How did he get these exhaust pops? - Page 2 - BMW M5 Forum and M6 Forums
 4Likes
post #11 of 25 Old 7th May 2019, 05:05 AM
Sailor24
Sailor24's Avatar
I have not heard one do it and it is part of emissions requirements to turn off fuel on decel for all new cars since IIRC 98. Maybe it was fake sound from the audio.
Sailor24 is offline
post #12 of 25 Old 7th May 2019, 01:08 PM
CSBM5
CSBM5's Avatar
It's not emissions decel with the S55 tuning...not at all unfortunately. The S55 in my M2C when in Sport or Sport+ mode is full of pops, burbles and crackles on the over-run. Outside the car it is fairly loud but well integrated into the exhaust sound; let one go by you at full throttle in 2nd and then abruptly lifts off throttle at about 5k rpms....loud ripping tear followed by burbles. Put it in Comfort mode, and all is much quieter and all those shenanigans are gone.
As to the other subject about fuel cut-off on closed throttle...that first appeared with Bosch Motronic in 1982 on the M20 in the 528e (in North America) and then in the M30 and others. Hence all BMWs from E28 onward essentially have fuel cutoff on closed throttle (above a preset rpm, usually about 1400). 37 years now.
Current stable:
CSBM5 is offline
The Following 2 Users Say Thank You to CSBM5 For This Useful Post:
Blockdoc (11th May 2019)
post #13 of 25 Old 7th May 2019, 03:15 PM
bfp9
bfp9's Avatar
If your F80 did that is was broken also. If that car is running a stock tune it is also broken. In the long term it will not be good but hard to say bad either, just depends.
If you want to do that just imitate what is broken, 1/2 the clutch switch. Two parts to a clutch switch one for starting and one to know that you pushed in the clutch so it will supply fuel to the injectors so the car does not stall when you are off the gas. One switch works at the top of the pedal the other at the bottom.
All you need to do is remove one wire and you can guess at it if you want pull any that go to the starter part car won't start any of the others are fine.
Competition Package S55 motors do it from the factory, with nothing wrong with them.
Originally Posted by DonutFlame View Post
Pretty sure my F80 that I bought brand new wasn’t broken. It was bone stock. The burbles and pops are part of the competition package.
Exactly. 2017 F80 Competition Pack here and it snaps crackles and pops from the factory at 4500-6000rpms upon letting up on the gas.
2000 M5 - UUC SSK/DSSR, Bilstein PSS, Billy Boat Exhaust, ZHP Knob, Blacked out Kidneys, Dinan Rear Sway Bar with BeastPower brackets, Hardwired Passport 9500xi.
bfp9 is offline
post #14 of 25 Old 7th May 2019, 04:59 PM
SidekickChuck
SidekickChuck's Avatar
My car does this (though not as loud) after installing my x-pipe and exhaust. While it typically only happens when letting off the throttle at certain RPM ranges, you can re-create it by letting off the throttle, and tapping the throttle pedal with your foot. Not enough to propel you forward, but enough to send fuel to be burbled off. I very much dislike all the pops on so many cars these days as it seems you hear the machine gun pops on so many cars if you sit and watch cars go by on a busy road.
2001 BMW e39 M5
Eisenmann Race Exhaust
SS X-Pipe resonator delete
Powerchip Tune
South Bend Stage II Endurance Racing Clutch
CNS Lightened Flywheel
KW Variant 3 Coilover Suspension
RDSport 19" RD2
AC Schnitzer Type II Racing 19x9.5F 19x10.5R
Latest Photos
SidekickChuck is offline
post #15 of 25 Old 7th May 2019, 06:16 PM
OjaiM5
OjaiM5 is offline
post #16 of 25 Old 9th May 2019, 02:06 AM
pmalik
I used to have an F80 M3 that did this in stock form. Should I have bought a honda civic instead?
I'm pretty sure F80 m3 doesn't just dump fuel into the exhaust on overrun, because that's what' that e39 is doing. Turbo anti lag, except without a turbo...
pmalik is offline
post #17 of 25 Old 9th May 2019, 07:12 AM
Sailor24
Sailor24's Avatar
Well that is getting into another area and it is from fuel being left in the head sitting on the valves when you let off the gas. At full throttle your injector duty cycle is 95% likely. That is a ton of fuel at 5k or 6k rpm. The S62 burbles a bit at 6k when you come of the gas. My RS4 with two turbos added and 2 sizes up on injectors burbles for a very long time, because of all the fuel being dumped in for all that air I push through at 6k. It is atomized above the valve, it is not like it pours in like a tap.
When I come off the gas the air is reduced to nothing from 15 psi and just drags a little of that fuel into the cyl each pass. I can stop the burble by hitting the gas just a bit for a second or two.
Anyway my comment was based on the video, not full throttle at high rpms. If people want to take it out of context so be it.
Yes I recognize many manufacturers shut fuel off on decel much earlier but the point was it became law and there is no getting around that, so BMW is not adding fuel on decel so guys can hear their cars burble so they sell more cars.
Sailor24 is offline
post #18 of 25 Old 11th May 2019, 09:50 PM
Blockdoc
Blockdoc's Avatar
Correct. Standard on the competition packages. The big aftermarket tuning platforms (Bootmod3, Apline, MHD etc) all add this. Bootmod actually allow the user to modify burbles to his/her taste. Personally, I think it sounds ricey and turned them off in my F82. To each their own
Brian
2003 Sterling Grey M5 SOLD
ESS kit #1 with RK AUTOWERKS Upgrade! (RK/EVO software, Injectors, Fuel Pump)
Dinan Free Flow Exhaust, Dinan Rear Sway Bar
Super Sprint Headers
Rogue Octane SSK and WSR
DICE Ipod connectivity
Bimmian Black Kidney Grilles
Ultimate Pedals
Rear Wheels Up Front (275s all around)
Aquamist HFS3/Howerton Engineering Tank (pre/post SC nozzles)
RK Autowerks CNC Plenum Plates
2015 M4 Coupe DCT (BootMod flash Custom Paul Johnson Tune, downpipes, Methanol 100 percent , E30 map, Pure Turbos 700WHP+, 295/275 tires with Vorsteiner wheels)
2018 Jeep Hellcat Trackhawk (707HP Supercharged)
Blockdoc is offline
post #19 of 25 Old 13th May 2019, 04:20 AM
TexaZ3
TexaZ3's Avatar
Well, exhaust sound on F80 is computer generated soundtrack that comes through the speakers anyway, so you could do what ever sound you want, really. J/k, but I do find F80 exhaust sound super lame.
E36 1999 M3 Coupe Dakar Yellow/Black Vaders
E36 2000 M Coupe Cosmos Black/Black Leather, Shark, Conforti CAI, B&B Exhaust, H&R, Bilstein.
E39 2000 M5 Imola/Black Heritage
E46 2005 M3 Coupe ZCP Carbon Black/Black
E63 2006 M6 Coupe Indianapolis Red/Black/Madeira, Style 343
TexaZ3 is offline
post #20 of 25 Old 13th May 2019, 05:57 PM
Blockdoc
Blockdoc's Avatar
LOL. Thats why so many decat and do cartwheels trying to get rid of the Fart Can sound of the inline 6 LOL It is sSUCH a great engine though despite its sound
Ultimate Pedals
Blockdoc is offline
Currently Active Users Viewing This Thread: 3 (1 members and 2 guests)
Marvinnga
E60 M5 cats install Andrik28 E60 M5 and E61 M5 Touring Discussion 4 16th January 2015 04:08 AM
1st In-Depth F10 M5 RPi GT Exhaust Review BMWDave F10 M5 Discussion 10 16th February 2013 10:34 AM
Encore Innovation M5 E60 Exhaust opinions? itzjOw3 E60 M5 and E61 M5 Touring Discussion 2 17th January 2011 03:12 AM
Some things are not outsourceable [email protected] E60 M5 and E61 M5 Touring Discussion 8 24th December 2009 04:29 PM
Trouble codes and descriptions LeMansBlau E39 M5 and E52 Z8 Discussion 1 19th April 2007 03:43 PM
