dinan RSB
2016 Ford Mustang GT PP
2004 Mercury Marauder
2003 Mercury Marauder
1996 Ford Bronco
offroadkarter is offline
post #7 of 12 Old 11th May 2019, 02:55 AM
josiahg52
josiahg52's Avatar
The wire is directly connected to the iBus junction center behind the glove box. A purple wire, if I remember correctly. I pulled a pin connector, soldered the StealthOne wire to it and snapped it back in to the junction center.
josiahg52 is offline
post #8 of 12 Old 11th May 2019, 02:31 PM
DaveinGigHarbor
I have a file of the StealthOne owners manual if you need it. Just PM me. I just looked at it and it did not call out a wire color, but just said connect to the I-Bus.
From the manual:
To Install StealthOne:
1. Select an appropriate location to install your Valentine One® using any of the
methods described in the Valentine One® owner’s manual. We recommend that
you use the direct wire power adapter provided with your Valentine One® and
tap into a switched 12v wire in the overhead console. This will allow you to
place the Valentine One® at the top of the front windshield, which will give it
the best unobstructed front and rear view.
Note: When mounted, Valentine One® must have an unobstructed view. It
cannot be mounted behind the windshield wipers.
2. Plug one end of the 2 Ft. RJ-11 modular Power Cable into the Valentine One®
Accessory (ACC) port using Valentine One®’s direct wire power adapter or the
cigarette lighter adapter, and then plug the other end of the Power Cable into
the StealthOne “V1 ACC” module port.
3. Plug the end of the RJ-11 modular Interface Cable that has the I-BUS wire
attached to it into the StealthOne I-BUS/AUX module port. Do not connect the
other modular plug to anything, but instead let the wire hang loose and locate
it in a convenient location. This modular plug will be used for in car
programming of the StealthOne with software updates and future options.
2001 BMW 525it/auto
2001 BMW 525i/auto
post #9 of 12 Old 13th May 2019, 05:26 PM Thread Starter
Bavarianbattleship
Alright... so i got the windshield replaced, but Safelight wouldn't touch the ball. I have it hanging off right now but can't for the life of me get that ball back on.
Any suggestions? BMW said they wouldn't even try and quoted $600 for a new mirror. I can't believe getting the ball back on is so hard. Since I have the V1 hard wired in there I can't just do the quarter turn and take the mirror out of the car. I saw a video of a guy using a block of wood and a jack to get the mirror back in the ball. Any help would be appreciated guys. Thanks!
2003 M5
1971 MG Midget
post #10 of 12 Old 13th May 2019, 08:21 PM
gsfent
gsfent's Avatar
I have used Safelite before (as recently as 5 months ago-they do very nice work) and I have never had them refuse to replace the rear view mirror. I would not pay for the job as I would consider that "incomplete". That is part of replacing the windshield.
I would contact customer service and contact your credit card company for a chargeback if necessary.
Dinan Stage 3 suspension, SS jet coated headers, ESS SC kit w/ 1 range colder NGK's, 92mm pulley, 440 Big Greens, TTFS alpha N tune for meth, RK plenum plates, SBC Endurance Stage 3 Kevlar performance clutch setup, "Jed" lightened DMFW, open brake ducts, TEC cupholder, U.S.(Euro style) tilt/slide armrest, 6k HID fogs, Umnitza bi-xenon flamethrowers w/6k super white low beams, rear fogs, V1/Stealth1, dual head LI, 2.65 diff w/40% lockup/2x dynamic, compact spare, M5 logo trunk carpet, Euro trailer hitch, Mocal oil cooler, ACS type rear spoiler, Rogue custom SSK and tranny mounts, ST 355 BBK (fronts), BP sway bar brackets, Bluetooth retrofit, Speedhut boost gauge (20 psi), Dinan TB's and VS, KB BAP, Howerton/HFS-3 Aquamist WI trunk setup (50/50), with 2nd gauge in rear view mirror, aftermarket trunk mounted sound system integrated into stock unit (amps, crossovers, sub and speakers).......
gsfent is offline
radar and laser jammer fais2000 E39 M5 and E52 Z8 Discussion 22 4th February 2006 07:46 PM
Aftermarket NAV install, subs to fit in M-Audio spots HDClown E39 M5 and E52 Z8 Discussion 12 2nd December 2005 03:09 PM
Rant: Radar drones and CHP radar M-Fünf E39 M5 and E52 Z8 Discussion 24 16th October 2005 12:25 AM
What Radar Detector Do You Use??? BlackBM E60 M5 and E61 M5 Touring Discussion 60 11th October 2005 01:33 PM
Radar Detector or Sonar Radar detector ?? fais2000 E39 M5 and E52 Z8 Discussion 1 2nd September 2000 06:45 AM
