Lower oil separator return pipe access - BMW M5 Forum and M6 Forums
 1Likes
  • 1 Post By M3Fan
post #1 of 9 Old 2nd May 2019, 02:38 AM Thread Starter
austrianvespaguy
austrianvespaguy's Avatar
If I have the belts, crank pulley, and harmonic damper off, is it possible to get the oil separator return pipe up out of the oil pan in order to change the o-ring on it, without resorting to removing the thermostat housing or messing with the lower rubber hoses? My hoses seem OK and I don't want scope creep to necessitate cracking open the coolant system on this one if possible; just want to go after the front main seal and perhaps this o-ring to hopefully stem my oil leak. I'm referring to the pipe #5 and o-ring #7. Thanks to anyone that knows whether this is or is not possible before I dive in!
RealOEM.com - Online BMW Parts Catalog
austrianvespaguy is offline
post #2 of 9 Old 2nd May 2019, 07:38 AM
Sailor24
Sailor24's Avatar
Only if you have small Hands and the tools to get at bolt 8. BTW it is hard to do the seal without removing the cover and putting it on a bench. You can do it but it is hard in the car, just depends on your experience and skills.
Sailor24 is offline
post #3 of 9 Old 2nd May 2019, 01:21 PM Thread Starter
austrianvespaguy
Thanks Sailor, I got this great little seal puller that I think should lower the difficulty to just a moderate level. Once I get everything off I'll probably make a slow and careful attempt to see if I can work that pipe out of there, but if it seems like it won't work I'm prepared to give up quickly and just finish the seal. 2.5" diameter PVC pipe is what I need to press in the new seal, correct?
post #4 of 9 Old 2nd May 2019, 02:35 PM
M3Fan
A standard hook-style seal puller gets the front crank seal out, reaching up from below the car, in about 5 seconds. Driving it in requires anything that circumference.
I wonder the same thing about the breather pipe O-ring.
Evolve Alpha-N tune, FMU Rear Exhaust, E60 Shifter
M3Fan is offline
post #5 of 9 Old 2nd May 2019, 07:10 PM
kiznarsh
kiznarsh's Avatar
Which seal are you referring to? Talking about the t-stat seal in case you need to remove it?
I'm also leaking from that O-ring but it's not too bad yet. But eventually if I have to replace the water pump & t-stat, then I'll tackle it then, along with the lower oil separator hoses.
'03 M5 | 987.2 Cayman | @kian.ski
kiznarsh is offline
post #6 of 9 Old 2nd May 2019, 11:28 PM Thread Starter
austrianvespaguy
Holy crap, so far, NOT a very fun job, but making good progress, think I have the old seal out and the new one in! Question though, what seals the oil out of the bolt passages? Whenever I'd pull the bolts out of the holes in the nose of the crank, they'd drag a little stream of oil out with them. I'm assuming this is normal, but I can't figure out what if anything keeps the oil from leaking out past the bolts in normal operation.
post #7 of 9 Old 3rd May 2019, 03:49 PM
M3Fan
There is no oil to seal out. Maybe that wept into the bolt holes from the leaky crank seal over time(?) Don't forget to replace those 4 bolts and torque them with an angle gauge.
M3Fan is offline
post #8 of 9 Old 3rd May 2019, 08:13 PM Thread Starter
austrianvespaguy
My guess is that with all 4 bolts out, any oil sitting on the crankshaft can run into the seam between the bit of shaft on the end of the crankshaft with the timing and oil pump chainrings on it and the actual crankshaft itself where the threads are, apparently those are actually 2 different pieces. Anyway, not worrying about it. New bolts arrive today and although I don't have an angle gauge, it generally works quite well for me to mark the bolt head and surrounding part so that I can check how much angle I've actually achieved on the bolts.
post #9 of 9 Old 6th May 2019, 02:26 AM Thread Starter
austrianvespaguy
Whew, all done, but for the record no I couldn't figure out how to get the return pipe out, so that o-ring will need to wait until the thermostat housing comes off some time in the future! On the plus side, it does seem that the real leaks was from the main seal, and so far (about 100 miles), still dry down there!
Oil thread with Lab Analyst First e28 M5 E34 M5 Discussion 239 27th March 2018 10:01 AM
How I resolved my oil consumption issue... suggestions for other sufferers Vindicator E39 M5 and E52 Z8 Discussion 82 11th March 2018 11:56 PM
S85 V10 oil level service bulletin cobradav E63 BMW M6 Forum and BMW M6 Convertible | m6board.com 6 7th February 2018 06:24 AM
DIY: Rod bearing change ger E39 M5 and E52 Z8 Discussion 21 25th October 2017 03:03 AM
Another Dealer Oil Overfill Question? EM_5 E60 M5 and E61 M5 Touring Discussion 11 4th March 2011 03:50 PM
