Help identify what's missing - Xtron nav unit removal, back to OEM - Page 3 - BMW M5 Forum and M6 Forums
 2Likes
post #21 of 28 Old 9th May 2019, 01:00 PM
Marcel RSD
Marcel RSD's Avatar
If the back light is on in the monitor, you are not getting a video signal. Can it be that this navigation unit is from a e46 with arrow navigation and you need to re-code it to 16:9 monitor ? If there is no external video module, I assume will not have a (correct) video signal.
Done so far:
- Evolve ECU tune, Alpha-N, sec. air pump delete, oct. 98, speed limiter removal
- Evolve carbon air intakes
- Evolve IATS relocate
- Evolve Medusa Headers
- Evolve 200 cell cats
And of course very happy with these mods
Marcel RSD is offline
post #22 of 28 Old 9th May 2019, 01:05 PM Thread Starter
lockeed
lockeed's Avatar
lockeed is online now
post #23 of 28 Old 9th May 2019, 01:33 PM
Marcel RSD
Marcel RSD's Avatar
Is your MKIII unit coded for e39 wide-screen or small screen or is it from an e46 and coded for arrow navigation ?
If it is coded for arrow navigation, you will not have a correct video output which is causing a "black screen".
You can try NAVCODER to see how it is coded.
Done so far:
post #24 of 28 Old 9th May 2019, 02:43 PM Thread Starter
lockeed
lockeed's Avatar
I'm sure it's the OEM one.
The previous owner installed the Xtron because the screen went dark, didn't do anything to diagnose it...
01' M5 Silver
08' M3 Sedan white
02' M3 Coupe Silver
post #25 of 28 Old 9th May 2019, 03:20 PM
Marcel RSD
Marcel RSD's Avatar
If it is the original unit which was installed then the best solution is to try a unit from somebody else. I think the video board is toasted/defect in the navigation unit.
Done so far:
post #26 of 28 Old 9th May 2019, 04:12 PM Thread Starter
lockeed
lockeed's Avatar
Yup, that's exactly what i'm gonna do. There's an MKIII unit on the way which Chris helped me out with.
01' M5 Silver
08' M3 Sedan white
02' M3 Coupe Silver
post #27 of 28 Old 19th May 2019, 04:11 PM Thread Starter
lockeed
lockeed's Avatar
Quick update. The replacement nav unit solved the blank screen problem. Works like a charm.
Now I found out the cd changer was empty and the 6cd cartridge is missing.... I'll need to find a 6 cd cartridge or some sort of MP3 player or hdd that would take the charger's place and connect to the system. I think I've seen that somewhere....
01' M5 Silver
08' M3 Sedan white
02' M3 Coupe Silver
post #28 of 28 Old 20th May 2019, 12:46 PM
Marcel RSD
Marcel RSD's Avatar
I have the CP600BMW as CD emulator and does a terrific job playing MP3 with tags to the monitor. But you can also use GROM or get your hand on an OEM Alpine MP3 player.
Done so far:
Adjusting viewing angle of nav screen Frits E39 M5 and E52 Z8 Discussion 32 2nd April 2018 10:15 AM
DIY: Avin Android Head Unit Install (plus new amp) Ikazuchi E39 M5 and E52 Z8 Discussion 58 25th January 2018 10:16 PM
E39 For Sale: E39 OEM 16:9 Navigation Wide Screen and MK3 (MKIII) GPS Unit Dking078 Parts / Other For Sale or Wanted 35 28th September 2017 05:36 PM
CIC Retrofit for BMW E63s - (Long and Pic Heavy) AlexMSFT E63 BMW M6 Forum and BMW M6 Convertible | m6board.com 40 20th June 2014 04:33 PM
