Seat heater/rear sun shade fuse - BMW M5 Forum and M6 Forums
post #1 of 2 Old 18th April 2019, 07:11 PM Thread Starter
booster_
So I had repaired the rear sunshade, but to my disappointment it's unusable because the fuse keeps blowing.
I read somewhere that this is maybe because the heating pad inside either seat has a short.
I'm not interested in using or repairing the heater element, the car is for summer duty only.
Can the heater be disconnected somewhere to prevent the fuse from being blown?
booster_ is offline
post #2 of 2 Old 22nd April 2019, 06:36 PM
gsfent
gsfent's Avatar
I don't know. But I would think if the seat heater is off, the short wouldn't matter. The circuit is not engaged. Same as disconnected.
Did you check the fuse chart in the glovebox to confirm they are on the same circuit? I would be surprised only because the seat heaters would draw a fair amount of power and they could be run at the same time as the rear shade.
I believe the rear fuse chart labels have been posted here somewhere (right hand side of trunk, behind the panel). Perhaps in connection with the fuel pump relay threads.
Dinan Stage 3 suspension, SS jet coated headers, ESS SC kit w/ 1 range colder NGK's, 92mm pulley, 440 Big Greens, TTFS alpha N tune for meth, RK plenum plates, SBC Endurance Stage 3 Kevlar performance clutch setup, "Jed" lightened DMFW, open brake ducts, TEC cupholder, U.S.(Euro style) tilt/slide armrest, 6k HID fogs, Umnitza bi-xenon flamethrowers w/6k super white low beams, rear fogs, V1/Stealth1, dual head LI, 2.65 diff w/40% lockup/2x dynamic, compact spare, M5 logo trunk carpet, Euro trailer hitch, Mocal oil cooler, ACS type rear spoiler, Rogue custom SSK and tranny mounts, ST 355 BBK (fronts), BP sway bar brackets, Bluetooth retrofit, Speedhut boost gauge (20 psi), Dinan TB's and VS, KB BAP, Howerton/HFS-3 Aquamist WI trunk setup (50/50), with 2nd gauge in rear view mirror, aftermarket trunk mounted sound system integrated into stock unit (amps, crossovers, sub and speakers).......
gsfent is online now
Review: Cobra Nogaro seats (uniquely street friendly fixed back bucket seat) Obioban E39 M5 and E52 Z8 Discussion 10 20th August 2018 02:20 PM
Can power rear sun shade be installed? Vason E39 M5 and E52 Z8 Discussion 15 28th February 2007 11:59 PM
Help! Rear Power Sun Shade Doesn't Work! jedigras E39 M5 and E52 Z8 Discussion 9 21st February 2006 06:53 AM
TECH: Little sun shade not retracting louv E39 M5 and E52 Z8 Discussion 3 23rd July 2003 08:54 PM
Rear sun shade busted.....again..... Serge E39 M5 and E52 Z8 Discussion 2 9th May 2001 06:50 PM
